Introduction to the Salesforce Service Cloud SyncPack
This section describes how you can use the Salesforce Service Cloud SyncPack to automatically synchronize Salesforce cases or incidents and SL1 events between your Salesforce and SL1 systems. The integration is bidirectional between SL1 and Salesforce.
  • A subscription that includes Incident/Notification Workflow Automations
  • Base Steps SyncPack version 1.3.2 or later
  • SL1 Base Notifications SyncPack version 1.0.1 or later
  • A Salesforce Developer account
PowerFlow Salesforce API Any TCP 443 Salesforce API Access
PowerFlow SL1 Database Any TCP 7706 SL1 Database Access
Contents of the SyncPack
This section lists the contents of the Salesforce Service Cloud SyncPack.
PowerFlow Applications
  • Bulk Resolve SL1 Events From Salesforce Cases. This application resolves SL1 events that were resolved by corresponding Salesforce cases.
  • Bulk Resolve SL1 Events From Salesforce Incidents. This application resolves SL1 events that were resolved by corresponding Salesforce incidents.
  • Create Salesforce Case. This application collects event information from SL1 and creates a case in Salesforce.
  • Create Salesforce Incident. This application collects event information from SL1 and creates an incident in Salesforce.
  • Get Acknowledged Salesforce Cases And Update SL1 Event. This application collects acknowledged case data from Salesforce and updates the corresponding SL1 event.
  • Get Acknowledged Salesforce Incidents and Update SL1 Event. This application collects acknowledged incident data from Salesforce and updates the corresponding SL1 event.
  • Pass Acknowledgment Details From SL1 To Salesforce Case. This application collects acknowledged event data from SL1 and updates the corresponding Salesforce case.
  • Pass Acknowledgment Details From SL1 to Salesforce Incident. This application collects acknowledged event data from SL1 and updates the corresponding Salesforce incidents.
  • Resolve Salesforce Case. This application resolves Salesforce cases that were resolved by corresponding SL1 events.
  • Resolve Salesforce Incident. This application resolves Salesforce incidents that were resolved by corresponding SL1 events.
For more information about how to configure these applications, see Configuring Applications for the Salesforce Service Cloud Synchronization PowerPack.
Configuration Object
  • Base Salesforce Configuration. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to SL1, including the host, username, and password.
  • Details for connecting to Salesforce, including the client ID, client secret, username, and password.
  • Details for adding connecting events and cases or incidents between SL1 and Salesforce, including options to populate the external URL, define the default acknowledging user, and resolving an SL1 event from Salesforce.
  • Details for customizing templates.
Steps
  • Create Bulk SL1 Payloads Including SF Email
  • Fetch Cases From Salesforce
  • Fetch Incidents From Salesforce
  • Fetch Resolved Cases From Salesforce
  • Fetch Resolved Incidents From Salesforce
  • Get Event Details And Create Salesforce Case
  • Get Event Details And Create Salesforce Incident
  • Pass Acknowledgment From SL1 to Salesforce Case
  • Pass Acknowledgment From SL1 to Salesforce Incident
  • Pass Case Resolution From SL1 to Salesforce
  • Pass Resolution From SL1 To Salesforce
  • Post Event Update to SL1
Installing the SyncPack
Downloading the SyncPack
  1. Go to the ScienceLogic Support Site.
  2. Click the Product Downloads tab and select PowerPacks.
  3. In the Search PowerPacks field, search for this SyncPack and select it from the search results. The Release Version page appears.
  4. On the PowerPack Versions tab, click the name of the SyncPack version that you want to install. The Release File Details page appears.
  5. Click the Download File button or click the name of the .zip file containing the .whl file for this SyncPack to start downloading the file.
If you are installing or upgrading to the latest version of this SyncPack in an offline deployment, see "Installing or Upgrading in an Offline Environment" in the SyncPack release notes to ensure you install any external dependencies.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see Activating and Installing a Synchronization PowerPack.
