What is the Datacenter Advanced Enrichment Actions PowerPack?
The Datacenter Advanced Enrichment Actions PowerPack contains automation actions that can be configured to collect additional diagnostic information when events occur and to provide instructions on how to troubleshoot issues. This additional information about an event is intended to assist the engineer responsible for troubleshooting and resolving that event.
What Technologies are Supported?
The Datacenter Advanced Enrichment PowerPack contains 348 automation actions that define different diagnostic information to be collected. In other words, you can execute 348 different sets of commands with this PowerPack. Each set of commands is specific to a type of device.
The following table lists the number of command sets for each type of device:
Device Type | Number |
Cisco ACE | 2 |
Cisco CSP | 2 |
Cisco Route/Switch | 33 |
Cisco IOS | 80 |
Cisco IOS-XE | 33 |
Cisco IOS-XR | 35 |
Cisco NSO | 3 |
Cisco NX-OS | 12 |
Cisco OLT | 1 |
Cisco StarOS | 32 |
Cisco Collaboration | 3 |
Cisco Unified Communication Manager | 20 |
Cisco UCS | 17 |
Cisco UCS C-Series | 17 |
Cisco Wireless | 18 |
Citrix NetScaler | 10 |
F5 | 21 |
Juniper JUNOS | 3 |
Juniper ScreenOS | 3 |
NetApp | 3 |
Installing the Datacenter Advanced Enrichment Actions PowerPack
Download the PowerPack from the ScienceLogic Support Site at https://support.sciencelogic.com/s/powerpacks.
Go to the PowerPack Manager page (System > Manage > PowerPacks).
In the PowerPack Manager page, click the button, then select Import PowerPack. The Import PowerPack dialog box appears:
Click the [Browse] button and navigate to the PowerPack file.
When the PowerPack Installer modal appears, click the button to install the PowerPack.
Overview of Configuring the Datacenter Advanced Enrichment Actions PowerPack
There are two general steps you need to take to configure the content in the Datacenter Advanced Enrichment Actions PowerPack:
- Configure one or more automation policies that use the actions included in the PowerPack. This is described in the Creating Automation Policies chapter.
- Configure credentials for the devices that are aligned with the automation policies. This is described in the Configuring Device Credentials chapter.
Unsupported Configurations
The following configurations are not supported by the Datacenter Advanced Enrichment Actions PowerPack:
- Customer-created automation actions that build command lists to be executed by the Enrichment: Util: Collect Enrichment Data automaton action are not supported without prior authorization from ScienceLogic.
- Modifications of any kind to the code supplied in the Datacenter Advanced Enrichment Actions PowerPack are not supported without prior authorization from ScienceLogic.
