Overview of Skylar One Features
This section provides an overview of the features and terminology in Skylar One. The order of the features matches the order of the items on the left-hand navigation in Skylar One.
Home
The Dashboards page is the default Home page () when you first launch Skylar One. You can set any of the top-level pages that display in the left-hand navigation bar as your landing page, including Events, Devices, Business Services, Skylar AI, Maps, and Setup and Config. You can also set a specific dashboard from the Dashboards page as your home page.
If you lose permission to the page or dashboard you set as your landing page, the Events page will be automatically set as your home page.
You cannot use any pages that display in the navigation bar below these pages as a landing page. This feature does not work with classic dashboards. For more information on what you can see and do on the default dashboards page, see the section on Default Dashboards.
To set your home page:
  1. In Skylar One, navigate to the page or the Skylar One dashboard that you want to set as your home page.
  2. Click your user name in the navigation bar at the top of the page and select Set as Home Page. That page or dashboard will be your home page the next time you launch Skylar One. If the page you are currently on cannot be used as a home page, the Set as Home Page option will be grayed out.
Dashboards
A dashboard is a page that displays one or more graphical reports, called widgets. These widgets appear in their own pane, and display charts, tables, and text. Access to dashboards is based on your login credentials, so you can view only dashboard data for which you have access. Also, some dashboards might be private instead of public.
To define a widget, you first select from a list of pre-defined widget definitions, and then customize what will be displayed by the selected widget by supplying values in the option fields provided by that widget.
To navigate to the Dashboards page, click the Dashboards icon (). You can also access "classic" dashboards from the Classic Dashboards page (Dashboards > Classic Dashboards).
If an animated line appears under a widget name, the widget is in the process of updating its data. When the line disappears, the widget is done updating.
If an item name displays as a hyperlink in a dashboard, you can click that link to go to the relevant detail or Investigator page for that item. You can click dashboard links to the Investigator pages for devices, events, and services.
For more information about Dashboards, see the Dashboards section.
Events
One of the quickest ways to monitor the health of your network is to look at events. You can view events on the Events page in Skylar One.
Events are messages that are triggered when a specific condition is met. For example, an event can signal if a server has gone down, if a device is exceeding CPU or disk-space thresholds, or if communication with a device has failed. Alternately, an event can simply display the status of a managed element.
Skylar One generates log messages from incoming trap and syslog data, and also when Skylar One executes user-defined policies. Skylar One then uses these log messages to generate events. Skylar One examines each log message and compares it to each event definition. If a log message matches an event's definition, Skylar One generates an event instance and displays the event on the Events page.
Each event includes a description of the problem, where the problem occurred (device, network hardware, software, policy violation), a pre-defined severity, the time of first occurrence, the time of most recent occurrence, and the age of the event.
Skylar One includes pre-defined events for the most commonly encountered conditions in the most common environments. You can also create custom events for your specific environment or edit the pre-defined events to better fit your specific environment.
For more information about events, see the Events section.
Devices
As part of monitoring your network, Skylar One collects data using common networking protocols. Most collected data is associated with a device in Skylar One. A device in Skylar One is a record that can represent:
  • Physical network hardware, for example, servers, switches, routers, printers, etc.
  • A component of a larger system, for example, a data store in a hypervisor system, a blade server, etc.
  • Any other entity about which you want to collect data, but want or need to associate that data with a container that does not correspond directly to a physical device or a component. For example, you might configure a device record that represents a web site or a cloud service.
Skylar One allows you to monitor and manage hardware and applications within your network. Skylar One provides a network-wide view through a "single pane of glass." This means that you can monitor status, create policies, define thresholds, and receive notifications, all through a single, browser-based application.
Discovery
Discovery is the tool that automatically finds all the hardware-based devices, hardware components, and software applications in your network. You must provide the discovery tool with a range or list of IP addresses and/or a list of fully-qualified domain names (hostnames), and the discovery tool determines if a device, hardware component, or software application exists at each IP address. For each device, hardware component, or software application the discovery tool "discovers", the discovery tool can collect a list of open ports, DNS information, SSL certificates, list of network interfaces, device classes to align with the device, topology information, and basic SNMP information about the device.
The Discovery tool also determines which (if any) Dynamic Applications to align with the device. If the discovery tool finds Dynamic Applications to align with the device, the discovery tool triggers collection for each aligned Dynamic Application.
For more information about Discovery, see the Discovery and Credentials section.
Credentials
Credentials are access profiles (usually username, password, and any additional information required for access) that allow Skylar One to retrieve information from devices and from software applications on devices. Discovery uses SNMP credentials to retrieve SNMP information during initial discovery and nightly auto-discovery. If Skylar One can connect to a device with an SNMP credential, Skylar One deems that device "manageable" in Skylar One.
Dynamic Applications use credentials to retrieve SNMP information, database information, SOAP information, XML information, XSLT information, and WMI information. Proxied Web Services use SOAP/XML Host credentials to pass authentication information to external web services.
Skylar One includes a type of credential called "Basic/Snippet" that is not bound to a specific authentication protocol. You can use this type of credential for Dynamic Applications of type "WMI", of type "snippet", and when defining system backups. "Basic/Snippet" credentials can also be used for monitoring Windows devices using PowerShell.
Skylar One includes a type of credential that allows Dynamic Applications of type "Snippet" to use SSH to communicate with a remote device. To use these Dynamic Applications, you must define an SSH credential.
Skylar One includes a type of credential that allows Dynamic Applications to retrieve data from Windows devices. If you align a Dynamic Application for PowerShell with a PowerShell credential, Skylar One assumes that you want to use its built-in agentless transport to communicate with Windows devices.
Skylar One also includes several universal credential types that are tailored to monitoring specific types of devices by using field names that correspond to the terminology used and the structures of data needed for those technologies. Skylar One includes universal credentials for the following device types: Aliyun; AWS, including credentials specific to Assume Role, EC2, and IAM; Azure; Citrix Xen; IBM; and VMware. There are also several universal credential types that are used for Skylar Oneconfiguration and administration, rather than to monitor specific device types. These include SL Service Connection and S3 Backup credential types.
If necessary, a single device can use multiple credentials. If more than one agent or application is running on the device, each agent or application can be associated with its own credential. During discovery, Skylar One will use the appropriate credential for each agent.
For more information about Credentials, see the Discovery and Credentials section.
Virtual Device
  • Monitor a device or application that doesn't support TCP/IP, SNMP, or both. The device's data can be pushed to Skylar One via another method (for example, email) and stored in a virtual device.
  • Monitor multiple SNMP agents on a single device. In such a case, one of the SNMP agents (for example, a hardware agent) can be associated with the device and another SNMP agent (for example, an agent that monitors a software application) can be associated with a virtual device.
  • Isolate and monitor specific parameters separately from their originating device. For example, you might want to monitor a database and keep its data separate from the hardware data you are collecting from the host device.
Component Device
Skylar One uses Dynamic Applications to retrieve data from a management device and discover each entity managed by that management device. Skylar One then uses that retrieved data to create a device for each managed entity. In some cases, the managed entities are nested.
  • In Skylar One a managed entity is called a component device. A component device is an entity that runs under the control of a physical management device.
  • In Skylar One, the root device is the physical device that manages one or more component devices.
  • In Skylar One, a parent device is a device that has associated entities modeled as component devices. A parent device can be either a root device or another component device.
For more information about Devices, see the Device Management section.
The Skylar One Agent
The Skylar One agent is a program that you can install on a device monitored by Skylar One (formerly SL1). There is a Windows agent, an AIX agent, a Solaris agent, and a Linux agent. The agent collects data from the device and pushes that data back to Skylar One.
The following minimum agent versions are required for Skylar One 12.1.1 and later: Windows version 131; Linux version 174; AIX version 180; and Solaris version 180. Users who require agent-based log collection on a device with a Windows agent or a Linux agent must have the minimum Windows agent (131), or for a Linux agent (174). ScienceLogic recommends that users perform an upgrade, if they do not have the minimum required agent versions, via the Upgrade button on the Agent page in the current user interface, or by downloading and upgrading the agent manually.
For more information about the agent, see the Agent section.
Business Services
A business service includes one or more technical services that provide value to internal or external customers. Some examples of business services include verifying Internet access or website hosting, online banking, remote backups, and remote storage. Usually a business service includes an associated Service Level Agreement (SLA) that specifies the terms of the service.
Create the following types of services on the Business Services page, in the following order:
  1. Device Service. Monitors a set of related devices, such as all devices from a specific region.
  2. IT Service. Monitors a service that IT provides to your organization. An IT service is made up of one or more device services.
  3. Business Service. Monitors a service your organization provides to your customers. A business service is made up of one or more IT services.
For more information about Business Services, see the Business Services section.
Skylar AI
Skylar AI is a software services suite powered by artificial intelligence (AI) that is designed to automatically manage and anticipate IT incidents. Skylar AI reasons over telemetry and the stored knowledge of an organization to deliver accurate insights, recommendations, and predictions.
Skylar One collects data and leverages Skylar AI to learn the patterns for a particular device metric over a period of time. Skylar uses the resulting data to build a device metric-specific model that is used to define a scope of expected behavior as well as anomalous data points.
The Skylar AI family of services currently includes the following components:
  • Skylar Analytics, an advanced reporting and custom analytics service that combines AI-powered analytics with deep data exploration and visualization.
  • Skylar Advisor, a proactive IT problem-solving advisory service powered by human-centered AI (coming soon).
For more information about Skylar AI, see the Skylar AI Documentation site.
Skylar Analytics
Skylar Analytics contains a set of tools that lets you view, analyze, and use the data that Skylar One gathers and sends to the Skylar AI engine. Skylar Analytics insights are presented in the Skylar One user interface, using a ScienceLogic-hosted instance of Apache Superset, and in the Skylar AI API.
Skylar Analytics includes the following components:
  • Data Visualization. Enables SQL-based dashboards and charts based on data gathered by Skylar AI and Skylar One. Data Visualization is achieved using a ScienceLogic-hosted instance of Apache Superset.
  • Data Exploration. Enables third-party tools that use the Open Database Connectivity (ODBC) interface to access the metric data from Skylar AI. This component lets you use ODBC to connect Skylar AI data with applications like Tableau, Microsoft Power BI, or other business intelligence tools.
  • Anomaly Detection. Uses always-on anomaly detection to find metric outliers in Dynamic Application time series data. It also computes an anomaly score that characterizes the significance of each anomaly. You can view anomalies for all Dynamic Application metrics for a device by visiting the Anomaly Detection tab on the Device Investigator page for that device.
  • Predictive Alerting. Helps to avoid problems such as file systems running out of space, hosts running out of memory, or issues with network reliability due to oversubscription. The alerts appear as enriched events within Skylar One.
Skylar Advisor (coming soon)
Skylar Advisor provides diagnostic assistance for your Skylar One system using Skylar AI. You interact with Skylar Advisor by reviewing and following its proactive suggestions, which appear as notifications or prompts in your IT management interface. You can also query Skylar Advisor for advice.
Skylar Advisor offers tailored guidance based on real-time data sent to Skylar AI from Skylar One, which empowers you to make informed decisions quickly and efficiently.
Maps
A map is a visual representation of the various devices and related elements, also called nodes, in your environment that have been discovered by Skylar One. A map displays the important details about the nodes, their hierarchy, and the relationships associated with those nodes.
Maps can display business services, component maps (DCM, DCM+R), CDP topology, LLDP topology, Layer-2 topology, Layer-3 topology, and Virtual Infrastructure (VMware and virtual machines).
You can also create your own maps with your most important devices, and add images, text, and shapes to customize your maps.
To view a map, go to the Maps page () and click the name of the map from the Maps page.
  • Nodes. Shapes that represent Devices, Topology Elements, and Business Services defined in Skylar One. The shape of a node represents its type, and the color of its outline specifies the current state of the node.
  • Links. Lines with or without arrows that represent the relationships and hierarchies between nodes. All device relationships are displayed as child and parent relationships. If the nodes on a map contain arrows, then the arrows represent the direction of the relationship, pointing from the child node to its parent node. If a node does not contain an arrow, then the relationship is bi-directional, or undirected.
In addition, the Geographic Maps page (Maps > Geographic Maps) allows you to create and manage custom geographic maps that visualize devices on a map and provide location-based insights of those devices at a glance. You can create custom geographic maps from your existing devices by selecting devices that have been associated with a location. If no devices are available for selection, you will need to load location data first. In this release, location data can be uploaded in bulk, and this process can be repeated at any time to add more location data to devices.
For more information about maps, see the Maps section.
Setup and Config
The Setup and Config page () displays all information relevant to getting started in Skylar One for administrator-level users. Included on this page are a number of journeys, intuitive self-service workflows that will guide you through the most common Skylar One system tasks. Click the name of a workflow to get started.
This page also contains informational cards that provide you with the proper resources for Skylar One setup and configuration.
The informational cards on this page include:
  • Get Started. Displays a list of available user journeys and their journey status. Click the name of the journey to get started. The journeys include:
  • Take a Tour of Skylar One
  • Discover and Monitor Hybrid Cloud Infrastructure
  • Resources. Hosts additional external resources to help you with setup and configuration; these links include:
  • Training Portal
  • ScienceLogic Support
  • Overview. Provides links to the user journeys. These journeys include guided tours and interactive wizards that help you set up and refine your Skylar One environment:
  • Next Steps. Contains links to other pages in Skylar One where you can continue working after completing some or all of a journey:
  • Manage Devices
  • Manage Collector Groups
  • Manage Organizations
  • Manage Users
  • Manage Access Hooks
Ticketing
A ticket is a request for work. This request can be in response to a problem that needs to be fixed, for routine maintenance, or for any type of work you require. Tickets are assigned a severity based on the severity of the issue that needs to be fixed or worked on. For example, a server going down might require a critical ticket, whereas a routine maintenance issue might require only a minor ticket. These severities range from healthy to notice, minor, major, and critical.
A ticket can be created manually, or created based on an event. If a ticket is created based on a selected event, most of the ticket fields are populated automatically by Skylar One. The Skylar One can also automatically create a ticket, using Run Book Automation and user-defined parameters.
In Skylar One you can view a list of active tickets, create new tickets, edit one or more existing tickets, and generate reports for one or more tickets, among other features.
For more information about Ticketing, see the Ticketing section.
Reports
Custom Reports
A custom report in Skylar One provides you with a collection of data from one or more tables in the Skylar One database. This information is populated and generated in different user-defined formats. You can select from default custom reports provided by ScienceLogic, edit these default reports, or create your own reports. You can also schedule reports, view a list of archived reports, and email reports to other users.
Custom reports include Quick Reports, which are custom report templates in Skylar One. You can access Quick Reports on the Reports page, in the Run Report category (Reports > Run Report).
Embedded Reports
Several pages in Skylar One allow you to generate a report that contains the information displayed in the page. Reports that are specific to a page are called embedded reports. The embedded reports cover the following elements:
  • Devices
  • Device Interfaces
  • System Processes
  • Windows Services
  • Hardware Components
  • Installed Software
  • Organizations
  • User Accounts
  • Access Keys
  • Tickets
  • Asset Records
  • Product Subscriptions
  • Vendors
For more information about Reports, see the Reports section.
Organizations and Users
An organization is a group for managing elements and user accounts. All policies, events, tickets, users, and other elements in Skylar One are associated with an organization.
The basic characteristics of an organization are:
  • A unique name (required)
  • Users who are members of the organization
  • Elements (for example, devices) associated with the organization
Organizations can be defined by geographic areas, departments, types of devices, or any structure that works best for your needs. For example, for a business with multiple locations, an administrator might create organizations named Boston, New York, and DC. Another administrator might create organizations named for departments, like Finance, Sales/Marketing, and Engineering.
Users
In Skylar One, there are two broad types of user accounts:
  • Administrators. By default, users of type "administrator" are granted all permissions available in Skylar One. Administrators can access all tabs and pages, and perform all actions and tasks on all entities, regardless of organization.
  • Users. Accounts of type "user" are assigned key privileges. Key privileges are customizable by the administrator and grant users access to pages and tabs and permit users to view information and perform tasks in Skylar One. These key privileges are defined by the Skylar One system administrator from the Access Keys page (System > Manage > Access Keys).
For more information, see the section on Access Permissions.
An account of type "user" can be granted the privileges that allow him/her to create or modify other users' accounts. However, for accounts of type "user", certain restrictions apply:
  • An account of type "user" cannot create or modify an account of type "administrator".
  • An account of type "user" cannot change his/her own account to type "administrator" or change another user's account to type "administrator".
  • An account of type "user" cannot add additional Access Keys to his/her own account.
  • An account of type "user" cannot grant or remove Access Keys to other accounts that he/she has not also been granted.
Regardless of access keys, accounts of type "user" can access only pages and actions associated with their organization. For example:
  • Suppose your organization includes three regional offices. Suppose you define three organizations: Northeast, Headquarters, and West Coast.
  • Suppose each organization includes the hardware located at the corresponding office.
  • Now suppose the account "JohnDoe" is of type "user" and is a member of the organization "West Coast". User JohnDoe would be able to view and act upon only devices that are included in the organization "West Coast". User JohnDoe would not be able to view or act upon the hardware at the other offices.
  • Skylar One allows you to assign each user a primary organization and optional additional organizations.
  • Now suppose that user "JohnDoe" needs to view the status of a device at headquarters. If you add "Headquarters" as a secondary organization in JohnDoe's account information, that user will now be able to view and act upon all the devices in the "Headquarters" organization.
NOTE: You can use Access Keys to further limit the access of each user, even within their own organization.
For more information about Organizations and Users, see the Organizations and Users section.
Run Book Automation
Skylar One includes automation features that allow you to specify actions you want Skylar One to execute automatically when specific event conditions are met. Automation in Skylar One is divided into two parts:
  • An automation policy defines the event conditions that can trigger an automatic action.
  • An action policy defines an action that can be triggered by an automation policy. An action policy can perform one of the following tasks:
  • Send an SNMP trap from Skylar One to an external device.
  • Write an SNMP value to an existing SNMP object on an external device.
  • Query a database.
  • Send an SNS Message to a Topic ARN (Amazon Resource Name). All subscribers to the Topic ARN will receive the message.
For more information about Automation, see the Run Book Automation section.
Dynamic Applications are the customizable policies that tell Skylar One what data to collect from devices and applications. For example, suppose you want to monitor a MySQL database running on a device in your network. Suppose you want to know how many insert operations are performed on the MySQL database. You can create or edit a Dynamic Application that monitors inserts. Every five minutes (for example), Skylar One could check the number of insert operations performed on the MySQL database. Skylar One can use the retrieved data to trigger events and/or to create performance reports.
Skylar One includes Dynamic Applications for the most common hardware and software. You can customize these default Dynamic Applications to suit your environment. You can also create custom Dynamic Applications.
Dynamic Applications in Skylar One support a variety of protocols to ensure that Skylar One can always communicate with the devices and applications in your network and retrieve information from them. Dynamic Applications can use the following protocols to communicate with devices:
  • SNMP
  • SQL
  • XML
  • SOAP
  • XSLT (uses SOAP and XSLT to convert XML data to a new format)
  • WMI (Windows Management Instrumentation), including WMI and WBEM
  • Windows PowerShell
  • Custom Python applications (called "snippets") for proprietary or more complex data retrieval
PowerPacks
A PowerPack is an exportable and importable package of one or more Dynamic Applications, device classes, device templates, event policies, custom reports, dashboard widgets, dashboards, run book policies, run book actions, ticket templates, credentials, proxy XML transformations, themes, device categories, device dashboards, and/or IT service policies.
You can use PowerPacks to share customized content among Skylar One systems and to download customized content from ScienceLogic.
You can create a PowerPack on a Skylar One system to export one or more Dynamic Applications, device classes, device templates, event policies, custom reports, dashboard widgets, dashboards, run book policies, run book actions, ticket templates, credentials, proxy XML transformations, themes, device categories, device dashboards, and/or IT service policies. You can then import that PowerPack on another Skylar One system to install the Dynamic Applications, device classes, device templates, event policies, custom reports, dashboard widgets, dashboards, run book policies, run book actions, ticket templates, credentials, proxy XML Transformation, themes, device categories, device dashboards, and/or IT service policies.
For more information about PowerPacks, see the PowerPacks section.
Asset Management
An asset is a piece of equipment owned by an organization. An asset record is a collection of information about that asset. In Skylar One, asset records are usually created for hardware devices, with some of the information populated automatically from collected data. Users can also manually enter information into an asset record.
In Skylar One, asset records can contain information about:
  • The name, make, and model of a device.
  • The serial number of a device.
  • Function and status of a device.
  • Networking information, like host ID, IP address, or DNS server for the device.
  • Physical location of the device.
  • Description of the network interface.
  • Vendor information for the device, including PO or check number, warranty policy, and service policy.
  • Hardware information like the amount of memory, CPU, and BIOS or EPROM version.
  • Description of each hardware component (if applicable).
  • Description of installed software (if applicable).
When possible, Skylar One can automatically populate fields in each asset record. Skylar One also allows users to create their own tabs and form fields in addition to the ones provided by default.
For more information about Assets, see the Asset Management section.
