The following sections provide an overview of Silver Peak and the Silver Peak PowerPack:
What is Silver Peak?
Silver Peak is an SD-WAN management solution that captures data and information from the Silver Peak Unity Orchestrator about devices connected through Unity EdgeConnect. Users can measure the performance and availability of these devices and the connected network, which helps determine potential service delivery issues and maintain compliance.
What Does the Silver Peak PowerPack Monitor?
To monitor Silver Peak using SL1, you must install the Silver Peak PowerPack. This PowerPack enables you to discover, model, and collect data about Silver Peak Unity Orchestrator and devices connected via Unity EdgeConnect.
The Silver Peak PowerPack includes:
- A sample credential you can use as a template to create SOAP/XML credentials to connect to the Unity Orchestrator you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics, and to collect configuration data for Unity Orchestrator and connected devices
- Device Classes for each of the Silver Peak devices that SL1 monitors
- Event Policies and corresponding alerts that are triggered when New Relic services meet certain status criteria
- A device template for Silver Peak Unity Orchestrator
- A dashboard that displays key metrics for each device
Installing the Silver Peak PowerPack
