What is the GraphiQL User Interface?
GraphiQL is a browser-based user interface for interactively exploring the capabilities of, and executing queries against, a GraphQL API. Unlike the SL1 REST API, all requests to the GraphQL API on a given SL1 system use the same URI.
To access the GraphiQL interface, type the URL or IP address for SL1 in a browser, add /gql to the end of the URL or IP address, and press .
GraphiQL is not maintained by ScienceLogic. You can access its documentation at https://github.com/graphql/graphiql.
GraphiQL User Interface Elements
The GraphiQL user interface enables you to write and execute operations, define variables, view operation results, and explore your schema, among other things.
The following sections describe all of the elements you can interact with in the GraphiQL user interface.
Query Pane
The left-hand pane in GraphiQL is the query pane. This is where you write GraphQL queries and mutations.
The query pane includes several features to help you properly formulate your queries and mutations:
- As you type, GraphiQL intuitively suggests potential fields, arguments, and syntax based on what you've already written and your defined schema.
- Additionally, GraphiQL automatically validates your query or mutation as you type, highlighting any errors in syntax or other elements that would cause your query or mutation to fail.
- GraphiQL highlights fields, arguments, syntax, and other important elements in the query pane to make the query or mutation easier to read.
- If you need to insert notes or comments in a query or mutation, add them on a line that starts with the # symbol above or below the query or mutation. GraphiQL ignores any lines that start with # when executing an operation.
- As you edit a query or mutation, GraphiQL automatically updates the URL that appears in the address bar to reflect what you have entered. It preserves every part of your entry in the URL, including whitespace, comments, and invalid syntax or elements. This feature enables you to share your query or mutation publicly or with colleagues for distribution or debugging purposes.
- You can use the following keyboard shortcuts in the query pane:
- Shift + Ctrl + P: Prettify the query or mutation
- Shift + Ctrl + M: Merge the query or mutation
- Shift + Ctrl + C: Copy the query or mutation
- Ctrl + Enter: Execute the query or mutation
Query Variables Pane
The lower-left pane in GraphiQL is the query variables pane. This is where you can define variables that you are using in your query or mutation. You should write variables in JSON format.
When you first access GraphiQL, the Query Variables pane might be collapsed at the bottom of the page. Click the Query Variables header to expand it.
For more information about using variables, see the section on Variables.
Results Pane
The right-hand pane in GraphiQL is the results pane. This is where GraphiQL displays the results of the most recently executed query or mutation, in JSON format.
Alternatively, if your query or mutation is not properly formed, the results pane displays the errors that are causing the query or mutation to fail.
GraphiQL highlights fields, arguments, syntax, and other important elements in the results pane to make the results easier to read.
The results that display in this pane are read-only, so you cannot accidentally edit or delete them.
Documentation Explorer Pane
The Documentation Explorer pane on the right-hand side of the page. The Documentation Explorer pane enables you to search or browse through the GraphQL schema. This allows you to explore all of the possible queries, mutations, fields, types, arguments, and other schema elements that you can use.
button expands theFor more information about using the Documentation Explorer to browse the GraphQL schema, see the section on The GraphQL Schema.
Toolbar Buttons
The following buttons display in the toolbar at the top of the GraphiQL browser:
- The (Play) button executes the query or mutation in the main query pane.
- The query operation type from the query. button re-formats the text in the main query pane to make it easier to read. If your query or mutation is not properly formed, the button turns red when you click it and does not format the text. If there is only one unnamed query in the query pane, then clicking also removes the
- The button is similar to the button, except it also flattens a query that contains defined fragments.
- The button copies all of the text in the main query pane to your clipboard, enabling you to paste your query or mutation elsewhere.
- The button opens a new pane on the left side of the page that contains a list of the previous queries you have run in the GraphiQL interface. You can click a query to add it to the main query pane.
The GraphQL Schema
A common refrain you might hear when people discuss GraphQL is that it is "self-documenting". This is because of two key features in GraphQL:
- GraphQL's intuitive suggestions and validation capabilities as you type your query or mutation in the query pane
- The GraphQL schema, which explicitly defines all of the possible queries, mutations, fields, types, arguments, and other schema elements that you can use
In all, the GraphQL schema provides the following information:
- All of the possible queries you can make
- All of the possible mutations you can perform
- All of the types that you can query or mutate
- All of the fields within a given type
- All of the potential arguments for a given field
- The accepted value types for each argument
- The relationships between types
You can access the full schema in GraphiQL's Documentation Explorer, which you can open by clicking the button on the right-hand side of the page.
The GraphiQL Documentation Explorer is always synced with GraphQL, automatically adding new fields, types, and arguments as they are added to the schema. It also automatically removes deprecated fields from the schema.
Within the Documentation Explorer, you can search for specific elements within the schema, or you can click one of the two root types—query or mutation—and drill down from there by clicking the fields, arguments, and types that display.
Exploring the GraphQL Schema in the Documentation Explorer
To get the most value out of the Documentation Explorer, you must understand how to explore the SL1 GraphQL schema that it documents.
When using the Documentation Explorer to explore the GraphQL schema, keep in mind this basic rule: Everything you click in the schema will result in either a definition or an additional set of fields or types that represent additional layers in the schema (and, by extension, your query or mutation).
When you first open the Documentation Explorer, you will see that the schema begins with the two root operation types: query and mutation:
When you click one of the root operation types, a list of objects that are available for that operation type displays. Each object lists the object name, the arguments that can be passed into that object, the object's return type, and a definition of that object.
In the following example, let's say you clicked Query and then scrolled down to the following section:
- Schema and the back arrow at the top-left of the pane indicate that you clicked here from the main schema page.
- Query at the top-center of the pane indicates that you clicked on the Query root operation type from the main schema page, and that all of the objects listed in the pane below are objects that you can query.
- event is a query object. It represents an object that can be queried from the SL1 API. As indicated by the definition below it, you can use this particular object to get information about an individual event.
- The next three lines, which are surrounded by parentheses, are all of the possible arguments that you can pass into the event query object. Each argument is displayed in a field name: value type pair, where the field name indicates an API field associated with the object and the value type indicates how you must define that field if you include that argument in your query. Arguments are used to define your query parameters. This example includes the following arguments:
- id: ID!. When you use this argument, you must supply a unique identifier (as indicated by the ID value type) for the event id API field. The exclamation point indicates that you must include this argument in the query.
- isGlobalManagerRequest: Boolean. If you use this argument in the query, you must include true or false (as indicated by the Boolean value type) as a value for the event isGlobalManagerRequest API field.
- globalManagerStackSearch: GlobalManagerStackSearch. This argument has a "search" value type. If you include this argument, you must also include a nested set of search parameter fields below it. If you click GlobalManagerStackSearch in the schema, it displays all of the nested fields that you can include in the globalManagerStackSearch argument, along with their value types. If you click on their value types, the schema might display even more fields and their value types.
- Event is the return type for the event query object. The return type consists of one or more fields related to the event that you specified in your argument; you are requesting that GraphQL return values for these fields when you execute the query. The schema lists all of the fields that belong to the Event return type, along with their value types.
Example 1: Using the Schema to Execute a Simple Query
This example describes how to use the Documentation Explorer to explore the SL1 GraphQL schema and determine the specific objects, arguments, and return fields that we need to include in a query.
For this example, we are executing a simple query: We are asking GraphQL to return some basic information about a single user account in SL1.
To use the schema to execute this simple query:
- In the GraphiQL user interface, click the Documentation Explorer. The main schema page displays: button to expand the
- Because we are executing a query, click the Query type link. A list of all potential query objects displays in the Documentation Explorer.
- Because we want to query a specific user account, browse the list or use the search feature to locate the entry for the account query object:
- Click the account object link that displays in blue text. The schema displays a more readable version of the information that appeared for the account object in the list of query objects. The schema defines the object, shows that it has a return type of Account, and indicates that it has just a single argument (id: ID!):
- Click the ID! argument value type link. The schema displays a definition for the ID scalar type that specifies the type of value you must enter in the argument for the id field:
- Click the back arrow in the top-left corner of the pane to return to the account object definition, then click on the Account return type link. The schema displays a list of all the potential fields that you can ask GraphQL to return in your account query, along with their value types:
- Click through the return fields and value types as needed to view their definitions. For this example, let's assume we clicked the definitions for id: ID!, user: String, and administrator: Boolean for additional information about those fields, if needed.
- Having reviewed the schema in the Documentation Explorer, type the query in the query pane. In this query, we are asking GraphQL to return the user ID number and username for the user account with the ID "25", and indicate whether that user account is an administrator:
query basicAccountInfo {
account(id: 25) {
id
user
administrator
As you type your query, GraphiQL automatically suggests potential fields, arguments, and syntax based on what you've already written and your defined schema; validates your query or mutation as you type; and uses different colors to highlight fields, arguments, syntax, and other important elements to make the query easier to read.
- Click the (Play) button. The query results display in the results pane. Having reviewed the schema, we can expect GraphQL to return an ID number for the id field, a string for the user field, and a boolean value for the administrator field:
"data": {
"account": {
"id": "25",
"user": "example",
"administrator": false
Example 2: Using the Schema to Execute a Complex Query
This example expands on the previous example to execute a more complex query about the same user account.
For this example, we are asking GraphQL to return additional information about the user account from Example 1, including information about the user's contact information, physical location, and organization membership. This example will require us to dig deeper into the schema in the Documentation Explorer to successfully execute a more advanced query.
To use the schema to execute this more advanced query:
- Complete the steps in Example 1.
- In the Documentation Explorer, click the back arrow in the top-left corner of the pane to return to the Account return type definition and fields:
- In this example, one of the things we want to add to the query is the user's contact information. From the list of Account return fields and value types, locate the contact: Contact field: value type pair, and then click the Contact type link. The schema displays a list of all the potential contact information fields that you can ask GraphQL to return in your account query, along with their value types:
- Click through the return fields and value types as needed to view their definitions. For this example, let's assume that we do not want GraphQL to return values for every possible contact return field, but that instead we want GraphQL to return values for just a few of them: The user's first name, last name, and email address. Therefore, let's assume we clicked the definitions for firstName: String, lastName: String, and email: [String] for additional information about those fields, if needed.
Because the value type for the contact return field is the custom Contact type, which itself consists of these additional return fields, we will need to nest these additional return fields under the contact return field when we form the query. If we include only the contact return field in our query without specifying any nested return fields under it, GraphQL will return values for every possible contact field.
- Click the back arrow in the top-left corner of the pane to return to the Account return type definition and fields.
- In this example, we also want to add information about the user's physical location to the query. From the list of Account return fields and value types, locate location: Address and then click the Address type link. This time, however, the schema does not display any fields for the Address type; instead, it indicates that the Address type itself has a possible type of USAddress:
- Click the USAddress type link. The schema displays a list of all the potential U.S. Address fields that you can ask GraphQL to return in your account query, along with their value types:
- Click through the return fields and value types as needed to view their definitions. For this example, let's assume that we clicked the definitions for address: String, city: String, state: String, and zip: String for additional information about those fields, if needed.
Because the value type for the location return field is the custom Address type, which in turn has the possible custom USAddress type that consists of these additional return fields, we will need to nest these additional return fields under the location return field when we form the query. To do this, we will need to include an inline fragment that allows us to specify that the location return fields that we are including in the query belong to the USAddress type within the schema. We can do this using the format "... on USAddress" in our query.
- Click the back arrow in the top-left corner of the pane to return one final time to the Account return type definition and fields.
- Lastly, in this example, we want to add information about the user's organization to the query. From the list of Account return fields and value types, locate organization: Organization and then click the Organization type link. The schema displays a list of all the potential organization fields that you can ask GraphQL to return in your account query, along with their value types:
- Click through the return fields and value types as needed to view their definitions. For this example, let's assume that we clicked the definitions for id: ID!, company: String, and events for additional information about those fields, if needed. If you do so, you discover that those first two are field: value type pairs like we have encountered throughout this example, but the events return field includes its own list of arguments and a connection type, EventConnection:
- For this example, we want to query GraphQL to return some basic information about the first three events aligned to the user's organization. To do this, we will use the first: Int argument, and then we will query several fields under the EventConnection connection type. Click the EventConnection type link:
- EventConnection is a connection type. Connection types consist of one or more edges that connect two nodes. The schema reflects this, so from EventConnection, click [EventEdge]:
- From EventEdge, click Event. The schema displays a list of all the potential event fields that you can ask GraphQL to return from the Event node in your account query, along with their value types:
- Click through the return fields and value types as needed to view their definitions. For this example, let's assume that we clicked the definitions for id: ID!, severity: String, message: String, and dateAcknowledged: Int for additional information about those fields, if needed. Let's assume that we also clicked the definition for source: EventSource, which we discovered had additional nested fields, including id: ID!.
- Having reviewed the schema in the Documentation Explorer, type the query in the query pane. In this query, in addition to the information we queried in Example 1, we are asking GraphQL to return:
- The user's contact information, including first name, last name, and email address
- Information about the user's physical location, including address, city, state, and ZIP code
- Information about the user's organization, including its organization ID and company name, along with the event ID, severity, source ID, event message, and acknowledged date of the first 3 events aligned to that organization
account(id: 25) {
id
user
administrator
contact {
firstName
lastName
email
location {
... on USAddress {
address
city
state
zip
organization {
id
company
events(first: 3) {
edges {
node {
id
severity
source {
id
message
dateAcknowledged
- Click the (Play) button. The query results display in the results pane. Having reviewed the schema, we can expect GraphQL to return data for all of the fields in the format of their respective defined value types:
"data": {
"account": {
"id": "25",
"user": "example",
"administrator": false,
"contact": {
"firstName": "Example",
"lastName": "User",
"email": [
"example@sciencelogic.com"
"location": {
"address": "10700 Parkridge Blvd",
"city": "Reston",
"state": "VA",
"zip": "20191"
"organization": {
"id": "0",
"company": "System",
"events": {
"edges": [
"node": {
"id": "154134",
"severity": "0",
"source": {
"id": "2"
"message": "Ticket Created: 95",
"dateAcknowledged": null
{... 2 more nodes
The above result has been truncated to make it easier to read in this documentation. When you actually complete this example, information about the second and third events will display in the results in the place of {... 2 more nodes}.
Example 3: Using the Schema to Execute a Mutation
This example describes how to use the Documentation Explorer to explore the SL1 GraphQL schema and determine the specific objects, arguments, and return fields we need to include in a mutation.
For this example, we are telling GraphQL to create a custom link to appear in the SL1 Action Runner.
To use the schema to execute this mutation:
- Because we are executing a mutation, click the Mutations type link. A list of all potential mutation objects displays in the Documentation Explorer.
- Because we want to create a new custom link, browse the list or use the search feature to locate the entry for the createCustomLink mutation object:
- Click the createCustomLink mutation object. The schema displays a more readable version of the information that appeared for the createCustomLink object in the list of mutation objects. The schema defines the object, indicates that it has just three potential arguments, and shows that it has a return type of CustomLink:
- Click the CustomLinkEntity! argument value type link. The schema displays a definition that specifies the type of value you must enter in the argument for the entity field. According to the schema, the only acceptable value is device.
- Click the back arrow in the top-left corner of the pane to return to the createCustomLink object definition, then click through the other argument value types as needed to view their definitions.
- Click on the CustomLink return type link. The schema displays a list of all the potential fields that you can ask GraphQL to return when it executes your createCustomLink mutation, along with their value types:
- Having reviewed the schema in the Documentation Explorer, type the mutation in the query pane. In this mutation:
- The custom link would display for all devices that used the custom attribute "Restorepoint ID". It would not display for devices that do not use that custom attribute.
- When creating the mutation, you would replace [Restorepoint Hostname or IP] in the url argument with the Restorepoint hostname or IP address that you want the link to open.
- When clicked, the link would open the URL https://[Restorepoint Hostname or IP]/#/device/{attribute.label.Restorepoint ID}, where [Restorepoint Hostname or IP] would already be defined and SL1 would automatically replace {attribute.label.Restorepoint ID} with the Restorepoint ID custom attribute value of the device from which the link was clicked.
- The custom link would display in the Action Runner as "Restorepoint".
This is the mutation we would type in the query pane:
mutation createCustomLink {
createCustomLink(
entity: device,
url: "https://[Restorepoint Hostname or IP]/#/device/{attribute.label.Restorepoint ID}",
id
entity
url
name
editedBy {
user
dateEdited
As you type your mutation, GraphiQL automatically suggests potential fields, arguments, and syntax based on what you've already written and your defined schema; validates your mutation as you type; and uses different colors to highlight fields, arguments, syntax, and other important elements to make the mutation easier to read.
- Click the (Play) button. The mutation executes, and GraphQL displays the data you requested in the results pane.
