Cherwell Service Management (CSM) is a low-code, no-code tool where you can manage the CMDB, track the life cycle of assets, manage changes, and manage incidents and requests. You can use the "Cherwell" SyncPack to manage the Federated CMDB integration between CSM and SL1.
The following graphic provides an overview of the various workflows available in the "Cherwell" SyncPack:
The "Cherwell" SyncPack lets you manage the Federated CMDB integration between Cherwell Service Management (CSM) and ScienceLogic (SL1).
Using this SyncPack, you can perform the following integrations between CSM and SL1:
- Incident Creation and Update Sync
- Configuration Item (CI) Creation and Update Sync
- Maintenance Window Sync
- Retirement of CIs from SL1 and CSM
Terminology
The following table lists the names and definitions of the various elements in SL1 and Cherwell:
| Name | Definition |
| Blueprint | An XML file that contains configuration information; these files can be shared between different CSM instances |
| Business object | Provides a view for the user for objects like CIs, federated relationships, federated field mappings, and federated CI mappings |
| CI | Configuration Item in CSM, also known as a "Device" in SL1 |
| CR | Change Request |
| CSM | Cherwell Service Management |
| CSM Administrator client | The CSM administration application, typically depicted by a round orange icon |
| CSM User client | The CSM application for CSM users, typically depicted by a round blue icon |
| Discovery Session (SL1) | Service Catalog Request (CSM) |
| Incident | A CSM Incident syncs with an SL1 Event. |
| IS or PF | ScienceLogic SL1 PowerFlow (formerly called the Integration Service) |
| mApp |
CSM Mergeable Application; a combination of Blueprints that contain configuration information |
| One-Step | A low-code/no-code tool in CSM that allows users to chain a series of actions into a simple or complex workflow |
| SL1 | ScienceLogic SL1 monitoring platform |
| Topology (SL1) | Dependency (CSM) |
Importing and Installing the Cherwell SyncPack
- On the SyncPacks page, click . The Import SyncPack page appears.
- Click and select the .whl file for the SyncPack you want to install.
You can also drag and drop a .whl file to the SyncPacks page.
- Click . PowerFlow registers and uploads the SyncPack. The SyncPack is added to the SyncPacks page.
- Click to confirm the activation and installation. When the SyncPack is activated, the SyncPacks page displays a green check mark icon (
) appears.
- For more information about the activation and installation process, click the check mark icon (
The "Cherwell" SyncPack requires you to install and configure the "Federated CMDB" mApp and the "IS Content" mApp. For more information, see Installing and Configuring Cherwell mApps.
After installing and configuring the Cherwell mApps, you will need to perform additional configurations before running the SyncPack. For more information, see the following chapters:
