Introduction to the CrowdStrike Falcon SyncPack
This section describes how you can configure and use the "CrowdStrike Falcon" SyncPack with the PowerFlow platform to sync SL1 events and CrowdStrike detections.
The "CrowdStrike Falcon" SyncPack let you sync sync SL1 events and CrowdStrike Falcon detections (security events).
  • Fetch Detections from CrowdStrike and Send Alert to SL1. This application acquires tokens and New Detections from CrowdStrike and creates alerts for SL1.
  • Clear Detection from Cache. This application acquires and saves event details to send to SL1.
Contents of the SyncPack
This section lists the contents of the "CrowdStrike Falcon" SyncPack.
PowerFlow Applications
For more information about how to configure these applications, see Configuring Applications for the CrowdStrike Falcon SyncPack.
Configuration Object
  • CrowdStrike Sample Configuration. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system.
Steps
  • Fetch Detections and Generate Payloads for SL1
  • Fetch New Detections from CrowdStrike
  • Get Alerted Detections from Cache
  • Get Each Detection and Create SL1 Alerts
  • Get Event Details and Clear Detections ID
  • SL1PowerFlow platform version: 2.3.0 or later
  • SL1 version: 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
  • "Base Steps" SyncPack version 1.3.2 or later
  • Administrator access to both SL1 and CrowdStrike
PowerFlow CrowdStrike REST API Any TCP 443 CrowdStrike REST API Access
ScienceLogic highly recommends that you disable all firewall session-limiting policies as the firewalls will drop HTTPS requests resulting in data loss.
Installing the SyncPack
Downloading the SyncPack
  1. Go to the ScienceLogic Support Site.
  3. In the Search PowerPacks field, search for the SyncPack and select it from the search results. The Release Version page appears.
  4. On the PowerPack Versions tab, click the name of the SyncPack version that you want to install. The Release File Details page appears.
  5. Click the Download File button or click the name of the .zip file containing the .whl file for this SyncPack to start downloading the file.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see the following topic.
