Introduction to the AWS Incident Manager SyncPack
This section describes how you can use the "AWS Incident Manger" SyncPack to automatically synchronize SL1 events and Amazon Web Services (AWS) incidents between your AWS and SL1 systems. The integration is bidirectional between SL1 and AWS.
You can use the "AWS Incident Manager" SyncPack to automatically synchronize SL1 events and Amazon Web Services (AWS) incidents between your AWS and SL1 systems. The integration is bidirectional between SL1 and AWS.
  • Bulk Resolve SL1 Events From AWS. This application collects resolution state data from AWS and resolves corresponding SL1 events.
  • Create Timeline Event In AWS Incident Manager. This application collects acknowledged event data from SL1 and creates a timeline event in AWS.
  • Resolve AWS Incident. This application resolves an AWS incident that was resolved by a corresponding SL1 event.
  • Send SL1 Event to AWS Incident Manager. This application collects event details from SL1 and creates an incident in AWS.
Contents of the SyncPack
This section lists the contents of the "AWS Incident Manager" SyncPack.
PowerFlow Applications
For more information about how to configure these applications, see Configuring and Aligning the AWS Incident Manager Applications.
Configuration Object
  • AWS Incidents Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to SL1, including the host, username, and password.
  • Details for connecting to AWS, including the region name, access key ID, secret access key ID, and service.
  • Details for event and incident response including templates, maps, time, external URL population, and response plans.
Steps
  • CreateSL1Payload
  • Get Event Details From SL1 Start AWS Incident
  • Get Resolved Incidents And Pass To SL1
  • PostUpdateToSL1
  • Resolve Incident In AWS Incident Manager
  • "AWS Base" SyncPack
  • "SL1 Base Notifications" SyncPack
PowerFlow AWS API Any TCP 443 AWS API Access
Installing the SyncPack
You must download the AWS Base SyncPack before downloading the AWS Incident Manager SyncPack.
Downloading the SyncPack
  2. Click the Product Downloads tab and select PowerPacks.
  3. In the Search PowerPacks field, search for the SyncPack and select it from the search results. The Release Version page appears.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see Activating and Installing a SyncPack.
