This SyncPack requires a subscription to ScienceLogic Standard solutions.
Prerequisites for the SyncPack
- Administrator access to the SL1 Administration Portal
- Administrator access to Microsoft Teams
- A secured SSL/TLS-enabled connection to PowerFlow
PowerFlow | Microsoft Teams API | Any | TCP 443 | Microsoft Teams API Access |
Contents of the SyncPack
This section lists the contents of the Microsoft Teams SyncPack.
PowerFlow Applications
- Create Channel For Event. This application creates a channel in Microsoft Teams to post event notifications from SL1.
- Created Channel Event Notification MS Teams.
- Major Event Notification To MS Teams.
- Outage Event Notification.
- Sync Event Status From Teams to SL1. This application synchronizes an event update made in Microsoft Teams with the event status in SL1.
For more information about how to configure these applications, see Configuring and Aligning a Configuration Object in PowerFlow.
- Sample Microsoft Teams Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
- Details for connecting to the SL1 API, including the URL, username, and password
- Details for connecting to the Microsoft Teams API, including the base URL, private instance URL, and API keys
- Details for connecting to an HTTP Proxy when communicating with Microsoft Teams, including the hostname or IP address, username, and password
- Mapping between SL1 events and Microsoft Teams alerts including, device ID format, heartbeat and schedule name, default user, and maintenance object format information
Steps
- Call User on Teams
- Create Teams Channel
- Create SL1 Payload
- Delete Event From SL1
- Fetch Channel ID From Name
- Fetch Microsoft Email
- Fetch Teams User Input Data
- Post Event Card To Teams
- Post Event Details To Channel
- Post Update to SL1
Installing the SyncPack
Downloading the SyncPack
Importing the SyncPack
- On the SyncPacks page (
) appears.
