Monitoring and Maintaining Skylar One
This section describes how to manage user access, manage scheduled tasks, and more in Skylar One (formerly SL1).
Monitoring and Managing User Access
Skylar One lets multiple users log into the same Skylar One system at the same time. The time a user spends logged into Skylar One is known as a user session. You can end a user's session in Skylar One, and you can also limit the number of users that can be simultaneously logged into a Skylar One system.
The Access Sessions page allows administrators to monitor user logins and logouts to the user interface.
From this page, you can also:
  • End a user's session.
  • View a list of accounts that are locked out of the user interface due to invalid username and password.
  • Unlock accounts that are locked out of the user interface.
Viewing Information about Each Access Session
The Access Sessions page displays a list of recent logins to the user interface. To view the Access Sessions page:
  1. Go to the Access Sessions page (System > Monitor > Access Logs).
  1. For each session, the Access Sessions page displays:
  • User Account. Username of person logging in to the user interface.
  • User Display Name. The username, email address, or preferred display name. This value is determined by the user's authentication resource settings.
  • Last Address. IP address from which the user accessed the user interface.
  • State. Current status of the user. The choices are:
  • Active. User is currently logged in to the user interface.
  • Expired. User's session in the user interface was killed.
  • Logged Out. User logged out of the user interface.
  • Never Used. User logged in to the user interface and did not perform any tasks before the session was killed.
  • Login Time. Date and time at which the user logged in.
  • Last-Hit Time. Date and time at which the user last loaded a page in the user interface.
  • Logout Time. Date and time at which the user logged out.
  • Session Duration. Length of time between login and logout.
Deleting a User's Session
From the Access Sessions page, you can end a user's session in the user interface. The user must log in again to access the user interface. The status of the session will be "expired".
To end a user's session:
  1. In the Access Sessions page, find the session you want to end. Select the checkbox for that session.
  2. Click the Select Actions field (in the lower right of the page) and then select Kill user session. Click the Go button
  3. Each selected session is ended. The user associated with each selected session is logged out of the user interface. The status of the session changes to "expired".
NOTE: After ending a user's session, that user can immediately log in to the user interface again. To prevent a user from logging in to the user interface, you must disable the user's account. For information on user accounts, see the Organizations and Users section.
Limiting the Number of Simultaneous User Sessions
If you get an "HTTP Response code was 429 (Too Many Requests)" error or a "User sessions at maximum" in Skylar One, you can adjust the USER_MAX_SESSIONS value in the /opt/em7/nextui/nextui.conf file:
  1. SSH to the Skylar One appliance and log in as user em7admin.
  2. At the command line, open the nextui.conf file in the vi editor:
  3. In the NextUI configuration file, set a new value for USER_MAX_SESSIONS, such as USER_MAX_SESSIONS=1000 for 1,000 concurrent user sessions.
  4. Save your changes and restart the NextUI service:
    sudo systemctl restart nextui
Viewing Lockouts and Unlocking Lockouts
If a user enters incorrect login information multiple times in a row, that username, the user's IP address, or both will be locked out of the user interface.
To view lockouts or restore login privileges to locked out users:
  2. In the Access Sessions page, click the Lockouts button.
  3. The Account Lockouts modal page allows administrators to view a list of locked-out accounts and to restore login privileges to locked out users.
  4. The Account Lockouts modal page displays the following about each lockout:
  • Attempt Account. Username that caused the lockout.
  • From Address. IP address from which the failed login attempts originated.
  • Attempt Time. Date and time at which lockout occurred.
  • Tries. Number of times user tried to log in to the user interface.
  1. To remove the lock for the user account and allow logins from the username and/or IP address, click the delete icon ().
Global Settings for Lockouts
The platform includes global settings that define how lockouts behave. In the Behavior Settings page (System > Settings > Behavior), the following fields affect lock-outs:
  • Account Lockout Type
  • Account Lockout Attempts
  • Account Lockout Duration
  • Lockout Contact Information
Audit Logs
For additional information about users and their actions in the platform, you can view the Audit Logs page. The Audit Logs page provides a complete audit trail for the platform. The Audit Logs page displays a record of all actions in the platform that are generated by users or by managed elements. For details, see the section on Audit Logs.
Improved User Session Control with tmux
The tmux utility is a terminal multiplexer that enables a number of terminals to be created, accessed, and controlled from a single screen, strengthens session-control mechanisms and aligns with industry-wide security practices.
Starting with Skylar One version 12.3.4, the tmux utility is disabled by default if you are on a non-STIG Skylar One deployment and access a Skylar One system using SSH.
This is a change in behavior from Skylar One versions 12.2.1.1 through 12.3.3, where the tmux utility was enabled by default. For more information, see the 12.3.3 release notes.
If you are on a STIG-compliant Skylar One deployment, the tmux utility is enabled by default. ScienceLogic encourages non-STIG users enable the tmux utility as well.
If tmux is enabled, sessions are automatically locked after 15 minutes of idleness or if an unclean SSH disconnect or dropped SSH connection occurs. Upon login, Skylar One checks for and attaches any detached tmux session if it finds them; otherwise, it starts a new session.
The utility also facilitates advanced features like scroll-back buffering with search, built-in clipboarding, multiple sessions and panes, detaching or attaching sessions, and session supervision or sharing.
To enable the tmux utility in non-STIG deployments:
  1. Either go to the console of the Skylar One appliance or use SSH to access the Skylar One appliance.
  3. Type the following at the command line to edit the silo.conf file:
    sudo visilo
  4. Change the following line in the [OS_HARDENING] section of the file to enable tmux:
    TMUX = true
    If the [OS_HARDENING] heading does not already exist in the silo.conf file, you must add that immediately above the TMUX = true setting.
  5. Save and quit the file (:wq).
  6. Log out of Skylar One and then log back in. The tmux utility is now enabled.
For more information about tmux shortcuts and usage, see https://tmuxcheatsheet.com/.
When using the command-line interface on a Skylar One appliance, the interface is meant for limited administrative purposes only.
When completing a task in a tmux session that will take longer than 15 minutes to complete, such as restoring from backup files, you should open a named tmux session to avoid the session timing out:
tmux new -t <session name>
Managing Scheduled Tasks
The Schedule Manager page (Registry > Schedules > Schedule Manager) allows you to view and manage all the scheduled processes you have defined in your system.
You can define scheduled processes in the following pages:
Managed schedules are loaded in batches of 1,000 by default to prevent the Process Manager from becoming overloaded and stopping the scheduled jobs prematurely. Previously, all scheduled jobs were loaded simultaneously. You can update the default batch number of scheduled jobs by going to the Database Tool page (System > Tools > DB Tool) and entering the following in the SQL Query field, replacing <batch_number> with the number of scheduled jobs you want to load per batch:
INSERT INTO master.system_custom_config (field, field_value) VALUES ('load_schedules_in_batches', <batch_number>) ON DUPLICATE KEY UPDATE field = 'load_schedules_in_batches', field_value = <batch_number>
The Database Tool page is available only in versions prior to 12.2.1 and displays only for users that have sufficient permissions to access the page.
Recommended System Maintenance
ScienceLogic also recommends that you take the following actions on a regular basis to reduce outages as much as possible.
Daily:
  • Review "Skylar One Operational Insights: Database Performance" classic dashboard
  • Review "Skylar One Operational Insights: Collector Performance" classic dashboard
  • Review "Skylar One Operational Insights: System Log Summary" classic dashboard
  • Review "Skylar One Operational Insights: Backup History" classic dashboard
You can find the Skylar One Operational Insights PowerPack on the PowerPacks page at the ScienceLogic Support Site: https://support.sciencelogic.com/s/skylar-one/powerpacks.
Weekly:
  • Run the System Status Script and review:
  • Address every error item in the report
  • Read Knowledge Base articles
  • Open tickets for issues when help from Skylar One Support is needed
Monthly:
  • Review capacity items. You must understand License Usage and how to project future capacity
Quarterly:
  • Audit User Profile access to verify that it meets expected needs
  • Audit DNS servers and Timeservers on all collectors
Viewing the List of Schedules
The Schedule Manager page (Registry > Schedules > Schedule Manager) displays the following about each schedule:
  • Event ID. Displays a unique, numeric ID for the scheduled process. Skylar One automatically creates this ID for each scheduled process.
  • sch id. Displays a unique, numeric ID for the schedule. Skylar One automatically creates this ID for each schedule.
  • Context. Displays the area of Skylar One upon which the schedule works.
Enabling or Disabling One or More Schedules
You can enable or disable one or more scheduled process from the Schedule Manager page (Registry > Schedules > Schedule Manager). To do this:
  1. Go to the Schedule Manager page (Registry > Schedules > Schedule Manager).
  3. Click the Go button.
Deleting One or More Schedules
You can delete one or more scheduled process from the Schedule Manager page (Registry > Schedules > Schedule Manager). To do this:
Putting the Database Server into Maintenance Mode
You can now put the Database Server in maintenance mode and stop all pull processes from the Data Collectors. You can then perform database maintenance or network maintenance without generating events.
After maintenance is completed, you can put the put the Database Server out of maintenance mode. Pull processes from the the Data Collectors will resume from the point where they were paused.
The new commands are silostart and silostop.
To put a Database Server in maintenance mode:
  4. silostop
To put a Database Server out of maintenance mode:
  4. silostart
Monitoring Overall System Usage and Statistics
The System Usage page displays:
  • Tables that show the type and number of each type of task performed by Skylar One
  • An optional line graph that displays system usage. To enable the display of this graph, go to the Behavior Settings page (System > Settings > Behavior) and uncheck the Hide Perpetual License Count checkbox. The graph displays the following metrics over time:
    • Capacity. The total monitoring capacity of the system. This value is determined by the license(s) for the Database Server(s) or All-In-One Appliance(s) in the system.
    • Number of Devices. The number of devices currently discovered in the system.
    • System Usage. The amount of Capacity that the devices in the system are currently using. This value is the sum of the Device Ratings for all devices in the system. The Device Rating for each device is calculated daily and is based on the number of collections performed for that device.
  • If you have a subscription license, you can also generate reports about subscription licensing.
To view the System Usage page, go to the System Usage page (System > Monitor > System Usage).
Viewing an Overview of All Events
The Event Overview page (System > Monitor > Event Overview) provides a graphical overview of all events in Skylar One.
The Event Overview page displays the following reports:
  • Number of Events by Severity. This graph displays event distribution by severity for the last 24 hours and for the last 7 days.
  • The y-axis displays the number of events.
  • The x-axis displays severity.
  • The red line represents events in the last 24 hours.
  • The blue line represents events in the last 7 days.
  • Mousing over a data point in the red line displays the number of events of the specified severity in the last 24 hours.
  • Mousing over a data point on the blue line displays the number of events of the specified severity in the last 7 days.
  • Most Common Event Types. This pie graph displays the ten most frequently occurring events for the last 7 days.
  • Each slice of the pie represents an event type. The legend on the left maps each slice color to an event and lists the actual number of events of that type.
  • The graph displays percent. Compared to the total number of occurrences for the top ten events, each slice displays the percent that belong to a specific event.
  • Mean Time-to-Resolution. This bar graph displays the number of events generated in the last 24 hours, 7 days, 14 days, and 30 days, and their average resolution time.
  • The x-axis displays the time span. There is a bar for 24 hours, 7 days, 14 days, and 30 days.
  • The red bars represent the actual number of events associated with the time-to-resolution.
  • The blue bars represent the average number of events associated with the time-to-resolution.
  • Mousing over a bar displays the number of events associated with the time-to-resolution.
Viewing Events by Appliance and Event Source
The Event Statistics page displays a graph of the number of events processed by a selected Database Server, Data Collector, or Message Collector.
The Event Statistics page displays the following information:
  • Appliance. In the field in the upper left, select from the list of all Database Servers, Data Collectors, and Message Collectors.
  • Event Type. In the next field on the upper left, select from the list of event types. The choices are:
  • API. The event was generated by an external API.
  • Dynamic. Event was generated by a monitoring application running on the device.
  • Email. The event was generated by an incoming email.
  • Internal. Event was generated by Skylar One.
  • Syslog. Event was generated from standard system log generated by device.
  • Trap. Event was generated by an SNMP trap.
The graph displays the average number of events processed by the selected appliance, for the selected duration.
  • The y-axis displays the average number of events.
  • The x-axis displays time. The increments vary depending upon the selected data type (from the Options menu) and the date range (from the Date Range Selection pane).
  • Mousing over any point in any line displays the value at that time-point in the Mouse-over column in the Data Table pane.
  • You can use your mouse to scroll the report to the left and right.
