Installing the Skylar One Agent
This section describes how to install, upgrade, and uninstall Skylar One (formerly SL1) agents for Windows, Linux, AIX, and Solaris operating systems. All agent installations, upgrades, and uninstallations require command-line interface access to the targeted device.
Caveats
  • If you use the Skylar One Extended Architecture (which includes Compute Nodes, Storage Nodes, and a Management node), install the agent from the Agents page (Devices > Agent). For details, see Installing an Agent from the Agents Page.
    With on-premises Skylar One Extended Architecture systems, the TLS handshake can fail between the Windows Agent on a monitored device and the Skylar One streamer service. For details and the workaround, see the following Knowledge Base article: Extended Architecture.
  • If you use the Skylar One Distributed Architecture (where the Skylar One Agent collects and transfers data to a Message Collector), you can install the agent from the Devices page or from the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface). For details, see Installing an Agent from the Devices page or the Device Manager Page.
    If you are using PhoneHome Message Collectors in a Distributed Architecture, see Configuring a Skylar One Agent to Work with PhoneHome Collectors before you install the agent.
  • RPM installer packages must be signed. Therefore, when installing an RPM package, you might receive a warning message if the RPM store does not contain ScienceLogic's public GPG key.
    To address or prevent this warning, you can obtain the ScienceLogic key and then add it to the RPM store:
    1. Go to http://keys.openpgp.org/search?q=devops%40sciencelogic.com.
    2. Download the key.
    3. Import the key into the RPM store using the following command:
      rpm --import <file name>
When running Skylar One on the Skylar One Extended Architecture, you can use the Agents page (Devices > Agents) to help you install the Skylar One agent on a Linux, Windows, AIX, or Solaris device.
You can also upgrade and delete agents from Skylar One on the Agents page.
The Agents page appears as an option on the Devices menu only when you are using the Skylar One Extended Architecture. If your version of Skylar One does not have an Agents page, see Installing an Agent from the Device Manager Page.
If you are using a Skylar One system with the Skylar One Extended Architecture, you must use the Agents page (Devices > Agents) to install agents, including AIX and Solaris agents. AIX and Solaris agents are not available for non-Skylar One Extended systems.
If you want to remotely install one or more agents, see Remotely Installing a Skylar One Agent.
You do not install the agent from the Agents page itself. Instead, the Agents page enables you to gather the information or files you need to then install the agent on a particular device.
The instructions on the relevant tab of the Agents page also include command line parameters such as URLFRONT, which is used to define the Streamer service you are using as part of the Skylar One Extended Architecture.
If the agent installation is successful, one of the following automatically happens:
  • If the primary IP address of the device is not currently monitored by Skylar One, then Skylar One creates a device record for the device and populates the device record with data provided by the agent. The device record is assigned a device class based on data reported by the agent.
  • If the primary IP address of the device is currently monitored by Skylar One, the device record for the existing device is updated with data provided by the agent.
During initial discovery, the agent returns operating system type and version information to Skylar One. Based on this information, Skylar One assigns the corresponding device classes to a device monitored only by an agent. If a device is monitored by an agent and via SNMP, the device class assigned by SNMP discovery will take precedence.
Installing a Linux Agent
For a Linux system, the Agents page (Devices > Agents) provides version-specific commands that you will need to run on the Linux system you want to monitor. This page includes commands for the following operating systems:
  • Ubuntu and Debian (64-bit)
  • Red Hat and CentOS (64-bit)
  • Red Hat and CentOS - OS Libs (64-bit)
Linux agent version 196 is the minimum version required for Skylar One 12.5.1.
The Linux agent installation program checks for the relevant version of libcurl before installing the agent. If libcurl is not installed, the agent installation program installs the most recent version of libcurl.
Skylar One supports the use of proxy server connections when using the agent on Linux systems. For more information about installing and configuring a Linux agent with a proxy server, see Configuring the Linux Agent to Use a Proxy.
Beginning with Linux Agent version 184, by default the agent will install and run as a dedicated non-root user with the user name "scilog". To run the Linux agent as root, use the installation command which includes RUN_AS_ROOT=1. This configuration has the following limitations:
  • Process data is only Non-Intercepted Process Data (NIPD). There are no intercepts or library data.
  • Polled Data only works for the current user.
  • Log files can only be monitored if they are readable by the scilog user or scilog group.
  • You cannot upgrade the agent from the Skylar One user interface because the installation and uninstallation processes require root privileges.
If you are installing on SELinux, see Using Agents with SELinux.
To install a Linux agent:
  1. On the Agents page (Devices > Agents), click New Agent. The Agent Installation page appears:
    Image of the Install a Linux Agent page
  1. Click the Linux tab at top left.
  2. From the Select an Organization drop-down list, select an organization for the device on which you are installing the agent. The TENANT value in the commands on this page is updated with the Skylar One Organization ID for the organization you selected.
    The URLFRONT value is the URL for the Streamer service you are using as part of the Skylar One Extended Architecture.
  3. Based on the version of Linux running on the device you want to monitor, run the relevant commands from the Linux tab on the Linux device (the "target server"). After the commands complete, the Linux agent starts running in the background. The device on which you installed the agent appears on the Agents page (Devices > Agents), and the device is also added to the list of devices on the Devices page.
You can also install the Linux agent via the command line.
To install the Linux agent (Debian or Ubuntu) using the command line, execute the following command:
sudo TENANT=<organization id> URLFRONT=<streamer_URL> dpkg -i sl_agent.rpm
  • TENANT and URLFRONT are required.
  • The RUN_AS state can be set via command line with RUN_AS_ROOT=<0|1>.
  • The default RUN_AS state is "scilog" when there is no command line RUN_AS_ROOT=X parameter given.
To install the Linux agent (RHEL or CentOS) using the command line, execute the following command:
sudo TENANT=<organization_id> URLFRONT=<streamer_URL> rpm -ivh sl_agent.rpm
The Linux agent supports running in SELinux for CentOS or Red Hat in both permissive and enforcing modes. The RPM installer for Linux will detect if SELinux is active (permissive/enforcing) upon installation. The agent automatically creates and installs an appropriate SELinux policy for use with the agent daemon.
With the Linux Agent, a shared library gets injected into other processes. For non-root processes, this shared library should not generate any errors or audit logs. However, for root processes, this shared library might generate some additional audit logs where some of the shared library functionality is restricted by SELinux. If this is the case, you can update the agent configuration to exclude pre-loading into these root processes.
Installing an AIX Agent
Beginning with AIX agent version 184, by default the agent will install and run as a dedicated non-root system user named "scilog". To run the AIX agent as root, use the installation command which includes RUN_AS_ROOT=1.
For an AIX system, the Agents page provides a set of commands that you will need to run on the AIX system you want to monitor.
AIX agent version 196 is the minimum version required for Skylar One 12.5.1.
To download and install an AIX agent:
  1. On the Agents page (Devices > Agents), click New Agent. The Agent Installation page appears.
  2. Click the AIX tab:
    Image of the Install an AIX Agent page
  3. From the Select an Organization drop-down list, select an organization for the device on which you are installing the agent. The Tenant value in the commands on this page is updated with the Skylar One Organization ID for the organization you selected.
    The URLFront value is the URL for the Streamer service you are using as part of the Skylar One Extended Architecture.
  4. Run the relevant commands from the AIX tab on the AIX device (the "target server"). After the commands complete, the AIX agent starts running in the background. The device on which you installed the agent appears on the Agents page (Devices > Agents), and the device is also added to the list of devices on the Devices page.
You can also install the AIX agent via the command line by executing the following command:
sudo TENANT=<organization_id> URLFRONT=<streamer_URL> rpm -ivh sl_agent_aix.rpm
Installing a Solaris Agent
Beginning with Solaris agent version 184, by defaul the agent will install and run as a dedicated non-root system user named "scilog". To run the Solaris agent as root, add the file /etc/scilog/run_state.txt containing RUN_AS_ROOT=1.
For a Solaris system, the Agents page provides version-specific commands that will need to run on the Solaris system you want to monitor. This page includes commands for the following versions:
  • Solaris 11 - SPARC
  • Solaris 11 - x86_64
  • Solaris 10 - SPARC
  • Solaris 10 - x86_64
Solaris agent version 196 is the minimum version required for Skylar One 12.5.1.
To download and install a Solaris agent:
  1. On the Agents page (Devices > Agents), click the New Agent button. The Agent Installation page appears.
  1. Click the Solaris tab:
    Image of the Install a Solaris Agent page
  2. From the Select an Organization drop-down list, select an organization for the device on which you are installing the agent. The Tenant value in the commands on this page is updated with the Skylar One Organization ID for the organization you selected.
  3. Based on the version of Solaris running on the device you want to monitor, run the relevant commands from the Solaris tab on the Solaris device (the "target server"). After the commands complete, the Solaris agent starts running in the background. The device on which you installed the agent appears on the Agents page (Devices > Agents), and the device is also added to the list of devices on the Devices page.
You can also install the Solaris agent via the command line by executing the following commands:
mkdir -p /etc/scilog && printf "<configuration>\nTenant <organization_id> \nURLFront <streamer_URL>\n<configuration>\n" > scilog.conf && sudo cp scilog.conf /etc/scilog && rm scilog.conf
sudo pkgadd -d silo-agent.pkg
  • The file /etc/scilog/scilog.conf with fields TENANT and URLFRONT are required. Note that "<configuration>" is a valid component of the file content and not meant to be substituted with any company or organizational value.
  • The RUN_AS state can be set by adding file /etc/scilog/run_state.txt with RUN_AS_ROOT=<0|1>.
  • The default RUN_AS state is "scilog" when a /etc/scilog/run_state.txt file doesn't exist.
Installing a Windows Agent
For a Windows system, the Agents page provides an executable file (.exe) that you will need to run on the Windows system you want to monitor.
ScienceLogic provides an executable (.exe) installer called SiloAgent-install.exe. You will need to install and run the SiloAgent-install.exe file on the Windows system you want to monitor.
ScienceLogic also provides an MSI (.msi) installer upon request. The .exe installer is essentially a wrapper around the .msi file that allows for additional checks before installation, unwraps and runs the .msi file, prints information to the terminal, and provides information about failed installations. ScienceLogic recommends you use the .exe installer except for special cases. You can ask your ScienceLogic contact for an .msi file, if needed.
Skylar One supports the use of proxy server connections when using the Skylar One agent on Windows systems. For more information about installing and configuring a Windows agent with a proxy server, see Configuring the Windows Agent to Use a Proxy.
Windows agent version 154 is the minimum required version for Skylar One 12.5.1
To download and install a Windows agent in Skylar One:
  2. Click the Windows tab at top left:
    Image of the Install a Windows Agent page
  3. From the Select an Organization drop-down list, select an organization for the new agent. The Tenant value in the command on this page is updated with the Skylar One Organization ID for the organization you selected.
  4. Click Download Agent. An Opening SiloAgent-install.exe dialog appears.
  5. Save the SiloAgent-install .exe file for installing the agent.
  6. Copy the SiloAgent-install file you downloaded to the Windows system on which you want to run the agent. To do so, you can either go to the console of the Windows system or use a utility like WinSCP.
  7. To install the agent, use Windows PowerShell as an Administrator to run the command on the Windows system (the command is listed in step 2 on the Windows tab on the Agents page):
    .\SiloAgent-install.exe tenant=<organization_id> urlfront=<streamer_URL> RUN_AS_LOCAL_SYSTEM=1
    or
    .\SiloAgent-install.exe tenant=<organization_id> urlfront=<streamer_URL> USER=<user> PASSWORD=<password>
    where <organization_id> is Organization ID for the organization you selected in step 3, and <streamer_URL> is the URL for the Streamer service you are using as part of the Skylar One Extended Architecture.
    .\SiloAgent-install.exe tenant=1 urlfront=streamer2020.int.sciencelogic.com RUN_AS_LOCAL_SYSTEM=1
    RUN_AS_LOCAL_SYSTEM=1 indicates the agent service will run with administrator privileges. USER and PASSWORD designate a dedicated user to run the service. See Configuring the Windows Agent for more information.
  8. When the agent installation completes, the PowerShell window displays "info: install complete", and the Windows agent starts running in the background. The device on which you installed the agent appears on the Agents page (Devices > Agents), and the device is also added to the list of devices on the Devices page.
  9. To verify that the installation was successful, open the Windows Task Manager or enter the TASKLIST command to view running processes. The SiloAgent process will be running on the Windows machine.
When you upgrade to a newer version of the Windows agent, the installer upgrades the agent without generating a new CollectorID. The previous version's configuration file is passed to the upgraded version of the agent. The upgraded Windows agent continues to upload data to the same device record in Skylar One.
Configuring the Windows Agent Using the Command Line
The Windows agent can be configured with two command-line modes, RUN_AS_LOCAL_SYSTEM and RUN_AS_USER. You should choose which command line configuration your device needs. Prior to the Windows agent version 145, the agent was configured with user permissions equal to an administrator user when the agent ran under the Local System user account. For version 145 and later, you can specify any user account as the Windows agent runner. For security purposes, when a non-administrator user account is designated, the agent will have the same permissions and rights as that user account.
Configuring the Windows Agent to Run as Local System
Configuring the Windows agent service to run as a Local System with administrator privileges requires that you include RUN_AS_LOCAL_SYSTEM=1 in your installation command. This configuration is simple, allows the agent to collect many types of data from your device, and guarantees that Dynamic Applications(e.g. PowerShell collections through the agent) execute without issue.
Configuring the Windows Agent to Run as a Dedicated User
Configuring Windows agent service to run as a dedicated user account requires that you specify RUN_AS_USER=1 on the install or upgrade command to indicate that the agent should run as a specific user account. Using this mode allows you to have precise control over the agent permissions and an improved ability to audit agent actions.
Before installing the Windows agent:
  1. Create a Windows user account (local user on the device or domain user) that will be used to run the SiloAgent Service.
  2. Grant the user the exact permissions required to run the agent. Some permissions may be granted as part of the installation command but you may also configure the use before installation.
Using RUN_AS_USER=1 requires additional command-line options that must be configured properly for the agent to collect data and execute actions.
  1. Include USER=<user> in your installation command (required):
    • USER. Defines the user that will run the agent service when using RUN_AS_USER=1. USER may be a username, which indicates a local user account, or it may be in the doman\username form. USER is required for the agent to successfully install with RUN_AS_USER=1. It is not necessary to specify USER during an upgrade except to modify the property.
  2. Include PASSWORD=<password> or PROMPT_FOR_PASSWORD=1. One or the other is required:
    • PASSWORD. Defines the password associated with USER. The password is required to set the USER as the agent's service runner and to add domain accounts to groups.PASSWORD, or PROMPT_FOR_PASSWORD is required if RUN_AS_USER=1 is designated. It is not necessary to specify PASSWORD during an upgrade except to modify the property.
    • PROMPT_FOR_PASSWORD. This property is only available if using the .exe installer. Use PROMPT_FOR_PASSWORD=1 on the command line instead of PASSWORD so that the .exe installer will prompt for a password before starting the installation. The value entered takes the place of PASSWORD. This option can be used to avoid entering plaintext passwords into the command line.
There are additional command line options in your installation command that grant permissions to the account specified by USER.You may want to grant permissions to the USER before the installation for the most control. There are a few permissions that are essential to the agent's central functions and you have the option to grant these during installation.
  • LOG_ON_AS_A_SERVICE. User accounts require the "Log on as a service" user right to run services. LOG_ON_AS_A_SERVICE=1 grants this permission to the user. The agent installation may succeed, but the agent service will fail to start if the USERdoes not have this right.
The "Log on as a service" user right is required to run the the SiloAgent service as a dedicated user. You must either use the LOG_ON_AS_A_SERVICE=1 option, or manually grant the user this right.
  • DEBUG_PROGRAMS. To view the process details of processes owned by other users, a user account must have the required "Debug programs" user right. DEBUG_PROGRAMS=1 grants this right to USER. Without this permission, only processes owned by USER can be monitored.
  • PERFORMANCE_MONITOR_USERS. PERFORMANCE_MONITOR_USERS=1 adds the USER to the Windows group "Performance Monitor Users" which enables the agent to read Windows Performance Counters such as CPU utilization, memory utilization, and disk utilization. This permission is required for the Microsoft Windows PowerShell dynamic applications to work correctly and allows the Windows Management Instrumentation (WMI) queries to execute properly.
  • PERFORMANCE_LOG_USERS. PERFORMANCE_LOG_USERS=1 adds the USER to the Windows group "Performance Log Users" which enables the agent to monitor application events through log monitoring and allows local WMI queries to execute properly.
  • EVENT_LOG_READERS. EVENT_LOG_READERS=1 adds the USER to the Windows group "Event Log Readers" and enables the agent to monitor application events through Log Monitoring.
If neither mode is specified in a new install, the agent will default to RUN_AS_USER=1. If neither mode is specified during an upgrade, the agent will default to the mode already designated. Therefore, any agent running on version 144 and earlier will upgrade to RUN_AS_LOCAL_SYSTEMif not specified in the command line.
Example Install Commands
When installing the agent for the first time on a device running as Local System:
SiloAgent-install.exe TENANT=0 URLFRONT=10.1.1.2 RUN_AS_LOCAL_SYSTEM=1
  1. Tenant and URLFront values must be specified.
    • TENANT. Corresponds to Organization ID in Skylar One. TENANT is required for agent installation. The Windows agent will continue to use the same Tenant value during an upgrade.
    • URLFRONT. The URL or IP for the streamer service. URLFRONT is required for Agent Installation. The Windows agent will continue to use the same URLFront value during an upgrade.
  2. RUN_AS_LOCAL_SYSTEM=1 must be specified.
When installing the agent for the first time on a device running as a dedicated user named "scilogrunner" (local account on the device) with a password "qwerty".
SiloAgent-install.exe TENANT=0 URLFRONT=10.1.1.2 RUN_AS_USER=1 USER=scilogrunner PASSWORD=qwerty
When installing the agent for the first time on a device running as a dedicated user named "MYDOMAIN\scilogrunner" (domain account) on "MYDOMAIN" with password "qwerty".
SiloAgent-install.exe TENANT=0 URLFRONT=10.1.1.2 RUN_AS_USER=1 USER=MYDOMAIN\scilogrunner PASSWORD=qwerty
When installing the agent for the first time on a device running as a dedicated local user named "scilogrunner" with the password "qwerty", and granting the suer the "Log on as a service" user right, the "Debug programs" user right and adding the user to the "Performance Monitor Users" group.
SiloAgent-install.exe TENANT=0 URLFRONT=10.1.1.2 RUN_AS_USER=1 USER=scilogrunner PASSWORD=qwerty LOG_ON_AS_A_SERVICE=1 DEBUG_PROGRAMS=1 PERFORMANCE_MONITOR_USERS=1
  1. Grant the user the "Log on as a service" and "Debug programs" user rights.
  2. Add to the Performance Monitor Users group.
Example Upgrade Commands
When you upgrade the agent installation:
To upgrade an existing agent installation currently running as Local System, you are not required to specify any properties. The properties configured in the previous version are stored and the new version of the agent will continue to run as Local System, using the same Tenant and URLFront.
To upgrade an existing agent installation currently running as a dedicated user, you are not required to specify any properties. The upgraded agent stores the preferences from the previous version. The new version of the agent will continue to run as USER with the same Tenant and URLFront.
To change from a current agent installation running as Local System to a dedicated user during an upgrade, you are not required to provide Tenant and URLFront, but the RUN_AS_USER=1 and USER and PASSWORD must be specified. Once specified, the new version of agent will run as USER.
SiloAgent-install.exe RUN_AS_USER=1 USER=scilogrunner PASSWORD=qwerty
To change from a current agent installation running dedicated user to Local System during an upgrade, you are not required to provide Tenant and URLFront, but RUN_AS_LOCAL_SYSTEM=1 must be specified.
SiloAgent-install.exe RUN_AS_LOCAL_SYSTEM=1
To change the USER and PASSWORD of an existing agent installation, use the same installer and specify the new USER and PASSWORD.
SiloAgent-install.exe USER=scilogrunner_new PASSWORD=different_password
Troubleshooting the Windows Installation Agent
If you experience issues during the installation process, review the example scenarios below.
When an installation fails, a SiloAgent_install_log.txt file is generated in the current directory. If you need to contact ScienceLogic Support, please have that file when you contact them.
The agent installation fails when attempting to install with RUN_AS_USER=1
  • Specify a user account that already exists on the computer or domain.
  • Ensure that either PASSWORD=[password] or PROMPT_FOR_PASSWORD=1 is specified.
  • Ensure that the USER and PASSWORD provided are valid.
  • Ensure that all property names are spelled correctly.
The agent installation succeeds, but the SiloAgent service does not start. If USER and PASSWORD are valid, but USER does not have the"Log on as a service" user right, the installation will succeed but will not start. In this situation, you have two choices:
  • manually grant USER the "Log on as a service" user right and then start the service
  • re-run the installation or upgrade command with LOG_ON_AS_A_SERVICE=1
Please ensure that your USER account or containing groups do not have the "Deny log on as a service" user right. This right supersedes the "Log on as a service" right and will prevent the agent service from starting.
Additional Considerations
Beyond installation errors, there may be other service-related concerns you could experience.
  • The Upgrade button present on the Skylar One agent page sends a simple upgrade command to the Windows agent. The upgraded agent will have the same run-as mode as the previous version. There is currently no way to change USER which runs the agent service from the current Skylar One user interface. The upgrade must be done from the command line.
  • For upgrades from the Skylar One user interface to be successful, the USER must be in the administrator group because administrator access is required for the agent to upgrade itself (i.e. initiating installation of new software). Otherwise, the upgrade must be conducted by an administrator via the command line.
  • Other USER permissions should be limited (e.g. "Deny log on locally" or "Deny Access to this computer from the network").
  • Exercise caution when adding the USER to the administrator group as you are passing administrator credentials during the installation.
  • The USER must have read access to any directories where log file monitoring will occur or the log file monitoring will fail.
  • The USER must have any permissions required to execute PowerShell commands or commands passed by Dynamic Applications or those commands will fail.
  • Additional permissions or configuration may be required for other Dynamic Applications which execute scripts through the agent, such as PowerShell Performance and PowerShell Configuration Dynamic Applications. For example, the "Microsoft: SQL Server" PowerPack applications will not operate correctly unless the USER is granted permissions to the SQL server instance and databases.
Authenticating the Agent
Beginning with Unix Agent version 189 and Windows Agent Version 148, you can configure the Agent to make authenticated requests and uploads to the Skylar One. Skylar One Extended version 12.2.0 can generate tokens for agents, as well as receive authenticated requests from agents with tokens.
Configuring the Streamer
The streamer helm charts provide the tuneable helm variable acceptStaticApiKey. If acceptStaticApiKey is false, the streamer requires the agent to present a valid token and will reject any connection attempts by an agent without a token. If acceptStaticApiKey is not false, the streamer will accept connections from the agents presenting a valid token as well as agent connections where no token has been configured on that device.
Installing an Agent with a Token
To install a new agent that makes authenticated requests, that agent must acquire a valid guid and token. There are two methods to acquire guids and tokens. In both methods, the Skylar One user credential used must have permission to configure agents.
  1. Provide you Skylar One credentials as part of the installation command. The installer will make a request to the Skylar One and acquire a guid and token for the new agent.
  2. While you are logged in to Skylar One, use a GQL mutation to generate a guid and token. Provide the guid and token in the agent installation command.
Upgrading an Existing Agent to an Agent that Supports Tokens
You must upgrade the existing Agent to a version that supports tokens so the agent is able to make authenticated requests. In order to do that, the agent must acquire a token. There are two methods to upgrade an agent and also acquire a token at the same time. In both methods, the Skylar One credential used must have permission to configure agents. Both methods will preserve the existing device record in Skylar One.
  1. Provide your Skylar One credentials as part of the upgrade command. The installer will make a request to the Skylar One and acquire a token for the existing Agent.
  2. While you are logged in to Skylar One, use a GQL mutation to generate a token for the existing Agent. Provide the current guid and the new token in the Agent installation command.
Installing or Upgrading without Tokens
All current installation and upgrade commands continue to work as before. If an agent is not provided with a token, it will continue to attempt requests and uploads as before. Streamers with the tuneable helm variable acceptStaticApiKey not set to false will be able to receive these uploads as before.
Windows Installation Commands (Example)
To authenticate the Windows agent, follow the example on GQL mutations and how to acquire AGENT_GUID and AGENT_TOKEN with GQL. For more information about installation, see Installing a Windows Agent.
New agent installation with AP2_USER and AP2_PASSWORD
SiloAgent-install.exe TENANT=0 URLFRONT=url RUN_AS_LOCAL_SYSTEM=1 AP2_USER=em7admin AP2_PASSWORD=em7admin
New agent installation with AGENT_GUID and AGENT_TOKEN
SiloAgent-install.exe TENANT=0 URLFRONT=url RUN_AS_LOCAL_SYSTEM=1 AGENT_GUID=xxx AGENT_TOKEN=yyy
Upgrading an agent without a token to Windows version 148 or later and acquiring a tokeN with AP2_USER and AP2_PASSWORD
SiloAgent-install.exe AP2_USER=em7admin AP2_PASSWORD=em7admin
Upgrade an agent without a token to Windows version 148 or later and acquiring a token with AGENT_GUID and AGENT_TOKEN
SiloAgent-install.exe AGENT_GUID=<existing CollectorID> AGENT_TOKEN=<acquired token>
Linux Installation Commands-Debian and Ubuntu (Example)
. To authenticate the Linux agent for Debian and Ubuntu, follow the example on GQL mutations and how to acquire AGENT_GUID and AGENT_TOKEN with GQL. For more information about installation, see Installing a Linux Agent.
sudo TENANT=0 URLFRONT=url RUN_AS_ROOT=1 AP2_USER=em7admin AP2_PASSWORD=em7admin dpkg -i sl_agent.rpm
sudo TENANT=0 URLFRONT=url RUN_AS_ROOT=1 AGENT_GUID=xxx AGENT_TOKEN=yyy dpkg -i sl_agent.rpm
Upgrading an agent without a token to Linux version 189 or later and acquiring a tokeN with AP2_USER and AP2_PASSWORD
sudo AP2_USER=em7admin AP2_PASSWORD=em7admin dpkg -i sl_agent.rpm
Upgrade an agent without a token to Linux version 189 or later and acquiring a token with AGENT_GUID and AGENT_TOKEN
sudo AGENT_GUID=<existing CollectorID> AGENT_TOKEN=<acquired token> dpkg -i sl_agent.rpm
Linux Installation Commands-RHEL, CentOs, and AIX (Example)
To authenticate the Linux agent for RHEL and CentOs, follow the example on GQL mutations and how to acquire AGENT_GUID and AGENT_TOKEN with GQL. For more information about Linux installation, see Installing a Linux Agent. For more information about AIX installation, see Installing an AIX Agent.
sudo TENANT=0 URLFRONT=url RUN_AS_ROOT=1 AP2_USER=em7admin AP2_PASSWORD=em7admin rpm -ivh sl_agent.rpm
sudo TENANT=0 URLFRONT=url RUN_AS_ROOT=1 AGENT_GUID=xxx AGENT_TOKEN=yyy rpm -ivh sl_agent.rpm
sudo AP2_USER=em7admin AP2_PASSWORD=em7admin rpm -U sl_agent.rpm
sudo AGENT_GUID=<existing CollectorID> AGENT_TOKEN=<acquired token> rpm -U sl_agent.rpm
Generating GUIDs and Tokens Using GQL
It is possible to generate Agent guids and tokens using GQL, rather than using your Skylar One credentials in the installation or upgrade command. GQL mutations produce guid and token values which can be used as the AGENT_GUID and AGENT_TOKEN properties.
To execute a GQL mutation, you should log in to Skylar One, and navigate to https://<SL1_url>/gql and complete the following steps:
  1. Generate a guid and token for a new Agent device. Substitute the appropriate organization ID (TENANT).
mutation {
createAgentTokenSecret(organization: 0) { #USE DESIRED TENANT HERE
id
agent
jwt
The mutation returns an agent field, which is used as AGENT_GUID, and a jwt field, which is used as AGENT_TOKEN
  1. Generate a token for an existing agent device. An existing agent already as a GUID, also known as the CollectorID. The existing agent's CollectorID can be found in /etc/scilog/scilog.conf (Unix) or C:\Program Files\ScienceLogic\SiloAgent\conf\scilog.conf (Windows).
In the Query Variables panel, enter:
"guid": "<Current CollectorID>"
For the command, enter:
mutation ($guid: ID!) { updateAgentTokenSecret(agent: $guid) { id agent jwt } }
The mutation returns a jwt field, which is used as AGENT_TOKEN. Note that the agent field is the provided CollectorID.
Configuring a Skylar One Agent to Use a Proxy Server Connection
The following section covers how you can configure a proxy server connection when using an agent on Linux or Windows systems.
Configuring a Linux Agent to Use a Proxy
In the scilog_proxy.conf file, you can specify up to four Linux proxy server configurations when installing the agent. If the connection through the primary proxy fails or the proxy is unavailable, the agent will attempt to make the connection through the other specified proxies.
In version 12.3.6 and earlier, you can configure only one proxy server when installing the agent.
To configure the Linux agent to use a proxy server connection:
  1. Create a configuration file named scilog_proxy.conf and add the following proxy information to the new file:
    Proxy-Server
    Proxy-Port
    Proxy-Username
    Proxy-Password
    Proxy-Server2
    Proxy-Port2
    Proxy-Username2
    Proxy-Password2
    Proxy-Server3
    Proxy-Port3
    Proxy-Username3
    Proxy-Password3
    Proxy-Server4
    Proxy-Port4
    Proxy-Username4
    Proxy-Password4
    Primary-Proxy-Check
    The Primary-Proxy-Check value is in minutes. Any value less than "15" will run at 15 minutes, while any value over "15" will run at the interval you specify. If you do not set a value for Primary-Proxy-Check, then the agent will continue to use the primary proxy server until a connection fails; at that point, it will try the next proxy in the list to see if it is successful.
    Proxy-Server 10.1.1.1
    Proxy-Port 8080
    Proxy-Username admin1
    Proxy-Password passw0rd
    Proxy-Server2 10.1.1.1
    Proxy-Port2 8901
    Proxy-Username2 admin1
    Proxy-Password2 passw0rd
    Proxy-Server3 10.1.1.1
    Proxy-Port3 8902
    Proxy-Username3 admin1
    Proxy-Password3 passw0rd
    Proxy-Server4 10.1.1.1
    Proxy-Port4 8903
    Proxy-Username4 admin1
    Proxy-Password4 passw0rd
    Primary-Proxy-Check 60
    The agent requires at least the proxy server and proxy port information. If no authentication is required, leave the username and password commented out with a "#". If values are present for the username and password, the agent will try to use them. The agent currently supports basic authentication.
  2. Add the new file to the /etc/scilog directory on the Skylar One server. This directory is also where the scilog.conf file resides.
    If the scilog_proxy.conf file exists, the agent will try to connect to a proxy. If you do not need a proxy, remove or rename this file to prevent the agent from accessing it. Alternatively, you can leave the parameters blank in the scilog_proxy.conf file.
Installing and Configuring with the Proxy Settings
You can set the proxy parameters at install time by including them as parameters for the install command, just as you do with the Tenant and URLFront values. Use the package name for the package being installed.
deb
sudo TENANT=0 URLFRONT=10.1.1.2 proxyserver=10.2.1.1 proxyport=3128 proxyusername=1 proxypassword=1 dpkg -i sl_agent_v173.15.deb
rpm
sudo TENANT=0 URLFRONT=10.1.1.2 proxyserver=10.2.1.1 proxyport=3128 proxyusername=1 proxypassword=1 rpm -ivh sl_agent_v173.16.rpm
aix
sudo TENANT=0 URLFRONT=10.1.1.2 proxyserver=10.2.1.1 proxyport=3128 proxyusername=1 proxypassword=1 rpm -Uvh scilogd-0.173.17-0.aix7.2.noarch.rpm
If no proxy is used, you can remove the proxy parameters in the install command. Similarly, if a proxy is used without credentials, remove the proxyusername and proxypassword parameters in the install command, and only include the proxyserver and proxyport parameters .
Also note that the Tenant and URLFront values can now be passed on the install command for AIX.
Configuring a Windows Agent to Use a Proxy
In the scilog_proxy.conf file, you can specify up to four Windows proxy server configurations when installing the agent. If the connection through the primary proxy fails or the proxy is unavailable, the agent will attempt to make the connection through the other specified proxies.
To configure the Windows agent to use a proxy server connection:
    Proxy-Server
    Proxy-Port
    Proxy-Username
    Proxy-Password
    Proxy-Server2
    Proxy-Port2
    Proxy-Username2
    Proxy-Password2
    Proxy-Server3
    Proxy-Port3
    Proxy-Username3
    Proxy-Password3
    Proxy-Server4
    Proxy-Port4
    Proxy-Username4
    Proxy-Password4
    Primary-Proxy-Check
    Proxy-Port 8900
    Proxy-Port2 8901
    Proxy-Port3 8902
    Proxy-Port4 8903
    The agent requires at least the proxy server and proxy port information. If no authentication is required, leave the username and password values blank. If values are present for the username and password, the agent will try to use them. The agent currently supports basic authentication. The agent will discover the type of supported authentication, so there is no need to specify it in the configuration file.
  2. Add the new file to the C:\Program Files\ScienceLogic\SiloAgent\conf directory on the Skylar One server. This directory is also where the scilog.conf file resides.
    If the scilog_proxy.conf file exists, the agent will try to connect to a proxy. If you do not need a proxy, remove or rename this file to prevent the agent from accessing it. Alternatively, you can leave the parameters blank in the scilog_proxy.conf file. If you use the .msi installer, you can input the parameters in the dialog box for the installer.
When configuring a proxy password with the above procedure, Skylar One encodes the proxy password in the scilog_proxy.conf file. The password displays as a seemingly random string of characters.
You can manually edit the scilog_proxy.conf file, you can manually enter the proxy password. The agent will still work with a proxy password in plain text. The agent will detect if the setup script encoded the password; otherwise, it assumes the password is in plain text.
Installing and Configuring an Agent with the Proxy Settings
.\SiloAgent-install.exe Tenant=0 URLFront=10.1.1.2 proxyserver=10.2.1.1 proxyport=3128 proxyusername=1 proxypassword=1
If no proxy is used, you can remove the proxy parameters in the install command. Similarly, if a proxy is used without credentials, remove the proxyusername and proxypassword parameters in the install command, and only include the proxyserver and proxyport parameters.
If no parameters are passed to SiloAgent-install.exe, including Tenant and URLFront, a pop-up dialog will appear where you can enter these values. If you do not require proxy credentials, you can leave those values blank.
Upgrading an Agent
When you have the latest version of the Skylar One agent, a check mark icon () appears in the Newest Version column for that agent. If you do no have the latest version of the agent, an Upgrade button appears in the Newest Version column on the Agents page.
To upgrade to the latest version of an agent:
  1. On the Agents page (Devices > Agents), locate the agent you want to upgrade:
    Image of the Agents page with an Upgrade button
  2. Click the Upgrade button for that agent. The agent starts the upgrade process, which might take up to a minute to complete.
  3. Click the Refresh button in your browser to ensure that a check mark icon () appears in the Newest Version column for that agent.
It is not possible to configure the service USER when upgrading through the Skylar One user interface as the agent will continue using the service that USER already uses.
It is also possible to upgrade the agent from device command line.
To upgrade from the Windows command line:
  1. Open the command line as an administrator and run the new .exe installer. It is not necessary to specify Tenant or URLFront values during an upgrade as those parameters carry over.
  2. Change or configure any properties described in Installing a Windows Agent directly in the upgrade command line.
To upgrade with Linux :
Debian or Ubuntu
sudo dpkg -i sl_agent.deb
  • The RUN_AS state can be changed via the command line with RUN_AS_ROOT=1 or by updating the file /etc/scilog/run_state.txt with the same information.
    • The command line option will always take precedence.
    • The default RUN_AS state is "root" when no command line RUN_AS_ROOT=X parameter is given and there is no /etc/scilog/run_state.txt file.
RHEL or CentOS
sudo rpm -U sl_agent.rpm
To upgrade with AIX:
sudo rpm -U sl_agent_aix.rpm
To upgrade with Solaris:
sudo pkgadd -a /usr/share/overwrite.conf -d sl_agent.pkg scilogd
  • The RUN_AS state can be set by adding the file /etc/scilog/run_state.txt with RUN_AS_ROOT=<0|1>.
  • The default RUN_AS state is "root" when no /etc/scilog/run_state.txt file exists.
Upgrades of the same version can be used to change the RUN_AS state.
Stopping an Agent
You can use the "delete" option on the Agents page to stop an agent from running. When you delete an agent, Skylar One stops the agent from running on the device, deletes the data gathered by that agent, and removes that agent from the Agents page.
Using the "delete" option for an agent does not actually remove the agent from the device. As a best practice, use the delete process to delete the data gathered by the agent (the uninstallation process does not delete this data), and then uninstall that agent, if needed. For uninstallation details, see Uninstalling an Agent. Also, ScienceLogic recommends that you delete the device that had the agent installed on it, or at least remove the agent-related Dynamic Applications, to prevent Skylar One from attempting to use the data the agent gathered from that device.
To delete an agent and its data:
  1. On the Agents page (Devices > Agents), locate the agent you want to delete.
  2. Click the Actions button () for that agent and select DeleteSkylar One stops the agent from collecting data.
You can also delete an agent from Skylar One using the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface). Click the checkbox for the device with the agent and select Delete Selected Devices from the Select Action menu at the bottom of the page.
You can also stop an agent through the command line.
To stop an agent on a Linux system (Debian, Ubuntu, RHEL, or CentOS), execute the following command:
sudo service scilogd stop
To stop an agent on an AIX system, execute the following command:
sudo /etc/rd.d/init.d/scilogd stop
To stop an agent on a Solaris system, execute the following command:
sudo svcadm disable scilogd
When you uninstall an agent, you remove that agent completely from Skylar One, but you do not lose the data collected by that agent.
When uninstalling the agent, be sure that the /var/log/jmx-collector and the /temp/scilog directories are removed along with the /var/log/scilogd.log file.
Uninstalling a Linux Agent
To uninstall an agent on a Linux system:
  1. Log in to the Linux system via the console or SSH as a user that has sudo administrator permissions.
  2. For Red Hat, CentOS, and Oracle, execute the following command:
    sudo rpm –e scilogd
  3. For Debian and Ubuntu, execute the following command:
    sudo dpkg -r scilogd
  4. Optionally, you can remove the agent configuration directory from the Linux system. The configuration directory can be found at:
    /etc/scilog (rm -rf /etc/scilog)
Uninstalling an AIX Agent
To uninstall an agent on an AIX system:
  1. Log in to the AIX system via the console or SSH as a user that has sudo administrator permissions.
  2. To determine which package version is currently running, execute the following command:
    sudo rpm –ga|grep -i scilogd
    To determine which package version is running from a previous command, execute the following command:
    sudo rpm –e
  3. Optionally, you can remove the agent configuration directory from the Linux system. The configuration directory can be found at:
Uninstalling a Solaris Agent
To uninstall an agent on a Solaris system:
  1. Log in to the Solaris system via the console or SSH as a user that has sudo administrator permissions.
  2. To uninstall the agent, execute the following command:
    sudo pkgrm scilogd
Uninstalling a Windows Agent
To uninstall an agent on a Windows system:
  1. On the Windows system, open the Control Panel.
  2. Go to the Programs and Features page (Control Panel > Programs > Uninstall a program).
  3. Select the SiloAgent program from the list, and then click Uninstall.
Installing an Agent from the Devices Page or the Device Manager Page
If you are using a distributed Skylar One system without the Skylar One Extended Architecture (which includes Compute Nodes, Storage Nodes, and a Management Node), you must install the agent from the Devices page or from the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface).
If you are not using the Skylar One Extended Architecture, the Agents page (Devices > Agents) will not be available in the Skylar One user interface.
When you install an agent from the Devices page or from the Device Manager page, you will receive different content based on which type of agent you are installing:
  • For a Linux system, the page displays commands that must be executed on that system.
  • For a Windows system, the page provides an executable file to run on the Windows system.
To gather the necessary commands and executable files to install an agent on a device:
  1. Do one of the following:
    • Go to Devices page, then click the down arrow next to the Add Devices button and select Download/Install Agent. The Download/Install Agent modal appears.
    • Go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface), then click Actions and select Download/Install Agent. The Agent Installation modal appears.
  2. On the modal, complete the following fields:
  • Select an OS. Select the operating system running on the device on which you want to install the agent.
  • If you require a FIPS-compliant version of the Skylar One agent, select RedHat/CentOS 64-bit (OS Libs).
  • Select an Organization. Select an organization. The list of organizations is dependent on your user account. If the agent discovers a new device, that device will be associated with the organization you select here.
  • If you are installing an agent on a device that has already been discovered, you must select the organization that is already aligned with the existing device.
  • Select a Message Collector. Select the Message Collector to which the agent will send its collected data.
  1. If you selected a Linux operating system in the Select an OS field, the modal displays a list of commands to execute on the Linux system. Copy the commands for use during the installation on the Linux device.
  2. If you selected a Windows operating system in the Select an OS field, the modal displays a Download Windows Agent link. Click the link and save the executable file for use during the installation on the Windows device.
If you are installing an agent on multiple devices that run the same operating system, are part of the same organization, and connect to the same Message Collector, you can re-use the same commands or executable file on each of those devices.
Installing an Agent on a Linux System
To install an agent on a Linux system:
Copy and execute the appropriate commands from the Agent Installation page to download and install the agent. For more information, see Installing a Linux agent for details about install commands.
NOTE: Skylar One supports the use of proxy server connections when using the Skylar One agent on Linux systems. To do so, open a command window on the target server and first configure curl to use a proxy server using the CURLOPT_PROXY option, and then to use a username and password combination for that proxy server using the CURLOPT_PROXYUSERPWD option.
Upgrading an Agent on a Linux System
To upgrade the agent on a Linux system:
When using the classic Skylar One user interface, agents must be upgraded from the device command line. For more information, see Upgrading an Agent.
Installing an Agent on a Windows System
To install an agent on a Windows system:
  1. Copy the SiloAgent-install.exe file you downloaded from the Agent Installation page to the Windows system.
  2. Execute the appropriate command copied from the Agent Installation page to install the agent. For more details about install commands see Installing a Windows Agent.
Skylar One supports the use of proxy server connections when using the Skylar One agent on Windows systems. In Windows 10, go to Settings > Network & Internet > Proxy to set up a proxy; in older versions of Windows, you can do this by clicking on the Control Panel and going to Internet Options > Connections > LAN Settings. If a proxy server requires authentication, you will need to provide a username and password before traffic is allowed through the proxy server and to the Internet.
Configuring a Skylar One Agent to Work with Phone Home Collectors
If you are using PhoneHome Message Collectors in a Distributed Architecture, you will need to configure the settings for the Message Collector to prevent Skylar One from incorrectly configuring the Skylar One agent to use the loopback IP address when it should be using the local IP address for the Message Collector.
If you do not perform the configuration steps below, when you try to install the agent from a Message Collector when it is configured as a PhoneHome Collector, the URLs for both the download and the internal configuration of the agent reference the loopback address instead of the accessible public/private IP address of the Message Collector.
For more information about PhoneHome Collectors, see Configuring Skylar One for PhoneHome Communication.
To configure the Skylar One agent to work with a PhoneHome Collector:
  2. In the Message Collector row, click the Agent Endpoint Configuration icon () for the agent. The Agent Endpoint Configuration modal appears.
  3. Make sure that the configuration information under the Appliance Details field is accurate.
  • Download Link Visibility. Select whether you want to display the download link in the Agent Installation modal page.
    • If you select Enabled, the link to the Message Collector appears on the Agent Installation modal, which is available on the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface) when you click the Actions button and select Download/Install Agent.
    • If you select Disabled, the link to the Message Collector does not appear in the Agent Installation modal.
  • Endpoint Name for Download Link. This field contains the name of the Message Collector. If the name is not populated by default, you can enter the name.
  • Hostname/IP for Agent Download. Make sure that this field contains the IP address for the Message Collector.
  • Hostname/IP for Data Collection. Enter the IP address for the Message Collector.
  • Default CUG Alignment. Select the Collector Group aligned with the agent.
  1. Click Save. The agent is now configured to work with a Message Collector when it is configured as a PhoneHome Collector.
This section covers how to configure remote installations of the Linux agent and the Windows agent.
The following procedures are examples of how you could set up these installations, using Ansible as the tool for the installation. You might use Ansible in a different way, or you might use another tool altogether. These examples represent just one way to configure the remote installation of agents.
Remotely Installing a Linux Agent
This topic provides an example of how you can use Ansible to remotely install the Skylar One Linux agent. Please refer to the Ansible product documentation as needed.
To remotely install the Linux agent using Ansible:
  1. Set up your Ansible control node, using the documentation at Installing Ansible.
  2. Download the Skylar One Linux agent installers from the Agents page (Devices > Agents > New Agent button) in Skylar One. For example:
    • silo-agent-x86_64.rpm
    • silo-agent-x86_64.deb
  3. Create the hosts.yml file, using the following code as an example:
    servers:
      hosts:
        centos_host:
          ansible_host: 172.16.54.195
          ansible_user: root
        debian_host:
          ansible_host: 10.2.16.125
          ansible_user: root
  1. Create the playbook.yml file, using the following code as an example:
    - hosts: servers
      vars:
        tenant: 0
        url_front: 10.2.16.49
        package_rpm: silo-agent-x86_64.rpm
        package_deb: silo-agent-x86_64.deb
      tasks:
      - name: check if agent exists
        stat:
          path: /usr/bin/scilogd
        register: agent_binary
      - name: copy rpm installer
        copy:
          src: "{{ package_rpm }}"
          dest: ~/{{ package_rpm }}
        when: (agent_binary.stat.exists == False and ansible_facts['os_family'] == 'RedHat')
      - name: copy deb installer
        copy:
          src: "{{ package_deb }}"
          dest: ~/{{ package_deb }}
        when: (agent_binary.stat.exists == False and ansible_facts['os_family'] == 'Debian')
      - name: install rpm agent
        shell: TENANT={{ tenant }} URLFRONT={{ url_front }} rpm -ihv ~/{{ package_rpm }}
        args:
          creates: /usr/bin/scilogd
      - name: install deb agent
        shell: TENANT={{ tenant }} URLFRONT={{ url_front }} dpkg -i ~/{{ package_deb }}
        args:
      - name: remove rpm installer
        file:
          path: ~/{{ package_rpm }}
          state: absent
      - name: remove deb installer
        file:
          path: ~/{{ package_deb }}
          state: absent
  1. Run the playbook by executing the following command:
    ansible-playbook playbook.yml -i hosts.yml --ask-pass
    This example uses the --ask-pass parameter so that you are prompted for a single password to use with all remote computers.
    The following code is an example of the output:
    $ ansible-playbook playbook.yml -i hosts.yml --ask-pass
    SSH password:
    PLAY [servers] ********************************************************************************************
    TASK [Gathering Facts] ************************************************************************************
    ok: [centos_host]
    ok: [debian_host]
    TASK [check if agent exists] ******************************************************************************
    ok: [centos_host]
    ok: [debian_host]
    TASK [copy rpm installer] *********************************************************************************
    skipping: [debian_host]
    changed: [centos_host]
    TASK [copy deb installer] *********************************************************************************
    skipping: [centos_host]
    changed: [debian_host]
    TASK [install rpm agent] **********************************************************************************
    TASK [install deb agent] **********************************************************************************
    TASK [remove rpm installer] *******************************************************************************
    TASK [remove deb installer] *******************************************************************************
    PLAY RECAP ************************************************************************************************
    centos_host                : ok=5    changed=3    unreachable=0    failed=0    skipped=3    rescued=0    ignored=0
    debian_host                : ok=5    changed=3    unreachable=0    failed=0    skipped=3    rescued=0    ignored=0
Remotely Installing a Windows Agent
This topic provides examples of how you can use the PowerShell console or Ansible to remotely install the Skylar One Windows agent. Please refer to the PowerShell or Ansible product documentation as needed.
To remotely install the Windows agent using InstallSoftwareRemotely.ps1:
  1. Download the  Windows Agent installer from the Agents page (Devices > Agents > New Agent button) in Skylar One and add the installer to your domain-controller n its own directory. For example, C:\files\SiloAgent-install.exe.
  2. Download the third-party PowerShell script to your domain-controller.
  3. Create a comma-separated value (CSV) file with the names of the computers where you want to install the agent. For example: C:\computers.csv, such as:
    rstlsw12t16ls01
    rstlsw12t16ex01
    computer3
    computer99
  4. Run the following command from a PowerShell console:
    .\InstallSoftwareRemotely.ps1 -CSV C:\computers.csv -AppPath 'C:\foo\SiloAgent-install.exe' -AppArgs "Tenant=<organization_id> urlFront=<streamer_URL> RUN_AS_LOCAL_SYSTEM=1"
    • -CSV uses the full path to the .csv file you created in step 3, above.
    • -AppPath uses the full path to the installer in step 1, above. Make sure the file is in its own directory.
    • RUN_AS_LOCAL_SYSTEM=1 is an example configuration. See Configuring the Windows Agent for more information.
    • You can optionally use the -Credential option to be prompted for a different username and password to access all remote machines. Otherwise the script will use your current login account to access all remote machines.
PS C:\> .\InstallSoftwareRemotely.ps1 -CSV C:\computers.csv -AppPath 'C:\foo\SiloAgent-install.exe'
-AppArgs "Tenant=0 URLFront=streamer-shared-e2e-testing.int.sciencelogic.com"
Start remote installation on 2020-56-20 09:56:17
No credential specified. Using logon account
Attempt 1 of 5
COMPUTER RSTLSW12T16LS01 (1 of 2)
Coping C:\foo to \\rstlsw12t16ls01\C$\temp
Installing SiloAgent-install.exe on RSTLSW12T16LS01
Executing C:\temp\foo\SiloAgent-install.exe Tenant=0 URLFront=streamer-shared-e2e-testing.int.sciencelogic.com
Deleting C:\temp\foo
SiloAgent-install.exe installed successfully.
COMPUTER RSTLSW12T16EX01 (2 of 2)
Coping C:\foo to \\rstlsw12t16ex01\C$\temp
Installing SiloAgent-install.exe on RSTLSW12T16EX01
100% Success installing SiloAgent-install.exe on 2 of 2 computers:
rstlsw12t16ls01 rstlsw12t16ex01
To remotely install the Windows agent using Ansible:
  1. Set up your Ansible control node. Refer to Ansible documentation for installing on other operating systems: Installing Ansible with pip.
  2. Update your Ansible control node to manage Windows servers by running the following command:
    sudo pip3 install pywinrm
  3. Ensure that remote machines are set up with PowerShell 3 or later:
    https://github.com/jborean93/ansible-windows/blob/master/scripts/Upgrade-PowerShell.ps1
  4. Ensure that remote machines are setup for Windows Remote Management:
    https://github.com/ansible/ansible/blob/devel/examples/scripts/ConfigureRemotingForAnsible.ps1
  5. Download the Skylar One Windows agent installer, SiloAgent-install.exe, from the Agents page (Devices > Agents > New Agent button) in Skylar One.
  1. Create the hosts.yml file, using the following code as an example:
    group1:
      hosts:
        win2008r2:
          ansible_host: 10.2.16.41
          ansible_user: Administrator
        win2012:
          ansible_host: 10.2.16.42
        win2012r2:
          ansible_host: 10.2.16.40
    group2:
      hosts:
        dc01:
          ansible_host: 10.2.16.60
          ansible_user: administrator@T16TESTDOMAIN
        ls01:
          ansible_host: 10.2.16.62
        es01:
          ansible_host: 10.2.16.64
  1. Create the my_playbook.yml file, using the following code as an example:
    - hosts: group1
      gather_facts: no
      tasks:
      - name: Ping Windows Hosts
        win_ping:
      - name: Copy agent installer
        win_copy:
          src: ./SiloAgent-install.exe
          dest: C:\Temp\SiloAgent-install.exe
      - name: Exec Installer
        win_command: C:\Temp\SiloAgent-install.exe Tenant=yyy URLFront=zzz
      - name: Remove agent installer
        win_file:
          path: C:\Temp\SiloAgent-install.exe
          state: absent
  2. Run the playbook by executing the following command:
    This example uses the --ask-pass parameter so that you are prompted for a single password to use with all remote computers. Alternately, you could include the password in hosts.yml or ./group_vars/all.yml.
[em7admin@jkay88 demo_ansible]$ ansible-playbook my_playbook.yml -i hosts.yml --ask-pass
SSH password:
PLAY [group1] *********************************************************************************************************
TASK [Ping Windows Hosts] *********************************************************************************************
ok: [win2012]
ok: [win2008r2]
TASK [Copy agent installer] *******************************************************************************************
changed: [win2012]
changed: [win2012r2]
changed: [win2008r2]
TASK [Exec Installer] *************************************************************************************************
changed: [win2012]
PLAY RECAP *************************************************************************************************************
win2008r2                  : ok=3    changed=2    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
win2012                    : ok=3    changed=2    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
win2012r2                  : ok=3    changed=2    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
