What is the ELK Stack Synchronization PowerPack?
The ELK Stack Synchronization PowerPack includes a configuration object, applications, and steps that bidirectionally sync jobs, pipeline jobs, and node status between ELK and SL1.
- SL1 PowerFlow platform version: 2.3.0 or later
- ELK Stack Automation PowerPack version 100
- SL1 version: 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
- The following dependencies are included in the SyncPack:
- SL1 Notifications: 1.0.2
- base_steps_syncpack :1.3.2
- Administrator access to both SL1 and ELK
- ELK administrator access to the Administration Portal
- ELK administrator access to the GUI Portal
PowerFlow | ELK REST API | Any | TCP 443 | ELK REST API Access |
ScienceLogic highly recommends that you disable all firewall session-limiting policies as the firewalls will drop HTTPS requests resulting in data loss.
Contents of the SyncPack
This section lists the contents of the ELK Stack Synchronization PowerPack.
PowerFlow Applications
- Get Data from External Source. This application acquires data from external sources to update ELK statuses in SL1.
- Search Data in ELK. This application searches data in ELK and posts updates the SL1.
- Get Data from SL1. This application acquires data from SL1 to send to ELK and back to SL1 for updates.
For more information about how to configure these applications, see Configuring Applications for the ELK Stack Synchronization PowerPack.
Configuration Object
- ElasticSearch Logstash Kibana Configuration. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system.
Steps
- Get Log Data from SL1
- PostUpdateToSL1
- Get Search Results from ELK
- Send Data to ELK
- Update ELK Status To SL1
Installing the SyncPack
Downloading the SyncPack
- Click the .zip file containing the .whl file for this SyncPack to start downloading the file. button or click the name of the
Importing the SyncPack
- On the SyncPacks page (
) appears.
