- A subscription that includes CMDB/Inventory Workflow Automations
Source IP | Destination | Source Port | Destination Port | Requirement |
ThousandEyes | PowerFlow API | Any | TCP 443 | PowerFlow API Access |
Contents of the SyncPack
This section lists the contents of the ThousandEyes Integration SyncPack.
PowerFlow Applications
- ThousandEyes: Process Alert. This application processes ThousandEyes alert data and creates an SL1 event.
For more information about how to configure these applications, see Configuring the ThousandEyes Application.
Configuration Object
- ThousandEyes Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
- Details for connecting to the SL1 database, including the URL, username, and password
- Details for converting ThousandEyes alerts into SL1 events including event and yname format, device matching, default device, and custom attribute matching
Steps
- Get Alert Data From ThousandEyes
- Transform ThousandEyes Alert Data to SL1 Event
- Trigger ThousandEyes Event Payload
Installing the SyncPack
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various integration applications in this SyncPack, as these settings are not retained when you upgrade.
Downloading the SyncPack
Importing the SyncPack
- On the SyncPacks page (
) appears.
