You must install the "ServiceNow Base" SyncPack before you can install any of the other ServiceNow SyncPacks.
Architecture Overview for ServiceNow SyncPacks
The following diagram details the various elements that are contained in SL1 and the PowerFlow system, and how PowerFlow sits between the core SL1 platform and an external data platform:
SL1 | ServiceNow |
Asset, Custom Attribute |
Asset (ITAM) |
Device |
CI (Configuration Item) |
Discovery Session |
Event |
Incident, Event, or Case (depending on the SyncPack you are using) |
Alert |
Event |
Organization |
Company, Domain |
Dependency Map for ServiceNow SyncPacks
The following graphic describes which SyncPacks depend on other SyncPacks:
For more information about the "Base Steps" SyncPack, see Default SyncPacks.
Prerequisites for ServiceNow SyncPacks
This section describes the prerequisites for the ServiceNow SyncPacks. For more information about the specific software versions required by a ServiceNow SyncPack, see the release notes for that SyncPack.
To install any of the ScienceLogic ServiceNow SyncPacks, you must have administrator access to both SL1 and ServiceNow. Specifically, you will need:
If you want to install multiple ServiceNow SyncPacks at the same time, you should upload all of the SyncPacks first, and then install them to address any dependencies between the SyncPacks.
ScienceLogic does not support any deployment that attempts to sync one SL1 instance to multiple ServiceNow instances. A deployment of this type will be incredibly fragile and would require the customer to strictly control their environments. This is not something that can be controlled programmatically. Escalations related to this type of deployment are not supported.
Downloading the SyncPack
- Click the PowerPacks & SyncPacks. tab and select
- In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
- On the SyncPack version that you want to install, and select Show File Details. The Release File Details page appears. tab, click the down arrow next to the
- Click the SyncPack. button to download the
Importing the SyncPack
- On the SyncPacks page (
Installing the SyncPack
If you are upgrading to this version of the SyncPack from a previous version, make a note of any settings you made on the Configuration pane of the various PowerFlow applications in this SyncPack, as these settings are not retained when you upgrade.
If you do not see the SyncPack that you want to install, click the Filter icon (
) appears.
