Updating SL1
This section provides an overview of the System Updates page, detailed steps for performing an SL1 upgrade, and detailed steps on upgrading MariaDB, upgrading PowerPacks, and performing reboots.
As of version 12.2.0, SL1 can be deployed only on Oracle Linux 8 (OL8) operating systems. If you are upgrading from a version of SL1 prior to 12.1.1 that does not already run on OL8, you must first upgrade to SL1 12.1.1 or 12.1.2 and then convert to OL8 before upgrading to SL1 12.2.0 or later.
Depending on the version of SL1 that you are currently running, you might be required to upgrade to one or more earlier versions of SL1 before you can upgrade to 12.2.0 or later.
For more information about supported upgrade paths, see the upgrade notes included in the SL1 release notes for the release you want to upgrade to as well as the OL8 Conversion Resource Center on the ScienceLogic Support portal, which includes links to numerous resources such as the Oracle Linux 8 Conversion Guide. The conversion guide includes prerequisites, full instructions for converting to OL8 for all deployment types, FAQs, and other helpful information to walk you through the OL8 conversion process.
UPDATE: The deadline to convert SL1 platforms to Oracle Linux 8 operating system has been extended to January 30, 2025.
If you take no action, all SL1 systems with OL7 will continue to run, but ScienceLogic will not support them, and the systems may not be secure.
The SL1 system update process supports Python 3.
The System Updates Page
The System Updates page (System > Tools > Updates) allows you to update the software on your SL1 appliances.
You must first download the update file to the local computer. You can then import the software update through the user interface.
After you import a software update to your SL1 system, the SL1 system can automatically stage the software update. Staging is when the software is copied to each ScienceLogic appliance. Staging allows SL1 to simultaneously apply the software changes to each ScienceLogic appliance, regardless of the speed of the connection to each ScienceLogic appliance. You can allow the SL1 system to automatically stage the software or you can manually stage the software.
After the software update is staged, you can run preupgrade checks and then deploy the software.
To apply updates to an existing Data Collector, that Data Collector must be a member of a Collector Group. In some SL1 systems, users might have to create a Collector Group for a single Data Collector before applying updates.
To conserve disk space on Data Collectors and Message Collectors, after an update, SL1 removes previous Docker images.
The System Updates page displays a list of deployed updates and the date and time each update was applied. The following information displays for each update in the list:
  • EM7 Version. Displays the version number for each SL1 patch that has been imported (and optionally staged and deployed) to the SL1 system. SL1 releases include new features and address issues with previous releases.
  • OS Version. Displays the version number for each platform patch that has been imported (and optionally staged and deployed) to the SL1 system. Platform patches include updates to the ScienceLogic operating system, including newer versions of industry-standard packages.
  • Update Signature. Name of the entity that released the patch and type of patch. Usually "ScienceLogic Official Release".
  • Imported On. Date and time the software update was loaded onto the SL1 system.
  • Imported By. SL1 user who loaded the software update onto the SL1 system.
  • Import Status. Status of the import process. Clicking on the log icon displays the log file associated with importing the selected software. Possible values are:
    • In Progress. Software is currently being imported by the system.
  • Staging Status. Status of the staging process. Clicking on the log icon displays the log file associated with staging the selected software. Possible values are:
    • --. No staging request is active and software has not been staged on any SL1 appliances.
    • Scheduled. SL1 is aware of the staging request and is preparing for staging.
    • In Progress. Staging is in progress but has not completed.
    • Cancelled. User manually cancelled the staging process.
    • Failed. An unexpected error occurred in the staging process. Contact ScienceLogic Support for assistance.
    • If a software update has been set to manually stage, the Staging Status column will include an asterisk (*).
  • Preupgrade Status. Status of the preupgrade checks. Possible values are:
    • --. No preupgrade checks are active.
    • Complete. Preupgrade checks have completed successfully.
    • Incomplete. Preupgrade checks have not yet completed.
    • Failed. An unexpected error occurred in the preupgrade checks. Contact ScienceLogic Support for assistance.
  • Deployment Status. The current deployment state. Possible values are:
    • --. No deployment request is active and software has not been deployed on any SL1 appliances.
    • Scheduled. SL1 is aware of the deployment request and is preparing for deployment.
    • Incomplete. Deployment has completed, and one or more appliances are updated.
    • Cancelled. User manually canceled the deployment.
    • Failed. An unexpected error occurred in the deployment process. Contact ScienceLogic Support for assistance.
  • Deployment Status Date. Specifies the date and time the software update was last deployed.
From the System Updates page, you can also click the Appliance List button to view a list of appliances in your SL1 stack. The following information displays for each appliance in the list:
  • Appliance Name. The name assigned to the SL1 appliance.
  • IP. The appliance's IP address.
  • mid. The appliance's module ID.
  • Module Type. The SL1 appliance type.
  • Build. The version of SL1 currently running on the appliance.
  • MariaDB. The version of MariaDB currently running on the appliance.
  • Platform. The current operating system platform version for the appliance.
  • Task Manager Paused? Indicates whether the task manager service is paused.
  • Patch Eligible. Indicates if the appliance is eligible for patching.
  • Patch Enabled. Indicates if patching is enabled or disabled for the appliance.
    To enable or disable patching for an appliance, select the checkbox for that appliance on the Appliance List modal, select Enable Selected Appliances or Disable Selected Appliances from the Select Action menu, and then click Go.
The Workflow for Updating SL1
The following sections describe the steps to plan and deploy an SL1 update. If would like assistance planning an upgrade path that minimizes downtime, please contact your Customer Success Manager.
The workflow for updating SL1 is:
  1. Plan the update.
  3. Review pre-upgrade best practices for SL1.
  4. Back up SSL certificates.
  5. Set the timeout for PhoneHome Watchdog. (Only required if upgrading from SL1 11.1.x or earlier.)
  6. Run the Pre-Upgrade Test for PhoneHome Database Servers. (Only required if upgrading from SL1 11.1.x or earlier.)
  7. Adjust the timeout for slow connections.
  8. Run the system status script on the Database Server or All-In-One before upgrading.
  9. Update the SL1 Distributed Architecture using the System Update tool.
  10. Upgrade MariaDB, if needed.
  11. Reboot SL1 appliances, if needed.
  12. Upgrade to Aurora 3 RDS (MySQL 8.0). (Only required if deployed on AWS and currently on Aurora 2.)
  13. Restore SSL Certificates.
  14. Reset the timeout for PhoneHome Watchdog.
  15. Update default PowerPacks.
  16. Configure Subscription Billing (one time only).
The option to enable a Military Unique Deployment (MUD) configuration is not available for SL1 12.1.x or 12.2.0 installations or upgrades.
Planning the Update
Before upgrading SL1, perform the following steps that are specific to your organization:
  • What is fixed?
  • What is new?
  • What has changed?
  • What has been deprecated?
  • What are the supported upgrade paths?
  • What are the important notes that you need to know before upgrading?
  1. Read the Known Issues for the release. These can be found in the release notes and at https://support.sciencelogic.com/s/known-issues.
  2. Identify all integrations and third-party applications that access the SL1 database or manipulate data on SL1. Determine how to disable these integrations during the deployment and re-enable after deployment.
  3. Identify activities and customers that will be affected by maintenance windows and schedule and inform appropriately.
  4. Identify custom work (PowerPacks, Run Book Automations, Event policies, Dashboard widgets) and ensure that it is backed up so you can restore it if necessary.
Ensure that the each SL1 node or appliance has at least 4 GB of free space in the /var partition for pre-upgrade and deployment. Ensure that each SL1 node or appliance has at least 1 GB of free space in / (the root partition) to allow you to deploy the upgrade; however, depending on the appliance type and version you are upgrading from, you might need up to 3 GB of free space in / (the root partition).
If you are upgrading from a version of SL1 prior to version 8.10.0, see Updating SL1 Appliances to Oracle Linux.
Upgrading SL1 includes a minimum of two and possibly four maintenance windows:
  • Import and stage update and run the pre-upgrade script. These steps can take place prior to the day of upgrade and do not affect SL1 functionality. ScienceLogic suggest you perform these steps at least three days before the planned upgrade and ideally a week before the planned upgrade.
  • Deploy update. On the day of the upgrade, put all SL1 appliances in maintenance mode. The SL1 system will not be available during this procedure. Update the SL1 Distributed systems.
  • Update MariaDB (if required). The SL1 system will not be available during this procedure. Refer to the release notes for your current release to determine if you must upgrade MariaDB.
  • Reboot Appliances (if required). Individual SL1 appliances will not be available during these procedures. Refer to the release notes for your current release to determine if you must reboot all SL1 appliances after upgrading.
Identify activities and users that will be affected by these maintenance windows, and schedule the maintenance windows appropriately. Be sure to communicate all downtime with users.
Pre-Upgrade Best Practices for SL1
  • Review the hardware specifications of all the appliances in your system to ensure they meet the requirements for the current usage of your system. For more details about sizing and capacity for your specific environment, contact your Customer Success Manager and see https://support.sciencelogic.com/s/system-requirements.
  • Verify that recent backups are available for your system.
  • Ensure that each SL1 appliance has a valid license.
  • Ensure that a Data Collector is a member of a Collector Group if you are applying updates to an existing Data Collector. In some SL1 systems, users might have to create a Collector Group for a single Data Collector.
  • Ensure that each Data Collector is listed as "Available" to the Database Server. To check, see the Collector Status page (System > Monitor > Collector Status).
Backing Up SSL Certificates
  2. Open a shell session and type the following commands at the shell prompt:
  3. Repeat these steps on each Database Server in your SL1 system.
Setting the Timeout for PhoneHome Watchdog
This section applies to users who are upgrading from SL1 11.1.x or earlier and have an existing PhoneHome configuration. If you are upgrading from SL1 11.2.0 or later or you do not have a pre-11.2.0 PhoneHome configuration, you can ignore this section.
You can manually adjust the settings for the PhoneHome Watchdog server to reduce CPU consumption during the upgrade process. To do this:
    phonehome watchdog view
    Current settings:
    autosync: yes
    interval: 20
    state: enabled
    autoreconnect: yes
    timeoutcount: 2
    check: default
  5. To change the settings for SL1 upgrade, type the following at the command line:
Running the Pre-Upgrade Test for PhoneHome Database Server
When upgrading to SL1 version 11.2.0 or later, a pre-upgrade test in the system update procedure checks for existing PhoneHome Database Servers. Specifically, this test looks for PhoneHome token IDs inside the /home/phonehome0/config.json file, and fails if the value of the id field is less than or equal to "0".
In versions of SL1 prior to version 11.2.0, the primary PhoneHome Database Server was not self-registered with a token, causing it to have an id value of "0".
Therefore, if you are currently using a version of SL1 prior to version 11.2.0 and you are using PhoneHome communication with your SL1 Collectors, you or your SL1 administrator must complete the following one-time manual configuration steps prior to upgrading to version 11.2.0 or later.
Do not attempt to upgrade to SL1 version 11.2.0 or above until all pre-upgrade tests are successful on all PhoneHome Database Servers.
  1. Log in to the console of the Database Server or use SSH to access the server.
  2. To determine if your PhoneHome Database Server is registered, type the following command and locate its id value:
  3. If a PhoneHome Database Server has an id value of "0", type the following command and locate the id of the current appliance:
    phonehome status
  4. Type the following command and locate the PhoneHome token:
  5. Type the following command to register the PhoneHome token:
  6. Repeat steps 2-5 for all PhoneHome Database Servers that have an id value of "0".
  7. Type the following command to ensure that all of your PhoneHome Database Servers are synced:
    phonehome sync
  8. Repeat step 2 and confirm that all Database Servers have id values greater than "0".
After you have downloaded but not yet installed the ISO, you can also go to the System Updates page (System > Tools > Updates) and check the Preupgrade Status column to determine if the upgrade has successfully passed the pre-upgrade test. If the Preupgrade Status is Incomplete, click the magnifying glass icon () to determine which appliance is failing during the pre-upgrade test. Do not install the upgrade until the Preupgrade Status status displays as Complete.
Adjusting the Timeout for Slow Connections
If you have slow connections between SL1 appliances, you can adjust the timeout values for staging and deploying upgrades.
To adjust the timeouts:
  2. Open a shell session and type the following at the shell prompt:
    <timeout_in_seconds> is the timeout value, in seconds, for staging for each SL1 appliance. The default value is 1800 seconds (30 minutes). You can increase this value for slow connections.
  3. Type the following at the shell prompt:
    <timeout_in_seconds> is the timeout value, in seconds, for deploying to each SL1 appliance. The default value is 3600 seconds (1 hour). You can increase this value for slow connections.
If you are upgrading from a version of SL1 prior to version 8.14.0, see Adjusting the Timeout for SL1 8.12 and Prior Releases.
SL1 includes a script, system_status.sh, that provides diagnostic data for each node or appliance in your SL1 system.
On SL1 systems prior to 10.2.0, after running the system status script, you must ensure that the file /var/lob/em7/silo.log has the owner and group "s-em7-core".
If you are running SL1 version SL 8.14.0 or later, SL1 automatically runs the system status script every 15 minutes on each node or appliance in your SL1 system.
ScienceLogic recommends that you view the output from the system status script before upgrading:
  1. In SL1, go to the Appliance Manager page (System > Settings > Appliances).
  2. Locate the SL1 appliance that you want to view diagnostic information about.
  4. If the output includes errors and you need help fixing them, contact ScienceLogic Customer Support to fix the errors before upgrading.
  5. Repeat for each node or appliance in your SL1 system.
To get the very latest status before upgrading, manually run the system status script on each Database Server or All-In-One Appliance.
If you are upgrading from an SL1 8.12.x system, see Running the System Status Script on SL1 8.12.x Releases. If you are upgrading from an SL1 8.10.x or prior release, see Running the System Status Script on SL1 8.10 and Prior Releases.
Updating the SL1 Distributed Architecture
Any SL1 Distributed Architecture system running 8.6.0 or later can be upgraded by importing, staging, and deploying a single update file.
Upgrading the SL1 Distributed Stack includes the following steps:
Database Servers and Data Engines in your SL1 stack are deployed first; other appliance types cannot be deployed until the Database Servers and Data Engines are finished deploying.
If you are upgrading from an SL1 system between 8.1.1 and 8.5.0, see Upgrading the SL1 Distributed Architecture on SL1 Versions 8.5.0 and Earlier.
If you are currently running an SL1 version prior to 8.12.0, you must go to the System Updates page and disable automatic staging (System > Tools > Updates > Actions > Disable automatic staging).
If you have previously used manual staging, you must also perform these additional steps:
  1. Select all updates in the EM7 Releases pane and select all updates in the ScienceLogic OS pane.
Downloading the Update
Before you can load a patch or update onto your instance of the SL1 system, you must first download the patch or update to your local computer.
The following steps do not affect the performance of the SL1 system. ScienceLogic recommends that you perform these steps at least three days before upgrading.
  1. Log in to https://support.sciencelogic.com. Use your ScienceLogic customer account and password to access this site.
  2. From the SL1 Product Downloads menu, select SL1 Platform. The Platform Downloads page appears.
  3. Find the release you are interested in and click its name. The Release Version page appears.
  4. Click the specific link for a release, if needed.
  5. Click the link for the release image or release patch you want to download, and click the Download File button. The file is then downloaded to your local computer.
Importing the Update
To import a product update on to your SL1 system:
  1. In the SL1 system, go to the System Updates page (System > Tools > Updates).
  2. In the System Updates page, click the Import button.
  3. In the Import a new update modal page, browse to the product update file and select it.
  • If you select the Auto Stage button, the SL1 system will begin staging as soon as the import is completed.
  1. Click the Import button.
  2. In the System Updates page, the Import Status column can have one of the following statuses:
  • In Progress. Software is currently being imported by the SL1 system.
  • Missing Base. The SL1 system cannot import this software until another software package has been imported. The dependency is for compression purposes. Check the log for a message stating which software package needs to be imported.
  1. The update file or patch file is imported to SL1 system and appears in the System Updates page.
Staging the Update
After you import a software update to your SL1 system, you must stage the software update. During staging, the SL1 system copies the software update to each SL1 appliance. Staging allows SL1 to simultaneously apply the software changes to each SL1 appliance, regardless of the speed of the connection to each SL1 appliance. The SL1 system stages updates per import. You can choose to automatically stage imports or manually stage import.
A staging mode called "enhanced file upload" enables pre-staging operations and file upload operations to happen in separate worker processes, which does not count file upload time toward the "staging wait time" setting. This mode is enabled by default, and ScienceLogic recommends that you keep it enabled due to the large amount of data that needs to be pushed for SL1 updates. However, if you prefer to update this setting, you can make the following changes in the "master.system_settings_patcher" table:
  • To change the number of file upload workers (12 by default), insert or update the following parameter:
    param="num_file_upload_workers" and value="<number of workers>"
  • To change the number of pre-staging workers (25 by default), insert or update the following parameter:
    param="pool_size" and value="<number of workers>"
  • To disable enhanced file upload mode, insert or update the following parameter:
    param="use_enhanced_file_upload" and value="0"
The Staging Status column on the System Updates page can have one of the following statuses:
  • Scheduled. The SL1 system is aware of the staging request and is preparing for staging.
For details on the staging process, go to the System Updates page, find the entry for the software you are interested in, go to its Staging Status column, and click the log icon ().
Automatic Staging
To enable automatic staging:
  1. In SL1, go to the System Updates page (System > Tools > Updates).
  3. In the Import a new update modal page, browse to the product update file and select it. If you select the Auto Stage button, the SL1 system will begin staging as soon as the import is completed.
  1. After import, in the System Updates page, the Staging Status column will display the number of ScienceLogic appliances that have been successfully stage compared to the total number of ScienceLogic appliances
To disable automatic staging:
  4. If you do not select the Auto Stage button, you must click the staging button () after import is completed. You can do so at any time after import has completed.
Manually Staging an Update
You can manually stage a software update:
  • If you add another ScienceLogic appliance to your SL1 system and need to apply software updates.
When you manually stage a software update, SL1 checks the status of the software updated on each ScienceLogic appliance. SL1 then stages the software update only to those SL1 appliances that have not yet been staged for this software update.
  2. Locate the software update you want to stage and click its staging icon (). The software update will be copied to each ScienceLogic appliance that has not yet been staged.
Monitoring Staging
For SL1 versions 8.12.0 and later, you can monitor the staging process:
  2. Type the following at the shell prompt:
    monitor_stage
    You should see something like the following image:
  3. In the monitor_stage results, look for the following information:
  • Staging Process Stats. Displays status of staging on all SL1 appliances.
Running the Pre-Upgrade Check
If you are upgrading from SL1 8.14 or earlier, see Running the Pre-Upgrade Check for SL1 8.14 or Earlier.
  • Is each SL1 Appliance eligible to be updated?
  • Are updates enabled on each SL1 Appliance?
  • Are any of the SL1 Appliances running CentOS 5?
  • Is this hostfile on each SL1 Appliance correctly configured?
  • Are the CRM templates on High Availability and Disaster Recovery systems out of date?
  • Does /etc/init.d/mysql exist? (If it does not, it creates the file.)
The pre-upgrade check skips any SL1 appliances that have been deleted since the last upgrade.
To run a pre-upgrade check:
  2. Find the upgrade that you want to deploy.
  3. Click the purple checkmark at the end of the row. The pre-upgrade check will run.
  4. If a pre-upgrade criterion fails, the Deploy button will be disabled for the selected row.
  5. To view the output from the pre-upgrade check, click on the on the magnifying-glass icon () in the selected row.
  6. If the pre-upgrade check finds a failure, see the list below for possible causes.
  7. Fix all failures before deploying the update.
Potential Issues to Address
CentOS 5 Failure
Collector Group Membership
Eligibility Failure
  • The SL1 appliance is not licensed or the license has expired
  • The SL1 appliance cannot be reached over the network
  • The SL1 appliance is not configured
Enabled Failure
By default, all SL1 appliances are enabled for patching.
However, if you have used a command-line tool to exclude an SL1 appliance from updates, the pre-upgrade check will fail. To fix this error, include the SL1 appliance for updates.
Free Disk-Space Failure
Host File Failure
Check the following in case of failure:
  • The /etc/hosts file exists
Patch-Hook Ownership Failure
RPM Database Failure
To recover the RPM database:
    mkdir -p /tmp/rpm.bak
    rm -f /var/lib/rpm/__db*
    rpm --rebuilddb -vv
    rpm -q kernel
    rm -Rf /tmp/rpm.bak
RPM Package Failure
  • Duplicate packages
  • Conflicting packages
  • Unmet dependencies
Duplicate Packages:
    sudo package-cleanup --dupes
Conflicting Packages
  2. Verify that the package is a part of SL1 ISO or patch bundle
  3. If the package is not part of the SL1 ISO or patch bundle, uninstall the package.
Unmet dependencies
You will need to reset the staging status of the appliance and stage it again. Contact ScienceLogic Customer Success for help in resetting the staging status.
Putting All SL1 Appliances into Maintenance Mode
Immediately before deploying a software update, ScienceLogic recommends that you put all SL1 appliances in maintenance mode. This will prevent spurious error messages and events during the deployment.
To enable user maintenance mode for all the SL1 appliances in your SL1 system:
  1. Go to the Appliance Manager page (System > Settings > Appliances). Note the list of SL1 appliances in your system.
  2. Go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic SL1 user interface) and select the checkbox for each SL1 appliance in your SL1 system. This includes both primary and secondary Database Servers.
  3. In the Select Action drop-down list, select Change User Maintenance Mode: Enabled without Collection. This option puts the selected devices into user maintenance mode with collection disabled. The devices will remain in this state until you or another user disables user maintenance mode.
  4. Click the Go button.
Deploying the Update
  • Running integrations and third-party applications that access the SL1 database or manipulate data on SL1
  • Running discovery sessions
  • Running nightly discovery
  • Adding new SL1 Appliances
  • Importing a new patch
  • Run reporting jobs
When you deploy an update, the update is installed on all nodes or appliances that have already been staged.
When you deploy an update, SL1 checks to ensure that you have already deployed all required updates. If you have not, SL1 will generate an error message specifying the updates you must deploy before continuing with the current update.
During deployment, the Deployment Status column on the System Updates page can have one of the following statuses:
  • --. No deployment request is active, and software has not been deployed on any SL1 appliances.
  • Scheduled. The SL1 system is aware of the deployment request and is preparing for deployment.
To deploy a software update on your nodes or appliances:
  2. Go to the System Updates page (System > Tools > Updates).
  3. In the System Updates page, find the software update you want to deploy. Click the lightning bolt icon () to deploy the software. If SL1 is still staging the patch when you click the lightning-bolt icon (), SL1 will wait until staging has completed before deploying the updates to each ScienceLogic appliance.
  4. The software update will be deployed to all appliances in your SL1 system that have already been staged. If one or more appliances in your SL1 system have been successfully staged, SL1 will deploy the update to those appliances.
For details on the deployment process, go to the System Updates page, find the entry for the software you are interested in, go to its Deployment Status column, and click the log icon ().
Troubleshooting System Update
These tools can be useful when System Update does not work as expected, or if you have issues with the PhoneHome configuration or with communication between appliances and the Database Server. These tools are available on all SL1 appliances starting with SL1 version 10.2.0, and the tools are backwards-compatible to SL1 version 8.12.0.
  1. Either go to the console of any SL1 appliance or use SSH to access the appliance
    sudo sysuptb -h
    sudo sysuptb <argument> -h
Available Commands
  • Example:
    sudo sysuptb all
    Executing filestore tests
    RPM database is intact
    Filestore has 1026 files
    No yum processes found
    If you do not provide the name of a service, the command searches the logs for errors for siloupdate-pkgserver.service and siloupdate-spool.service.
  • Example:
  • The following command removes deleted SL1 appliances from the history of system updates so that they SL1 does not search for them during update.
    sudo sysuptb clear-mids
  • Example:
    sudo sysuptb clear-schedule
  • Example:
    sudo sysuptb filestore
  • Example:
    912 / 912 [-----------------------------------------------------------] 100.00% 14 p/s
  • Example:
    If you do not specify a service, the command examines the service siloupdate-manager.service. Starting with SL1 12.1.0, siloupdate-manager.service replaced em7_patch_manager.service.
  • Example:
    sudo sysuptb hosts
  • Example:
    sudo sysuptb hosts
  • Example:
    sudo sysuptb rpmdb
  • Example:
    sudo sysuptb rpmdb
  • Example:
    sudo sysuptb yum-proxy
  • Example:
  1. Either go to the console of an SL1 appliance using PhoneHome communication or use SSH to access the appliance.
    sudo phtb -h
    sudo phtb <argument> -h
Available Commands
    sudo phtb destination
    sudo phtb probe-host
    sudo phtb proxy
Monitoring Deployment
To monitor the deployment process:
    monitor_deploy
  • Deployment Process Stats. Displays status of deployment on all SL1 appliances.
Installing Additional RPMs on an SL1 Appliance
For certain patch releases, ScienceLogic might require additional RPMs to be installed on specific appliance types. If an RPM install is required, the release notes will indicate the additional RPMs to install on each specific appliance type.
To install additional RPMs on an appliance, perform the following steps:
  1. Download the RPM files provided by ScienceLogic to your local machine.
  2. Log in as root at the appliance console.
  3. Copy each of the downloaded RPM files to the appliance. To copy the downloaded files, perform the following command as root at the console of the appliance:
  4. scp <username-on-local-machine>@<ip-address-of-your-local-machine>:<full-path-to-rpm-on-your-local-machine> <full-path-on-appliance-to-copy-to>
  5. Use the following command to run the RPM installer for each of the RPM files:
  6. rpm -U <name-of-rpm-file>.rpm
  7. If you have not yet done so, apply the latest patch to your SL1 system.
Remove SL1 Appliances from Maintenance Mode
To disable user maintenance mode for all the SL1 appliances in your SL1 system:
  1. Go to the Appliance Manager page. Note the list of SL1 appliances in your system.
  3. In the Select Action drop-down list, select Change User Maintenance Mode: Disabled. This option disables user maintenance mode for the selected devices.
Also refer to the release notes for your current release to determine if you must reboot all SL1 appliances after upgrading.
Updating SL1 Extended Architecture
New installations of SL1 Extended Architecture are available only on SaaS deployments.
For existing on-premises deployments of SL1 Extended Architecture, see the section on Upgrading SL1 Extended Architecture.
Automatically Upgrading MariaDB
Most SL1 updates require you to upgrade MariaDB after you update SL1. Refer to the release notes for your patch release to determine if you must upgrade MariaDB.
Newer SL1 releases use the command siloupdate upgrade-mariadb to upgrade the MariaDB server. This command also updates MariaDB-client, MariaDB-common, and MariaDB-shared RPMs in addition to the MariaDB Server RPM.
Older versions of SL1 use the module_upgrade_mariadb script to upgrade MariaDB rather than the command siloupdate upgrade-mariadb that is described in this section. For more information, see the section on Using the module_upgrade_mariadb Script in Older Versions of SL1.
You should store all custom configuration settings for each MariaDB database in the file /etc/siteconfig/mysql.siteconfig. If you have added custom settings to the file /etc/my.cnf.d/silo_mysql.cnf, those changes will be overwritten each time you upgrade MariaDB. Before upgrading, copy any custom settings to the file /etc/siteconfig/mysql.siteconfig. SL1 will save these custom settings and apply them after you upgrade MariaDB.
The siloupdate upgrade-mariadb command:
  • Upgrades the following SL1 appliances:
  • All Database Servers
  • All-In-One Appliances
  • Data Collectors
  • Message Collectors
  • Will skip SL1 appliances that have already been updated
  • Stores log files in /data/logs/module_upgrade_mariadb.log and /data/logs/.upgrade_mariadb.log
To upgrade MariaDB in newer versions of SL1, perform the following steps:
    To upgrade all modules, you can use the command siloupdate upgrade-mariadb -m all.
  3. To see all the options for the siloupdate upgrade-mariadb command, enter the following command at the shell prompt:
    siloupdate upgrade-mariadb -h
SL1 will automatically update MariaDB-client, MariaDB-common, and MariaDB-shared RPMs but will not update the MariaDB Server RPM. You must update the MariaDB Server RPM after you install the SL1 update.
Older SL1 releases include the module_upgrade_mariadb script to automatically upgrade the MariaDB server.
Refer to the release notes for your current release to determine if you must upgrade MariaDB. Not every SL1 update requires an upgrade of for MariaDB.
Newer versions of SL1 use the command siloupdate upgrade-mariadb to upgrade MariaDB rather than the module_upgrade_mariadb script that is described in this section. If you attempt to use the older command on a newer version of SL1 that no longer supports it, you will get a deprecation message telling you to use the newer command.
The module_upgrade_mariadb script:
  • Data Collectors
To upgrade MariaDB in older versions of SL1, perform the following steps:
    sudo /opt/em7/bin/module_upgrade_mariadb  -m all
  3. To see all the options for the module_upgrade_mariadb script, enter the following command at the shell prompt:
    /opt/em7/bin/module_upgrade_mariadb -h
    Usage:
    module_upgrade_mariadb -m <module_id> [-t|--test] [-y|--assumeyes] [-s|--skip_conf_file_error][-p|--pool size <number_of_modules>][-h|--help]
  4. The script includes these options:
    • -m parameter specifies the SL1 appliances that you want to upgrade. You can specify:
    • -m <mid1, mid2…midN> provides a comma-separated module IDs.
    • -m all : upgrade all appliances (Database Servers, All-In-One Appliances, Data Collectors, and Message Collectors).
    • -m all -db : upgrade all Database Servers.
    • -m all-cu : upgrade all Data Collectors and Message Collectors.
    • -t parameter specifies not to upgrade but instead to run a test of the upgrade script.
    • -y parameter specifies to automatically enter "yes" at all prompts.
    • -s parameter specifies to ignore errors in the MySQL configuration files and proceed with the upgrade.
    • -p parameter specifies the number of Data Collectors that you want to upgrade simultaneously. Database Servers will be upgraded one at a time. Possible values are 1 - 20. The default value is 1.
    • -p <number_of_modules> is the number of Data Collectors to upgrade simultaneously. Values are 1 - 20. The default value is 1.
  5. To view the status of the automatic upgrade, enter the following command:
    monitor_upgrade_mariadb
Additional Steps for MariaDB Upgrades in SL1 10.1.x
SL1 10.1.x included an upgrade to MariaDB. The upgrade did not include a tool, jemalloc, that helps manage memory usage.
  • 10.1.0
  • 10.1.1
  • 10.1.2
  • 10.1.3
  • 10.1.4
  • 10.1.4.1
  • 10.1.4.2
  • 10.1.5
  • 10.1.5.1
    Variable Name Value
    version_malloc_library system
  4. Search for the file /usr/lib64/libjemalloc.so.1. If the file does not exist, contact ScienceLogic Customer Support to request the file jemalloc-3.6.0-1.el7.x86_64.rpm.
    cd /usr/lib64
    [Service]
  7. Save and close the file.
    sudo systemctl daemon-reload
      coro_config
    2. Select 1.
      crm resource restart mysql
      sudo rm /tmp/.proc_mgr_pause
      coro_config
    8. Select 1.
    Variable Name Value
Manually Upgrading MariaDB
Refer to the release notes for your current release to determine if you must upgrade MariaDB. Not every SL1 update requires an upgrade of MariaDB.
ScienceLogic strongly recommends that you upgrade MariaDB using the script described in Automatically Upgrading MariaDB with a Script.
If you prefer to upgrade MariaDB manually, the following sections describe how to upgrade the MariaDB server for different SL1 appliance types and architectures.
When you update MariaDB, you must update the following SL1 appliances:
  • Data Collectors
Download RPMs to SL1 Appliances
Before upgrading MariaDB, you must copy the RPMs from the primary Database Server to the Database Servers, All-In-One Appliances, Data Collectors, and Message Collectors in your SL1 system. To do this.
  2. To download the latest RPMs from the Database Server, enter the following at the shell prompt:
    For SL1 version 10.1.0 to 10.1.5:
    wget --output-document /tmp/MariaDB-server-10.4.12-1.el7.centos.x86_64.rpm http://localhost:10080/MariaDB-server.rpm
    wget --output-document /tmp/galera-4-26.4.3-1.rhel7.el7.centos.x86_64.rpm http://localhost:10080/galera-4.rpm
    For SL1 version 10.1.6 and higher, download all of the packages listed when you enter the command:
    cat /opt/em7/share/db_packages
    wget --output-document /tmp/MariaDB-server.rpm http://localhost:10080/<mariadb-server-pkg-from-db_packages>
    wget --output-document /tmp/galera-4.rpm http://localhost:10080/<galera-4-pkg-from-db_packages>
    wget --output-document /tmp/socat.rpm http://localhost:10080/<socat-pkg-from-db_packages>
  3. Verify if the downloaded packages are valid (not corrupt or incomplete downloads) by entering the following commands:
    rpm -qip /tmp/MariaDB-server.rpm
    rpm -qip /tmp/galera-4.rpm
    rpm -qip /tmp/socat.rpm
    If any errors are reported, try restarting siloupdate-pkgserver, using the following command, and retry downloading and verifying the RPM files again.
    systemctl restart siloupdate-pkgserver
  4. Use SCP or another secure copy program to copy these files to the /tmp directory on each Database Server, All-In-One Appliance, Data Collector, and Message Collector:
    • MariaDDB-server.rpm
    • galera-4.rpm
    To conserve disk space, ScienceLogic recommends you delete the RPMs from the /tmp directory the on the Database Servers, All-In-One Appliances, Data Collectors, and Message Collectors in your SL1 system after you successfully upgrade MariaDB.
Manually Upgrade Two Database Servers Configured for High Availability or Disaster Recovery
To upgrade a High Availability or Disaster Recovery cluster, perform the following steps:
The system will be unavailable when performing these steps.
Step 1: On the Secondary Database Server
You must put the secondary Database Server in maintenance mode. To do this:
  2. At the shell prompt, assume root privileges:
    sudo -s
  3. When prompted, enter the administrator password.
  4. At the shell prompt, enter the following command:
    coro config
    The following menu appears:
    1) Enable Maintenance
    2) Option Disabled
    3) Promote DRBD
    4) Stop Pacemaker
    5) Resource Status
    6) Quit
  5. Enter "1".
Step 2: On the Primary Database Server
  1. To determine the current installed version of the RPMs, enter the following command:
    sudo rpm -qa ^MariaDB-*
  2. To stop SL1 and MariaDB, enter the following commands at the shell prompt:
    sudo systemctl stop em7
    sudo systemctl stop mariadb.service
  3. To stop the MySQL resource, enter the following command:
    sudo crm resource stop mysql
  4. To save the current enabled state for mariadb.service, enter the following command:
    export MSRV='sudo systemctl is-enabled mariadb.service'
  5. Check the version of MariaDB-server that you are running.
    rpm -q MariaDB-server
  6. You must follow the steps below that correspond to your version of MariaDB. Step 6 is specific to MariaDB-server version 10.1.x, while Step 7 is specific to MariaDB-server versions 10.4.12 and higher.
  7. MariaDB-server version 10.1.x. If you are running MariaDB-server version 10.1.x:
  8. Do these steps in order. Doing the steps in any other order will result in unintended consequences.
    1. Remove MariaDB-server by using the following commands:
      sudo rpm --nodeps -ev MariaDB-server
    2. Replace the Galera package and install the new MariaDB-server package by using the following commands:
      sudo yum --disablerepo=* swap -- remove galera -- install /tmp/galera-4.rpm
      sudo yum --disablerepo=* install /tmp/MariaDB-server.rpm
  9. MariaDB-server version 10.4.12 and higher. If you are running MariaDB-server version 10.4.12 or higher, upgrade the MariaDB-server package and dependent packages (galera-4 and socat) by using the following commands:
    sudo yum --disablerepo=* install /tmp/galera-4.rpm /tmp/socat.rpm
    sudo yum --disablerepo=* upgrade /tmp/MariaDB-server.rpm
  10. To remove incompatible backup packages, enter the following command:
    sudo yum remove percona-xtrabackup
  11. NOTE: If the "yum remove" command fails, it means that the package does not exist on the SL1 appliance. You can ignore the error message.
  12. To regenerate the configuration file for MariaDB, enter the following command:
    sudo /opt/em7/share/scripts/generate-my-conf.py -f -o /etc/my.cnf.d/silo_mysql.cnf
  13. To re-start MariaDB, enter the following command:
    sudo systemctl start mariadb
  14. To restart the MySQL resource, enter the following command:
    sudo crm resource start mysql
  15. To restore the mariadb.service enabled state, enter the following command:
    sudo systemctl ${MSRV::-1} mariadb.service
  16. To upgrade the internal configuration for the database, enter the following:
    sudo mysql_upgrade -u root -p
  17. To restart the em7 service, enter the following commands:
    sudo systemctl start em7
Step 3: On the Secondary Database Server
  1. Determine the current installed version of the RPMs using the following command:
  2. To save the current enabled state for mariadb.service, enter the following:
    export MSRV=`sudo systemctl is-enabled mariadb.service`
  3. Check the version of MariaDB-server that you are running.
  4. You must follow the steps that correspond to your version of MariaDB. Step 4 is specific to MariaDB-server version 10.1.x, while Step 5 is specific to MariaDB-server versions 10.4.12 and higher.
  5. MariaDB-server 10.1.x: If you are running MariaDB-server version 10.1.x:
  6. Do these steps in order. Doing the steps in any other order will result in unintended consequences.
    1. Remove MariaDB-server by using the following command:
  7. MariaDB-server 10.4.12 or higher: If you are running MariaDB-server version 10.4.12 or higher, upgrade the MariaDB-server package and dependent packages (galera-4 and socat)by using the following commands:
  8. To remove incompatible backup packages, enter the following command:
  9. NOTE: If the "yum remove" command fails, it means that the package does not exist on the SL1 appliance. You can ignore the error message.
  10. To regenerate the configuration file for MariaDB, enter the following command:
  11. To restore the mariadb.service enabled state, enter the following command:
  12. To take the secondary Database Server out of maintenance mode, enter the following command at the shell prompt:
    sudo -s
  13. When prompted, enter the administrator password.
  14. At the shell prompt, enter the following command:
    coro config
    The following prompt appears:
    1) Disable Maintenance
    2) Option Disabled
    3) Promote DRBD
    4) Stop Pacemaker
    5) Resource Status
    6) Quit
  15. Enter "1".
Manually Upgrade Three Database Servers Configured for High Availability and Disaster Recovery
To upgrade a High Availability/Disaster Recovery cluster, perform the following steps:
    sudo -s
    coro config
  5. The following prompt appears:
    2) Option Disabled
    3) Promote DRBD
    4) Stop Pacemaker
    5) Resource Status
    6) Quit
  6. Enter "1".
  1. Determine the current installed version of the RPMs:
  2. Stop SL1 and MariaDB using the following commands:
  3. Stop the MySQL resource:
  4. Save the current enabled state for the mariadb.service:
  5. Check the version of MariaDB-server that you are running:
  6. You must follow the steps that correspond to your version of MariaDB.
  9. MariaDB-server version 10.4.12 and higher. If you are running MariaDB-version 10.4.12 or higher, upgrade the MariaDB-server package and dependent packages (galera-4 and socat) by using the following commands:
  10. Remove incompatible backup packages:
  12. Regenerate the configuration file for MariaDB:
    sudo /opt/em7/share/scripts/generate-my-conf.py -o -f  /etc/my.cnf.d/silo_mysql.cnf
  13. Restart MariaDB:
  14. Restart the MySQL resource:
  15. Restore the mariadb.service enabled state:
  16. Upgrade the internal configuration for the database:
  17. Restart the em7 service:
  1. Save the current enabled state for the mariadb.service:
  2. Check the version of MariaDB-server that you are running:
  3. You must follow the steps that correspond to your version of MariaDB.
  4. MariaDB-server version 10.1.x. If you are running MariaDB-server version 10.1.x:
  5. Do these steps in order. Doing the steps in any other order will result in unintended consequences.
    1. Remove MariaDB-server:
  6. MariaDB-server version 10.4.12 and higher. If you are running MariaDB-version 10.4.12 or higher, upgrade the MariaDB-server package and dependent packages (galera-4 and socat) by using the following commands:
  7. Remove incompatible backup packages:
  8. NOTE: If the "yum remove" command fails, it means that the package does not exist on the SL1 appliance. You can ignore the error message.
  9. Regenerate the configuration file for MariaDB:
  10. Restore the mariadb.service enabled state:
  11. Assume root privileges:
    sudo -s
  12. When prompted, enter the administrator password.
  13. At the shell prompt, enter the following command:
    coro config
  14. The following prompt appears:
    2) Option Disabled
    3) Promote DRBD
    4) Stop Pacemaker
    5) Resource Status
    6) Quit
  15. Enter "1".
Step 4: On the Disaster Recovery Database Server
  1. Open an SSH session to the Disaster Recovery Database Server.
  2. Assume root privileges:
    sudo -s
  13. Restore the mariadb.service enabled state:
Manually Upgrading Standalone Database Servers, All-In-One Appliances, Data Collectors, and Message Collectors
To upgrade MariaDB on one or more Database Servers that are not configured for high availability or disaster recovery, a single All-In-One Appliance, one or more Data Collectors, or one or more Message Collectors, perform the following steps:
The Database Server, All-In-One Appliance, Data Collector, or Message Collector will be unavailable when performing these steps.
  1. Go to the console or open an SSH session to the SL1 appliance.
  2. Stop SL1 and mariadb:
  3. Save the current enabled state for the mariadb.service:
  4. Check the version of MariaDB-server that you are running:
  5. You must follow the steps that correspond to your version of MariaDB.
  6. MariaDB-server version 10.1.x. If you are running MariaDB-server version 10.1.x:
  7. Do these steps in order. Doing the steps in any other order will result in unintended consequences.
  8. MariaDB-server version 10.4.12 and higher. If you are running MariaDB-version 10.4.12 or higher, upgrade the MariaDB-server package and dependent packages (galera-4 and socat) by using the following commands:
  9. Remove incompatible backup packages:
  10. NOTE: If the "yum remove" command fails, it means that the package does not exist on the SL1 appliance. You can ignore the error message.
  11. Regenerate the configuration file for MariaDB:
  12. Restart MariaDB:
  14. Upgrade the internal configuration for the database:
  15. Restart the em7 service:
  16. Repeat all the steps in this section on each non-HA/DR Database Server, All-In-One Appliance, Data Collector, and Message Collector.
Additional Steps for MariaDB Upgrades in 10.1.x
  • 10.1.0
  • 10.1.1
  • 10.1.2
  • 10.1.3
  • 10.1.4
  • 10.1.4.1
  • 10.1.4.2
  • 10.1.5
  • 10.1.5.1
    Variable Name Value
    cd /usr/lib64
    [Service]
      coro_config
    2. Select 1.
      coro_config
    8. Select 1.
    Variable Name Value
Rebooting Appliances in the SL1 Distributed Stack
Refer to the release notes for your current release to determine if you must reboot all SL1 appliances. Not every SL1 update requires rebooting.
When an upgrade requires a reboot, use the steps listed in this section to reboot all SL1 appliances in the Distributed stack.
If your SL1 system includes multiple Administration Portals, you can remotely reboot Administration Portals from another Administration Portal. To do so:
  2. Select the checkboxes for the SL1 appliances you want to reboot.
If your SL1 system include only a single Administration Portal, perform the following steps to reboot that Administration Portal:
  4. where:
From the SL1 user interface, perform the following steps to reboot a Data Collector or a Message Collector:
  2. Select the checkbox for each SL1 appliance you want to reboot.
  4. where:
  1. Either go to the console or use SSH to access the SL1 appliance.
  3. On the SL1 appliance, pause the system and shutdown MariaDB.
  4. Reboot the SL1 appliance:
    sudo reboot
  5. After the SL1 appliance has rebooted, either go to the console or use SSH to access the SL1 appliance.
  7. Un-pause the SL1 Appliance:
  1. Either go to the console of the primary Database Server or use SSH to access the primary Database Server.
  3. Check the status of both Database Servers. To do this, enter the following at the shell prompt:
    cat /proc/drbd
    ns:17567744 al:0 bm:1072 lo:0 pe:0 ua:0 ap:0 ep:1 wo:b oos:12521012
  4. Pause the system and shutdown MariaDB on the primary Database Server. Enter the password for the em7admin user when prompted:
    sudo systemctl stop pacemaker
  5. Reboot the primary Database Server:
    sudo reboot
  6. After the primary appliance has rebooted, log in to the console of the primary Database Server again.
  7. Execute the following command on the primary Database Server:
    coro_config
  8. Select the Promote DRBD option.
  9. Execute the following commands on the primary Database Server:
  10. Enter the password for the em7admin user and confirm the command when prompted.
  11. Log in to the secondary Database Server as the em7admin user using the console or SSH.
  12. Execute the following command on the secondary Database Server to reboot the appliance:
    sudo reboot
  13. Enter the password for the em7admin user when prompted.
  1. Either go to the console of the secondary Database Server or use SSH to access the secondary Database Server.
    cat /proc/drbd
  4. 1: cs:Connected ro:Secondary/Primary ds:UpToDate/UpToDate C r----
    If your output includes "ro:Secondary/Primary", but does not include "UpToDate/UpToDate", data is being synchronized between the two appliances. You must wait until data synchronization has finished before rebooting.
  5. Stop the cluster service on the secondary Database Server:
  6. Enter the password for the em7admin user when prompted.
  7. Either go to the console of the primary Database Server or use SSH to access the primary Database Server.
  8. Log in as em7admin with the appropriate password.
  9. Pause the system and stop the cluster service on the primary Database Server. Enter the password for the em7admin user when prompted:
  10. Reboot the primary Database Server:
    sudo reboot
  11. After the primary Database Server has rebooted, either go to the console of the primary Database Server or use SSH to access the primary Database Server.
  12. Log in as em7admin with the appropriate password.
  13. Execute the following command on the primary Database Server:
  14. Enter the password for the em7admin user and confirm the command when prompted.
  15. Either go to the console of the secondary Database Server or use SSH to access the secondary Database Server.
  16. Log in as em7admin with the appropriate password.
  17. Reboot the secondary Database Server:
    sudo reboot
  18. Enter the password for the em7admin user when prompted.
  1. Either go to the console of the secondary Database Server in the HA cluster or use SSH to access the secondary  Database Server in the HA cluster,
  3. Check the status of both Database Servers in the HA cluster. To do this, enter the following at the shell prompt:
    cat /proc/drbd
  4. 10: cs:Connected ro:Secondary/Primary ds:UpToDate/UpToDate C r----
  5. Stop the cluster service with the following command on the secondary Database Server in the HA cluster:
  7. Either go to the console of the primary Database Server in the HA cluster or use SSH to access the primary Database Server in the HA cluster.
  9. Pause the system and stop the cluster service on the primary Database Server in the HA cluster :
  10. Enter the password for the em7admin user when prompted
  11. Reboot the primary Database Server in the HA cluster:
    sudo reboot
  12. After the primary Database Server in the HA cluster has rebooted, either go to the console of the primary Database Server in the HA cluster or use SSH to access the primary Database Server in the HA cluster.
  13. Execute the following command on the primary Database Server in the HA cluster:
  15. Either go to the console of the secondary Database Server in the HA cluster or use SSH to access the secondary Database Server in the HA cluster.
  17. Reboot the secondary Database Server in the HA cluster:
    sudo reboot
  19. Either go to the console of the Database Server for Disaster Recovery or use SSH to access the Database Server for Disaster Recovery.
  20. Log in as em7admin with the appropriate password.
  21. Reboot the Database Server for Disaster Recovery:
    sudo reboot
  22. Enter the password for the em7admin user when prompted.
Upgrading to Aurora 3 RDS (MySQL 8.0)
This section applies only to users who deploy SL1 on AWS and are currently running on Aurora 2 RDS (MySQL 5.7). If you do not deploy SL1 on AWS or you are already running on Aurora 3, you can skip this section.
If you deploy SL1 using AWS, you are currently running on Aurora 2 RDS (MySQL 5.7), and are upgrading to SL1 12.1.2, you can upgrade to Aurora 3 RDS (MySQL 8.0).
Aurora 3 upgrades are not supported for SL1 12.2.x.
Before You Upgrade to Aurora 3
Before you upgrade to Aurora 3, you must have already done the following:
  • Ensured that you have administrator access to the AWS data engines, RDS, and IAM from the AWS console.
  • Already upgraded SL1 to a version that supports Aurora 3.
  • Created an RDS snapshot.
  • Created an Ansible AWX instance using the "ScienceLogic SL1 Deployment - AWX V5" AMI.
    To obtain this AMI, contact ScienceLogic Support.
  • Logged in to the AWX instance using credentials provided by ScienceLogic.
  • Created a jump host using AWX, if you do not already have one.
  • Updated the deploy, em7admin, and jump host credentials with the correct information.
  • Updated the DE01 and jump host IP addresses.
Performing the Aurora 3 Upgrade
To upgrade to Aurora 3:
  1. Ensure that your SL1 appliances are in maintenance mode.
  2. Log in to your AWX instance using the credentials provided by ScienceLogic.
  3. Run the "AWS - RDS Aurora3 Upgrade" job with the following input:
    aws_region:
    client:
    vpc_id:
  4. After the playbook has executed successfully, verify that your database and application perform the post-application validation check.
Restoring the SSL Certificates
  2. Open a shell session.
  4. Repeat these steps on each Database Server in your SL1 system.
This section applies to users who are upgrading from SL1 11.1.x or earlier and have an existing PhoneHome configuration. If you are upgrading from SL1 11.2.0 or later or you do not have a pre-11.2.0 PhoneHome configuration, you can ignore this section.
    phonehome watchdog view
    Current settings:
    autosync: yes
    interval: 120
    state: enabled
    autoreconnect: yes
    timeoutcount: 1
    check: default
    Note the settings for interval and timeoutcount, so you can restore them after the upgrade.
  3. To change the settings for SL1 upgrade, type the following at the command line:
Updating Default PowerPacks
ScienceLogic includes multiple PowerPacks in the default installation of SL1. When you apply an update to your system, new versions of the default PowerPacks will be automatically imported in to your system. If a PowerPack is included in an update and is not currently installed on your system, SL1 will automatically install the PowerPack. If a PowerPack is included in an update and is currently installed on your system, SL1 will automatically import (but not install) the PowerPack.
To install the updates for multiple PowerPacks
  1. Go to the PowerPack Manager page (System > Manage > PowerPacks) and click the checkbox for each PowerPack you want to install.
  2. In the Select Action drop-down field (in the lower right), choose Update PowerPack(s). SL1 displays a warning message before updating the PowerPack(s).
  3. Click the OK button to continue the installation.
  4. Click the Go button. If you completed the update, updated information about the PowerPack will appear in the PowerPack Manager page. All the items in the PowerPack will be installed in your SL1 system.
NOTE: If the Enable Selective PowerPack Field Protection checkbox on the Behavior Settings page (System > Settings > Behavior) is selected, certain fields in Event Policies, Dynamic Applications, and Device Classes will not be updated.
If your SL1 system is configured to communicate with the ScienceLogic billing server, usage data will be sent automatically from your SL1 system to the ScienceLogic billing server once a day. After the ScienceLogic billing server receives the usage data, SL1 will automatically mark the license usage file as delivered.
Sending usage data to the ScienceLogic billing server ensures that your bill is accurate and that ScienceLogic can continue making improvements to the SL1 products.
  • Go to the System Usage page (System > Monitor > System Usage) or (Manage > Subscription Usage). Click the Subscription button and choose License Data Delivery Status.
  • For air-gapped SL1 systems, the value of Summary Date should be within the past 48 hours.
  • For SL1 systems that connect to ScienceLogic, the value of Summary Date should be within the past 48 hours and the value of Delivery Status is 1.
