Monitoring Device Logs Using theSL1 Agent
This section describes how to use the SL1 Agent to monitor logs with Log File Monitoring policies. SL1 supports multiple methods for ingesting log data, which you can use to generate events.
The following video explains log file monitoring with the SL1 agent:
  • The logs from the file or Windows log that an agent will send to SL1
You can create, edit, and delete Log File Monitoring policies from the Log File Monitoring Policies page (System > Manage > Log File Monitoring Policies). After creating a Log File Monitoring policy, you must align the policy to one or more devices either from the Log File Monitoring page or by using a Device Template.
You can view logs collected by the SL1 agent on the Logs panel on the Device Investigator page for the device on which the agent is installed. The same logs also appear on the Logs tab in the Device Properties and Device Summary pages for that device. You can define event policies that specify how logs collected by an agent will trigger events.
When running the agent as a dedicated user on Windows or Linux systems, the user requires Read access to any directories being monitored. To monitor system events on Windows, the user must be in the Event Log Readers group. See Installing a Windows Agent for more information.
The Log File Monitoring Policies page displays a list of all Log File Monitoring policies. From this page, you can also create, edit, and delete Log File Monitoring policies.
  • Policy ID. Unique numeric ID, automatically assigned by SL1 to each Log File Monitoring policy.
  • Filter. The regular expression that the agent uses to determine whether a log message is sent to SL1.
  • Edited By. SL1 user who created or last edited the Log File Monitoring policy.
  1. Click Create. The Log Monitoring Policy modal appears:
      • application
      • system
      • security
      • other
    • Limit. The maximum log messages the agent sends to SL1 per minute. If the number of matching logs exceeds this value, the agent will stop sending logs to the platform for the remainder of the minute. The limit resets at the beginning of the next minute.
    • Filter. Specify a regular expression that will be used to evaluate the log messages in the specified file or Windows log. If a log message matches this regular expression, the agent will send that log message to SL1. If a log message does not match this regular expression, the agent will not send that log message to SL1.
      For Windows event logs, the SL1 Agent adds the Event ID to the value in the Message portion of the Windows log before applying the value in the Filter field. The agent does not apply the value in the Filter field to the Instance ID or any other property of a Windows event log entry.
      Avoid adding a leading ".*" in a filter, such as ".ERROR", as that character might increase the time it takes the agent to execute the filter, and on busy SL1 systems, that character in the filter can negatively impact the CPU.
  1. Click Create. The Log File Monitor modal appears:
  1. In the Log File Monitor modal, supply values in the following fields:
  • Limit. The maximum log messages the agent sends to SL1 per minute. If the number of matching logs exceeds this value, the agent will stop sending logs to the platform for the remainder of the minute. The limit resets at the beginning of the next minute. For example, suppose you set this field to 10,000. Suppose the agent monitors a device that has 30,000 log messages. The agent will retrieve 10,000 logs and then wait until the beginning of the next minute. The agent will then retrieve the next 10,000 logs and then wait until the beginning of the next minute. The agent will continue to retrieve 10,000 logs per minute until it has retrieved all the logs from the device.
  • File. Specify a regular expression that will be used to evaluate the log messages in the specified file or Windows log. If and only if a log message matches this regular expression, the agent will send the log message to SL1.
  1. Select the checkboxes for the devices with which you want to align Log File Monitoring policies.
  2. In the Select Action drop-down list, select MODIFY by Template.
  1. Click Go. The Device Template Editor modal appears:
  1. Click the Logs tab.
  2. Click the Add New Log Policy Sub-Template icon ().
  5. Click Confirm. The aligned Log File Monitoring policy will appear on the Log File Monitoring page (Registry > Monitors > Logs).
  2. Click Save.
  3. In the Select Action drop-down list, select DELETE Log FIle Monitoring Policies.
  4. Click Go.
  • ID. The unique numeric ID of the Log File Monitoring policy. The ID is automatically assigned by SL1.
  • Filter. The regular expression the agent uses to determine if a log should be sent to SL1.
Filtering the List of Log File Monitoring Policies and Aligned Devices
You can filter the list of Log File Monitoring policies and aligned devices on the Log File Monitoring page using the search fields at the top of each column. When you type in each search field, the list of results on the page is automatically updated to match the text, including partial matches.
You can use special characters in each search field to filter. Fore more information about filtering using special characters, see the Filtering the List of Log File Monitoring Policies section.
To trigger events based on log messages collected by the agent, you must create an event policy on the Event Policies page, and then associate that event policy with a Log File Monitoring policy.
If you are using the classic user interface for SL1, see Creating an Event Policy for Agent Logs in the Classic User Interface.
To create an event policy that triggers based on log data collected by the agent:
  1. Go to Event Policies page (Events > Event Policies).
  1. On the Event Policies page, click the Create Event Policy button. The Event Policy Editor page appears:
  1. On the Event Policy Editor page and set of tabs, you can define a new event. The Event Policy Editor page contains the following fields and tabs:
  • Policy Name. At the top left of the Policy Description tab, type a name for the event policy in this field.
  • Enable Event Policy. This toggle allows you to enable and disable the event policy.
  • Policy Description. In this field, type a description of the event policy.
  1. Click the Match Logic tab to define pattern-matching for the event:
  • Event Source. Select ScienceLogic Agent as the source for the event. The fields below this field will change based on your selection.
  • Log Policy. Select the Log File Monitoring Policy the agent will use to collect the log message.
  1. After selecting and defining your Event Source, enter values in the fields on the right side of the Match Logic tab specify the text that must appear in the log message for the event policy to trigger:
  • String/Regular Expression. Use this dropdown to select String or Regular Expression.
  • Match String. A string used to correlate the event with a log message. Can be up to 512 characters in length. To match this event policy, the text of a log message or alert must match the value you enter in this field. Can be any combination of alpha-numeric and multi-byte characters. SL1's expression matching is case-sensitive. This field is required for events generated with a source of Syslog, API, and Email.
  • Second Match String (Optional). A secondary string used to match against the originating log message. Can be up to 512 characters in length. Can be any combination of alpha-numeric and multi-byte characters. To match this event policy, the text of a log message or alert must match the value you enter in this field and the value you entered in the Match String field. This field is optional.
  • Allow event to expire if it doesn't reoccur within a time frame. If toggled on, enter the time in which an active event will be cleared automatically if there is no reoccurrence of the event in the fields that appear. You can enter time in minutes or hours.
  • Require multiple triggers within a time frame. If toggled on, enter the number of events and the time in which an event requires multiple triggers to occur in the fields that appear. You can enter time in minutes or hours.
  • Detection Weight. If two event definitions are very similar, the weight field specifies the order in which SL1 should match messages against the similar event definitions. The event definition with the lowest weight will be matched first. This field is most useful for events that use expression matching. Options range from 0 (first) - 20 (last).
  • Multi Match. By default, SL1 will match a log message or alert to only one event policy. If a log message or alert matches multiple event polices, SL1 will use the Detection Weight setting to determine which event policy the log message or alert will match. If you select the Multi Match checkbox in all event policies that can match the same log message or alert, SL1 will generate an event for every event policy that matches that single log message or alert.
  • Message Match. If SL1 has generated an event and then a second log message or alert matches the same event policy for the same entity, SL1 will not generate a second event, but will increase the count value for the original event on the Events page and in the Viewing Events page. By default, this behavior occurs regardless of whether the two log messages or alerts contain the same message. If you select the Message Match checkbox, this behavior will occur only if the log messages or alerts contain the same message.
  1. Click the Event Message tab to configure the event:
  • Event Message. The message that appears in the Event Console page or the Viewing Events page when this event occurs. This field defaults to "%M" for new event policies upon creation. The message can be any combination of alphanumeric and multi-byte characters. Variables include the characters "%" (percent) and "|" (bar). You can also use regular expressions and variables that represent text from the original log message to create the Event Message.
    To include regular expressions in the Event Message, surround the regular expression with %R and %/R. For example, %RFilename: .*? %/R would search for the first instance of the string "Filename: " (Filename-colon-space) followed by any number of any characters up to the line break. The %R indicates the beginning of a regular expression. The %/R indicates the end of a regular expression.
    SL1 uses the regular expression to search the log message and use the matching text in the event message. For details on the regular expression syntax allowed by SL1, see http://www.python.org/doc/howto/.
    You can also use the following variables in the Event Message field:
  • Healthy. Healthy events indicate that a device or condition has returned to a healthy state. Frequently, a healthy event is generated after a problem has been fixed.
  • Notice. Notice events indicate a condition that does not affect service but about which users should be aware.
  • Minor. Minor events indicate a condition that does not currently impair service, but the condition needs to be corrected before it becomes more severe.
  • Major. Major events indicate a condition that impacts service and requires immediate investigation.
  • Critical. Critical events indicate a condition that can seriously impair or curtail service and requires immediate attention (i.e., service or system outages).
  • Use Modifier. If selected, when the event is triggered, SL1 will check to see if the interface associated with this event has a custom severity modifier. If so, the event will appear in the Event Console with that custom severity modifier applied to the severity in the Event Severity field. For example, if an interface with an Event Severity Adjust setting of Sev -1 triggers an event with an Event Severity of Major and that event has the Use Modifier checkbox selected, the event will appear in the Event Console with a severity of Minor.
  1. Optionally, supply values in the other fields on this page. For more information on the remaining fields, as well as the Suppressions tab, see Defining an Event Policy.
  2. Click Save.
To trigger events based on log messages collected by the agent in the classic user interface for SL1, you must create an event policy that is associated with a Log File Monitoring policy.
  1. In the Event Policy Manager page, click Create. The Event Policy Editor page appears:
  1. In the Event Policy Editor page and set of tabs, you can define a new event. The Event Policy Editor page contains three tabs:
    • %R. Indicates a regular expression. Surround the regular expression with %R and %/R. For example, %RFilename: .*? %/R would search for the first instance of the string "Filename: " followed by any number of any characters up to the line break. For details on the regular expression syntax allowed by SL1, see http://www.python.org/doc/howto/.
  1. Select the Advanced tab.
  1. Enter values in the following fields to specify specific text that must appear in the log message for the event policy to trigger:
  • First Match String. A string used to match against the originating log message. To match this event policy, the text of a log message must match the value you enter in this field. Can be any combination of alphanumeric characters. Expression matching in SL1 is case-sensitive.
The Match Logic field specifies whether SL1 should process First Match String and Second Match String as simple text matches or as regular expressions.
  2. Click Save.
