Configuring Applications for the Events SyncPack
This section describes how to configure the bi-directional Event Sync between ServiceNow and SL1.
Workflow for Configuring Event Integration
The following topics cover how to configure the various components that make up the Event Sync:
Configuring the ServiceNow MID Server
Starting with version 1.1.0 of this SyncPack, you can configure Event Sync without a ServiceNow MID Server. If you are not using a MID Server, go to "Configuring the ServiceNow Instance," below.
  1. Install the MID Server.
  2. Configure the MID Web Server.
  3. Configure the MID WebService Event Collector.
  4. Start the MID Web Server and the Event Collector.
  5. Run an external test of the MID Server configuration.
  6. Review the MID Server Script Include (ScienceLogic_JS).
  1. Install the ServiceNow Event Management plugin (com.glideapp.itom.snac). You can request this plugin directly from ServiceNow.
  2. Install the "ScienceLogic SL1: Event Integration" (Scoped) application (also called the Certified application).
  3. Configure the Connector Definitions.
  4. Configure the Connector Instance.
Configuring the SL1 Instance
  1. Install the ServiceNow Base Pack PowerPack version 107 or later.
  2. Create a ServiceNow credential in SL1.
  3. Enable the following Run Book Automation Policies:
  • ServiceNow: [Events] - Add/Update
  • ServiceNow: [Events] - Event Acknowledged
  • ServiceNow: [Events] - Event Cleared
  1. Enable the "ServiceNow: Add/Update/Clear Event" Run Book Action.
  2. Optionally, send custom data to ServiceNow using the Pass-through Option.
  3. Optionally, enable the "ServiceNow: [Events] - Click to Create" Automation Policy.
Configuring the PowerFlow System
  1. Install the ServiceNow Events SyncPack.
  2. Create a configuration object in the PowerFlow user interface.
  3. Align the new configuration file with the relevant set of PowerFlow applications (depending on whether you use a ServiceNow MID Server).
Starting with version 1.1.0 of this SyncPack, you can configure Event Sync without a ServiceNow MID Server. If you are not using a MID Server, skip this topic and go to Configuring the ServiceNow Instance.
See the following link for instructions on installing and configuring the MID Server for your ServiceNow instance: MID Server installation.
After you set up the MID Server, you can use the following procedures to configure the ServiceNow MID Server to work with the ServiceNow Events SyncPack.
Configuring the MID Web Server
To configure the MID Web Server (a MID Server is required for this step):
  1. In ServiceNow, install the Event Management plugin. You can request this plugin directly from ServiceNow.
  2. Navigate to Mid Server > Extensions > MID Web Server. The Mid Web Server Contexts page appears.
  3. Click New and complete the following fields on the new record:
  • Name. Type a unique name. Required.
  • HTTP/HTTPS Port: Specify a port number to listen on. The port number must be unique.
  • Authentication Type: Select Basic. Currently Basic is the only supported Authentication method. Complete the Basic Auth User and Basic Auth User Password fields with the relevant credentials.
  • Execute on: Select a specific MID Server or Cluster of MID Servers.
  • MID Server: Specify the MID Server or Mid Server Cluster you will use.
  1. Click Submit to save the new record.
In the Related Links section, the Test parameters option is not a valid test to confirm your setup.
Configuring the MID WebService Event Collector
To configure the MID WebService Event Collector:
  1. In ServiceNow, navigate to Mid Server > Extensions > MID WebService Event Listener.
  2. Click New and complete the following fields on the new record:
  3. Click Submit to save the new record.
Starting the MID Web Server and the Event Collector
To start the MID Web Server and the Event Listener:
  1. Navigate the MID Server > Extensions > Mid Web Server and select the MID Web Server you set up in Configuring the MID Web Server.
  2. In the Related Links section, click the Start link.
  3. Navigate to the MID Server > Extensions > MID WebService Event Listener and select the MID WebService  Event Listener you set up in Configuring the MID WebService Event Collector.
  4. In the Related Links section, click the Start link.
  5. Confirm that the MID Web Server and the MID WebService Event Listener has a Status of "Started".
External Testing of the MID Server Configuration
ScienceLogic recommends that you test the MID Server connection by using an external testing source outside of ServiceNow, PowerFlow, and SL1.
  1. Post a message to http://{MID_SERVER_IP}:{MID_Web_Server_port}/api/mid/em/jsonv2
  2. Example body:
        "records":
            "source" : "Simulated",
            "event_class": "ScienceLogic",
            "node" : "Postman",
            "type" : "High Virtual Memory",
            "resource" : "C:",
            "severity" : "2",
            "description" : "Test Event",
            "ci_type":"cmdb_ci_app_server_tomcat",
            "message_key": "Postman_109843242",
            "additional_info":{"name":"Create an event in snow"}
    IMPORTANT: The value of the Source Instance (event_class) field must be the same case-sensitive value used in the Connector Instance Name. If the values do not match exactly, the bi-directional connection will not work. In the example above, "ScienceLogic" is the Source Instance (event_class) name. For more information, see Configuring the Connector Instances.
  3. Verify that the Send resulted in an HTTPS Status 200.
Using the MID Server Script Include (ScienceLogic_JS) in ServiceNow
The MID Server Script Include is provided with the "ScienceLogic SL1: Event Automation" application (also called the Certified Application), and it requires the ServiceNow Event Management plugin (com.glideapp.itom.snac). You can request the ServiceNow Event Management plugin directly from ServiceNow.
For information about installing the Certified application, see Installing the "ScienceLogic SL1: Event Integration Application" in ServiceNow.
The MID Server Script Include contains the following main parts:
  • Test Connection
  • Execute
  • Update Source
Test Connection is for validating that setup is complete for returning delta changes back to the source instance.
The Test Connection process includes the following steps:
  1. The Initialize step pulls in the required functions and defines default variables.
  2. The Test Connection is a two-part requirement that checks for the application and configuration availability:
    • Validates Application is available via GET HTTP request to PowerFlow.
    • Validates Configuration is available via Get HTTP request to PowerFlow.
  3. For the Logs step, because the script is run on the MID Server, all logs are submitted to ms.log().
Execute: The part of the Script is currently is not in use, but it runs the same process as test Connection step. At this time the execute step does not pull down events from ScienceLogic with the MID Server Script Include. Events are delivered using a push methodology to the MID Server Listener.
Update Source: Picks up pending updates on the Connector Update Queues (em_connector_update_queue) table and sends them back to the configured source instance.
The Update Source process includes the following steps:
  2. Builds the URL.
  3. Validates the URL.
  4. Pulls all Records matching even_class, source instance and connector Instance name sitting in pending.
  5. For each record, checks to see if the record matches the following criteria:
    • New: Checks the Number field being null and a value being assigned.
    • Open: Checks for field change on the State field from Closed to a new value of Reopen or Open.
    • Closed: Checks for field change on the State field from Open or Reopen to a new value of Closed.
    • Acknowledge: Due the difference in how acknowledgments are handled in the two platforms, the Acknowledged criteria tracks the boolean value flipping to true and will return either the default ScienceLogic user_id of 1 or a defined user id.
  6. Matching values are written to new JSON code.
  7. Matching JSON code is validated to ensure that it has information that needs to be sent back to source.
  8. Posts the Request back to PowerFlow.
  9. For the Logs step, because the script is run on the MID Server, all logs are submitted to ms.log().
The following topics cover how to set up your ServiceNow instance for Event Sync.
As a prerequisite for running Event Sync, you will need to install the ServiceNow Event Management plugin (com.glideapp.itom.snac). You can request this plugin directly from ServiceNow.
If you are not using a MID Server in ServiceNow, you will need to add the x_sclo_powerflow.user role to the ServiceNow user account or Integration user.
Installing the "ScienceLogic SL1: Event Integration" (Scoped) Application in ServiceNow
The "ServiceNow Events" SyncPack uses the "ScienceLogic SL1: Event Integration" application (also called the Scoped or Certified application) to sync event status updates from ServiceNow back to SL1. You must install the "ScienceLogic SL1: Event Integration" application on your ServiceNow instance to enable this SyncPack.
The "ScienceLogic SL1: Event Integration" application requires that you have already installed the ServiceNow Event Management plugin on the target ServiceNow instance. You can request this plugin directly from ServiceNow. Also, the MID Server must be configured.
You need to have a ServiceNow HI Service Account to request this application and download it onto your ServiceNow instance.
You first request the "ScienceLogic SL1: Event Integration" application from the ServiceNow Store, and then you can install it.
To request and install the "ScienceLogic SL1: Event Integration" application:
  1. Go to the ServiceNow Store at https://store.servicenow.com and search for "ScienceLogic SL1".
  2. Select the "ScienceLogic SL1: Event Integration" application. The detail page for the application appears.
  3. Click the Get button and log in with your HI credentials.
  4. After the request is approved, log in to ServiceNow as an administrator and navigate to Application Manager (System Applications > Applications or My Company Applications).
  5. Click Downloads in the menu header or search for "ScienceLogic".
  6. Click the version drop-down for the "ScienceLogic SL1: Event Integration" application listing to make sure you are using the correct version of the application that is compatible with your version of this SyncPack.
  7. Click the Install button for the "ScienceLogic SL1: Event Integration" application. The installation is complete when the button changes to Installed.
  8. In the filter navigator, search for "ScienceLogic" and locate the application in the left-hand navigation menu to verify that the application was installed. You might need to log out of ServiceNow and log back in to see the updated left-hand navigation menu.
Configuring the Connector Definitions in ServiceNow
To configure the Connector Definitions used by the Update Sender transaction:
  1. Navigate to Event Management > Event Connectors (Pull) > Connector Definitions. The Connector Definitions page appears.
  2. Click New to create a new Connector Definition.
    When you create a Connector Definition, ServiceNow creates a template MID Server Script Include with the same name and "_JS" appended at the end of the name. This item is automatically attached to the new record in the JavaScript to run field after you click Submit.
  3. In the Name field, type a unique name and click Submit to save the new Connector Definition record. The Connector Definitions page appears:
  4. Open the Connector Definition you just created and complete the following fields:
    • Javascript to run. Attach the JavaScript file provided by the Certified application: ScienceLogic SL1: Event Integration.
    • Default schedule (seconds). Specify the time in seconds between retrieval of events, such as "120". This field is not required for this integration specifically, but it is a required field. Events will not be pulled when this is triggered.
    • Bi-Directional. Select this option to enable ServiceNow to send Alert changes back to the source instance. Enabling this allows SL1 as an external monitoring system to receive changes made in ServiceNow that are specific to Alerts.
    • Alert field identifier. Set to "Message Key". The field causes the source monitoring system to be updated.
  5. In the Connector Parameters section, double-click to add one or more rows using the following parameters to enable correct formatting and communication with the source event system:
    Name Example Required
    application_path /api/v1/applications/update_sl1_event_from_snow_trigger No
    configuration_path /api/v1/configurations/ + Configuration Name Yes
    log_level 30 (Default Log level) No
    run_path /api/v1/applications/run No
    sl1_userid 1 (Default user_id in SL1) No
    The entries that are marked as not required are supplied by default.
  6. Click Submit to save the updated Connector Definition.
Configuring the Connector Instance in ServiceNow
Before you can set up a Connector Instance in ServiceNow, you need to create a ServiceNow credential that will be used by the Connector Instance.
Creating a ServiceNow Credential
To configure the ServiceNow credential that will be used by the Connector Instance:
  1. Navigate to Connections & Credentials > Credentials. The Credentials page appears.
  2. Click New.
  3. Select Basic Auth Credentials. A new Basic Auth Credentials record appears.
  4. Complete the following fields on the new record:
  • Name. Type a unique name for the credential. Required.
  • User name. Type the ServiceNow user name.
  • Password: Type the ServiceNow password.
  2. After the record is saved, open it again and check the Active field on the record.
  3. Click Update.
To configure the Connector Instance:
  1. Navigate to Event Management > Event Connectors (Pull) > Connector Instances.
      The value of the Connector Instance Name must be the same case-sensitive value used in the Source Instance (event_class) field. If the values do not match exactly, the bi-directional connection will not work. In the example below, "ScienceLogic" is the Connector Instance Name.
    • Connector definition. Confirm that the Connector Definition you created is associated with this Connector Instance record.
    • Host IP: Specify the host IP address for PowerFlow.
    • Credential. Select the credential for connection to PowerFlow. For more information, see Configuring the ServiceNow Credential.
    • Bi-directional. Select this option.
  1. In the Connector Instance Values section, ensure that the values have been configured:
  2. In the MID Servers for Connectors section, select the MID Server.
  4. After the record is saved, open it again and click Test Connector to confirm the correct configuration. This option is only available after you submit the record.
  5. If you have a successful test connection, check the Active field on the record.
  6. Click Update.
Additional Configurations in ServiceNow
Event and Alert Alignment in ServiceNow
PowerFlow posts cached events to ServiceNow with an unique message Key. Events are created in ServiceNow with the payload data from PowerFlow. Based on the event rule conditions, the alert gets created automatically within ServiceNow, and events align to an alert based on the message Key unique identifier. All of the events that are aligned to an alert should have the same message Key.
A New Event Reopens a Closed Alert or Creates a New Alert Based on the Time of the Incoming Event
In ServiceNow, go to the Event Management Properties module under the Event Management application. On this page, you can access the Active interval (in seconds) within which a new event reopens a closed alert field (evt_mgmt.active_interval). In this field, you can set a time period in seconds within which an incoming event can either re-open a closed alert or create a new alert event with same message Key.
In the following image, this field has a value of 14400 seconds (4 hours):
You can configure these properties for each customer instance. You can have two different alerts with the same message Key. Consider the following scenarios:
  • When an event clear occurs to close the alert associated to it, and the next open event occurs within 4 hours (based on the setting in the image above), then this event would re-open the same alert.
  • When an event clear occurs to close the alert associated to it, and the next open event occurs after 4 hrs, then this event would not re-open the same alert. Instead, a new alert is created with the same message Key.
The following image shows an example of the second scenario:
In the above example, a clear event came in and closed the corresponding alert, Alert1901706 at 2023-01-01 12:00:42. The next open event that triggered with the same message Key was at 2023-01-01 21:24:16. The time difference was more than 4 hours, so as a result, this event created a different alert , Alert1905924 and did not re-open Alert1901706.
Fix Scripts to Validate the Above Scenarios in ServiceNow
When you have large-scale data in event and alert tables in ServiceNow, it can be difficult to manually test the alignment of events and alerts, as well as alerts re-opening or creating a new alert, as mentioned in the scenarios, above.
To address this issue, ScienceLogic created Fix Scripts that you can use to validate the output and see if there are any misconfigured event/alert alignment or any mismatched alert re-openings.
To validate the event alert data, the following Fix Script checks to see if events that are aligned to alerts have the same message Key; if not, the script it pulls misconfigured alert numbers and Event sysIDs and creates a .CSV file with this data and attaches it to the same fix script. You can look at the .CSV file to check if there are any misconfigurations.
To validate alert re-openings, the following Fix Script checks for the date/time differences between alerts with same message Key. The Script pulls out any misconfigured alerts, creates a .CSV file with this data, and attaches it to the same Fix Script. You can look at the .CSV file to check if there are any misconfigurations for the alert re-opening/new alert scenario.
The following topics cover how to set up your SL1 instance for Event Sync.
You must install the "ServiceNow Base Pack" PowerPack before you can perform the following procedures. For more information, see Installing the ServiceNow Base Pack PowerPack.
To configure SL1 to communicate with ServiceNow, you must first create a SOAP/XML credential. This credential allows the Run Book Automation scripts in the "ServiceNow Base Pack" PowerPack to connect with your ServiceNow instance.
The ServiceNow RBA - Example credential from the "ServiceNow Base Pack" PowerPack is an example SOAP/XML credential that you can configure for your own use.
  2. Locate the ServiceNow RBA - Example credential and click its wrench icon (). The Edit SOAP/XML Credential page appears:
  • Profile Name. Type a new name for the ServiceNow credential.
  • Content Encoding. Make sure text/xml is selected.
  • Method. Make sure POST is selected.
  • URL. Type the URL for your PowerFlow instance.
  • HTTP Auth User. Type the username of your PowerFlow instance.
  • HTTP Auth Password. Type the password of your PowerFlow instance.
  • Timeout. Type "5".
  1. Click Save As.
  3. On the Credential Management page (System > Manage > Credentials), make a note of the value in the ID column for the credential you just created:
    You will use this value with the sl1_credential_id parameter when you enable the snippet code of the "ServiceNow: Add/Update/Clear Event" Run Book Action Policy:
Enabling the Run Book Automation Policies in SL1
Before you can run the "ServiceNow: Add/Update/Clear Event" Run Book Action, you must enable the three related Run Book Automation policies in SL1:
These Run Book Automation policies could use considerable SL1 resources if you configure the policies to trigger the "ServiceNow: Add/Update/Clear Event" Action for every single SL1 event. To avoid this, you will need to manage your event policies and ensure that your SL1 instance is sized appropriately to handle the resources required for syncing events to ServiceNow.
To enable the three ServiceNow Run Book Automation policies:
  1. Locate the "ServiceNow: [Events] Add/Update" automation policy and click its wrench icon (). The Automation Policy Editor page appears:
  • Available Actions. If it is not already selected, select the corresponding ServiceNow Run Book Action policy and add it to the Aligned Actions column.
  2. Repeat steps 2-4 for the "ServiceNow: Event Acknowledged" and "ServiceNow: Event Cleared" Run Book Automation policies.
The "ServiceNow: Add/Update/Clear Event" Run Book Action policy contains several default values in the snippet code for the policy that you can customize to use with the ServiceNow Events SyncPack.
You can edit these values in the Input Parameters pane of the Action Policy Editor page for this policy.
To enable and customize the Run Book Action policy:
  1. In SL1, go to the Action Policy Manager page (Registry > Run Book > Actions).
  2. Locate the ServiceNow: Add/Update/Clear Event policy and click its wrench icon (). The Action Policy Editor page appears:
  2. In the Input Parameters pane, edit the snippet code as necessary, using the information in the Customizing the Snippet Code in the Input Parameters Pane section, below. When you are finished, click Save.
SL1 run book action snippets are written in Python. In the event of a syntax error, the policies will no longer run. As a result, you must ensure that all edits adhere to Python standards. True and False options are case-sensitive and must not contain quotes.
You can customize the following values in the "ServiceNow: Add/Update/Clear Case", "ServiceNow: Add/Update/Clear Event", or "ServiceNow: Add/Update/Clear Incident" run book action snippet code:
  • sl1_credential_id. Specifies the ID of the credential object. You can find this value in the ID column of the Credentials page (System > Manage > Credentials of SL1. For example: "sl1_credential_id": "101"
  • configuration. Specifies the ID of the configuration object used on PowerFlow. The configuration ID is all lower-case, with spaces in the configuration object "friendly" name replaced by underscores. For example: "configuration": "docs_configs".
    NOTE: To find the configuration ID with the PowerFlow API, make a GET request on this endpoint: https://<PowerFlow_service_hostname>/api/v1/configurations.
  • discard_if_no_ci. Specifies whether PowerFlow should create incidents in ServiceNow for devices that do not have a matching CI record. The default is false. Your options include:
  • true. If a device is not mapped to a CI, PowerFlow will not create an incident in ServiceNow, and SL1 is not updated. The following log message appears: "No CI found".
  • false. If a device is not mapped to a CI, PowerFlow will create an incident in ServiceNow and update SL1.
  • events_mid_server. Set this field to true if you are using a ServiceNow MID Server with the Event Sync, or set it to false if you are not using a MID Server.
  • message_key_template. This field lets you customize the message key used by PowerFlow to correlate SL1 events with ServiceNow alerts. This field is used with the Event Sync.
    • By default the value is "{{'{}'.format(event.event_id)}}", which creates a ServiceNow alert for each SL1 event; this is the existing MID Server flow behavior.
    • A suggested alternative value is "{{'{}+EVENT+{}'.format(event.node_id,event.event_policy_id)}}", which groups the events by parent entity, such as device or interface, and event policy ID. The SL1 region used in the aligned configuration object in PowerFlow will be prepended to this value to ensure it is unique across stacks.
    If you are using the MID Server and you use the message_key_template field to configure a message key with a one-to-many correlation between a single ServiceNow alert and multiple SL1 events, you should schedule the "Sync Alert Details from ServiceNow to SL1 Events" PowerFlow application to run, with the events_mid_server parameter selected on the Configuration pane for the "Sync Alert Details" application. These settings ensure that the ext_ticket_ref is populated when the ServiceNow alert re-opens. If you are using a message key with a one-to-one relationship between alerts and events, you do not need to schedule the "Sync Alert Details from ServiceNow to SL1 Events" application.
Customizing Logging in the run book action
You can customize the following logging-related items in the "ServiceNow: Add/Update/Clear" run book action snippet code:
  • logfile = /data/tmp/ServiceNow_add_update_clear_incident.log
  • Location for logging output.
  • Will be created if it does not exist.
  • Will be appended with each Run Book job.
  • Is case-sensitive.
  • do_debug_logging = True
  • True is on, False is off.
  • For troubleshooting, these can be enabled or changed.
  • Writes logs to /data/tmp/servicenow_rba.log.
Sending Custom Data to ServiceNow Using the Passthrough Option (Optional)
You can use the "ServiceNow: [Events] - Add/Update" Run Book Automation and the "ServiceNow: Add/Update/Clear Event" Run Book Action to "pass through" custom data about events to ServiceNow.
  • Create a new Run Book Action that pulls the relevant data and adds it to a dictionary called EM7_RESULT.
  • Add the new Run Book Action to the "ServiceNow: [Events] - Add/Update" Run Book Automation Policy, ahead of the "ServiceNow: [Events] - Add/Update/Clear Event" Run Book Action so that the new Action runs first, and then is consumed by the ServiceNow Action.
The following procedure describes how to configure the passthrough functionality.
  1. In SL1, go to the Action Policy Manager page (Registry > Run Book > Actions) and click Create to create a new Run Book Action policy:
  • Action Name. Type a unique name for the Action.
  • Complete the other fields as needed.
  1. In the Snippet Code pane, add the snippet code you want to include for the EM7_RESULT dictionary. For example, the following snippet code lets you override the ServiceNow Event work notes with a hardcoded note:
  • A long snippet might delay the ticket being created.
  2. Go to the Automation Policy Manager page (Registry > Run Book > Automation) and open the "ServiceNow: [Events] - Add/Update" Run Book Automation Policy.
  1. In the Available Actions section, add the new Run Book Action before the "ServiceNow: Create, Update, Clear Event" Run Book Action:
The output of this new Run Book Action will be consumed by the "ServiceNow: Create, Update, Clear Event" Run Book Action, ensuring that the EM7_RESULT dictionary is passed through to ServiceNow. The "ServiceNow: Create, Update, Clear Event" Run Book Action automatically populates the passthrough values with any values from EM7_LAST_RESULT. The passthrough overwrites any other previously defined fields, such as assignment group.
  1. You can add additional Run Book Actions to the Run Book Automation Policy for any additional workflows that you might want to run. The Automation Policy execute these Actions in a sequential, top-down order. However, the "ServiceNow: Create, Update, Clear Event" Run Book Action only consumes the EM7_RESULT dictionary from the Run Book Action directly above it.
Configuring the "ServiceNow: [Events] - Click to Create" Automation Policy (Optional)
The "ServiceNow: [Events] - Click to Create" Run Book Automation policy lets you manually create an alert in ServiceNow by clicking the Actions button () in SL1 for an event and selecting "Create External Ticket" (or by clicking the life-preserver icon () for an event in the classic user interface).
This policy is available in the "ServiceNow Base Pack" PowerPack version 104 or later.
To configure the "ServiceNow: [Events] - Click to Create" policy:
  2. Click Save to save your changes.
  3. Go to the Automation Policy Manager page (Registry > Run Book > Automation).
  1. Locate the ServiceNow: [Events] - Click to Create policy and click its wrench icon (). The Automation Policy Editor page appears:
  • Available Actions. If it is not already selected, select the corresponding ServiceNow Run Book Action policy to add it to the Aligned Actions field.
Configuring PowerFlow
The following topics cover how to set up your PowerFlow instance for Event Sync.
You must install the ServiceNow Events SyncPack before you can perform the following procedures. For more information, see Installing the ServiceNow Events SyncPack.
To use this SyncPack, you will need to use an existing configuration object in the PowerFlow user interface or create a new configuration object. Next, you need to align that configuration object to the relevant applications that are triggered by the Run Book Actions in SL1.
Depending on your SL1 environment and the third-party environment with which you are syncing data, you might be able to use the same configuration object with more than one SyncPack.
Creating a Configuration Object for Event Sync
For the ServiceNow Events SyncPack, you will need to make a copy of the "ServiceNow SyncPack" configuration object, which is the sample configuration file that was installed with the "ServiceNow Base" SyncPack. After you create the new configuration object, you will need to add specific name-value pairs as variables for this SyncPack. These variables are listed in the following procedure.
If you have already set up a configuration object that you are using for other ServiceNow SyncPacks, you can use that configuration object for Event Sync. Go to step 7 in the following procedure to add the variables needed for this SyncPack.
To create a configuration object for the Events SyncPack:
  2. Click the Actions button () for the "ServiceNow SyncPack" configuration object and select Edit. The Configuration pane appears.
  1. Click Toggle JSON Editor to show the JSON code.
  2. In the Configuration Data field, be sure to include the required block of code to ensure that the applications aligned to this configuration object do not fail:
      "encrypted": false,
      "name": "sl1_db_host",
      "value": "${config.sl1_host}"
      "encrypted": false,
      "value": "10.2.11.42"
  1. In the Configuration Data field, update the default name-value pairs or add your own to match your PowerFlow configuration. The Events SyncPack requires the following name-value pairs as variables:
    The mid_server name-value pairs are not needed in the configuration object if your ServiceNow configuration does not include a MID Server.
  • mid_server_api_protocol. The protocol used by the API of your MID Server. The default is http.
  • mid_server_host. The IP address of the ServiceNow MID Server, along with the port number of the listener. In ServiceNow, go to the MID Web Server Contexts page (MID Server > Extensions > MID Web Server) and select the record you are using for Event Sync. The port number is defined in the HTTP/HTTPS Port field (port_number) on the MID Web Server Context record form. For example: 192.168.1.1:1773.
  • mid_server_user. The MID Server user account. In ServiceNow, go to the MID Web Server Contexts page (MID Server > Extensions > MID Web Server) and select the record you are using for Event Sync. The user is defined in the Basic Auth User field (basic_auth_user) on the MID Web Server Context record form.
  • mid_server_password. The MID Server account password. In ServiceNow, go to the MID Web Server Contexts page (MID Server > Extensions > MID Web Server) and select the record you are using for Event Sync. The password is defined in the Basic Auth User Password field (basic_auth_user_password) on the MID Web Server Context record form. This is not a User on the sys_user table.
  • region. Unique identifier that identifies your SL1 instance within ServiceNow.
  • sl1_host. The URL or IP address for the target SL1 system.
  • sl1_user. User id of the user account the PowerFlow will use to log in to SL1.
  • sl1_password. Password for the user account that PowerFlow will use to log in to SL1.
  • snow_host. The URL for the target ServiceNow instance. For example: sciencelogic.service-now.com.
  • snow_user. User id of the user account that PowerFlow will use to log in to ServiceNow.
  • snow_password. Password of the user account that PowerFlow will use to log in to ServiceNow.
  • snow_event_class. Unique identifier for the PowerFlow host that specifies which PowerFlow host should receive updates from ServiceNow. For bi-directional functionality to work, the connector instance name needs to match the source instance (snow_event_class) field exactly. These fields are case-sensitive.
  • mid_rel_url. The relative URL for the Events Endpoint on the MID Server. Set this value to the following: /api/mid/em/inbound_event?Transform=jsonv2.
  1. Click Save. You can now align the new configuration object with the relevant PowerFlow applications:
The following code is an example of the JSON configuration data for this configuration object:
"name": "mid_server_api_protocol",
"value": "http"
"name": "mid_server_host",
"value": "10.2.2.150"
"name": "mid_server_user",
"value": "midserveruserexample"
"name": "region",
"value": "example_region"
"name": "mid_server_password",
"value": "example_password",
"encrypted": true
"name": "sl1_host",
"value": "10.2.2.89"
"name": "sl1_password",
"encrypted": true
"name": "sl1_user",
"value": "em7admin"
"name": "snow_host",
"value": "example.service-now.com"
"name": "snow_event_class",
"value": "example_val"
"name": "mid_rel_url",
"value": "/api/mid/em/inbound_event?Transform=jsonv2"
"name": "snow_password",
"value": "snowpassword",
"encrypted": true
"name": "snow_user",
"value": "snowadmin"
Configuring the PowerFlow Applications for Event Sync
The workflows for configuring PowerFlow applications for Event Sync are different based on whether your ServiceNow environment uses a MID Server. Both workflows are included in the following sections.
Configuring PowerFlow Applications for ServiceNow with a MID Server
To run Event Sync, you must "align" the configuration object to run with the following PowerFlow applications:
  • Cache SL1 Users
  • Create Event in ServiceNow from SL1 Event
  • Update SL1 Event from ServiceNow Trigger
  • Sync Alert Details from ServiceNow to SL1 Events
    You only need to run the "Sync Alert Details from ServiceNow to SL1 Events" application if you use a message key in the "ServiceNow: Add/Update/Clear Event" Run Book Action that has a one-to-many correlation between a single ServiceNow alert and multiple SL1 events. See the following procedure for more information.
If you want to link events with ServiceNow Configuration Items (CIs), you will need to run the "Sync Devices from SL1 to ServiceNow" application from the "ServiceNow CMDB" SyncPack. For more information, see Running a Device Sync.
To configure PowerFlow applications for ServiceNow with a MID Server:
  1. On the Applications page of the PowerFlow user interface, open the "Create Event in ServiceNow from SL1 Event" application and click Configure. The Configuration pane for that application appears.
  2. Click Save to align that configuration with the application.
  3. Repeat this process for the "Update SL1 Event from ServiceNow Trigger" application and the "Cache SL1 Users" application. The "Cache SL1 Users" application is in the "System Utils" SyncPack. ScienceLogic recommends that you schedule the "Cache SL1 Users" application to run at least once a week.
  4. If you use a message key that does not have a one-to-one correlation between SL1 events and ServiceNow alerts, you will need to open the "Sync Alert Details from ServiceNow to SL1 Events" application and edit the following parameters on the Configuration pane:
    • events_mid_server parameter for this application should be selected.
    • user_note_template field that accepts a Jinja2 template to generate custom user notes.
  5. Click Save.
  6. ScienceLogic recommends that you schedule the following PowerFlow applications:
  • "Cache SL1 Users": at least once a week
  • "Sync Alert Details from ServiceNow to SL1 Events": every 60 seconds
Configuring PowerFlow Applications for ServiceNow without a MID Server
To run Event Sync for ServiceNow without a MID Server, you must "align" the configuration object to run with the following PowerFlow applications:
  • Cache SL1 Users
  • Sync Cached SL1 Events to ServiceNow
  • Process and Cache SL1 Events
To configure PowerFlow applications for ServiceNow without a MID Server:
  1. On the Applications page of the PowerFlow user interface, open the "Sync Alert Details from ServiceNow to SL1 Events" application and click Configure. The Configuration pane for that application appears.
  3. For only the "Sync Alert Details from ServiceNow to SL1 Events" application, make sure that the events_mid_server parameter selected is not selected.
  4. Click Save to save the configuration settings.
  5. Repeat steps 1-4 for the "Cache SL1 Users" application, the "Sync Cached SL1 Events to ServiceNow" application and the "Process and Cache SL1 Events" application. The "Cache SL1 Users" application is in the "System Utils" SyncPack.
  • "Sync Cached SL1 Events to ServiceNow"
You do not need to schedule or run the "Process and Cache SL1 Events" application, as that is triggered by the "ServiceNow: Add/Update/Clear Event" Run Book Action in SL1.
