What is the CrowdStrike Falcon Automation Synchronization PowerPack ?
The CrowdStrike Falcon Automation includes a configuration object, applications, and steps that bidirectionally sync jobs, pipeline jobs, and node status between CrowdStrike and SL1.
- SL1PowerFlow platform version: 2.3.0 or later
- CrowdStrike SyncPack version 100 or later
- SL1 version: 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
- The following dependencies are included in the SyncPack:
- SL1_Notifications>=1.0.2
- base_steps_syncpack>=1.3.2
- Administrator access to both SL1 and CrowdStrike
- CrowdStrike administrator access to the Administration Portal
- CrowdStrike administrator access to the GUI Portal
PowerFlow | CrowdStrike REST API | Any | TCP 443 | CrowdStrike REST API Access |
ScienceLogic highly recommends that you disable all firewall session-limiting policies as the firewalls will drop HTTPS requests resulting in data loss.
Contents of the SyncPack
This section lists the contents of the CrowdStrike Falcon Automation Synchronization PowerPack.
PowerFlow Applications
- Fetch Detections from CrowdStrike and Send Alert to SL1. This application acquires tokens and New Detections from CrowdStrike and creates alerts for SL1.
- Clear Detection from Cache. This application acquires and saves event details to send to SL1.
For more information about how to configure these applications, see Configuring Applications for the CrowdStrike Falcon Automation Synchronization PowerPack.
Configuration Object
- CrowdStrike Sample Configuration. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system.
Steps
- Fetch Detections and Generate Payloads for SL1
- Fetch New Detections from CrowdStrike
- Get Alerted Detections from Cache
- Get Each Detection and Create SL1 Alerts
- Get Event Details and Clear Detections ID
Installing the SyncPack
Downloading the SyncPack
- Click the .zip file containing the .whl file for this SyncPack to start downloading the file. button or click the name of the
Importing the SyncPack
- On the SyncPacks page (
) appears.
