Introduction to the ServiceNow Service Graph Connector SyncPack
The "ServiceNow Service Graph Connector" SyncPack works with the ServiceNow Service Graph Connector method instead of the ServiceNow Identification and Reconciliation Engine (IRE) used by the existing "ServiceNow CMDB" SyncPack.
This SyncPack uses the "Service Graph Connector for ScienceLogic" certified application in ServiceNow.
This SyncPack is not compatible with versions of the "ServiceNow Incident" SyncPack older than version 4.0.0. You cannot upgrade to this SyncPack from the "ServiceNow CMDB" SyncPack.
You can use this SyncPack to sync your monitored devices in Skylar One to your ServiceNow CMDB using the ServiceNow Service Graph Connector. Instead of adding classes and field mappings in PowerFlow, you can set up those classes and field mappings in ServiceNow.
You can also use this SyncPack to sync file systems and their organizations and relationships from Skylar One to ServiceNow, and to sync network interfaces and their organizations and relationships from Skylar One to ServiceNow.
Currently, all data is synced only from Skylar One to ServiceNow.
This SyncPack includes the following applications, which you can use to synchronize data between ServiceNow and Skylar One:
  • Device and Organization Sync. The "Sync Devices from Skylar One to ServiceNow via SGC" application syncs devices and their organizations and relationships from Skylar One to ServiceNow. For more information, see Syncing Devices from Skylar One to ServiceNow.
  • File System Sync. The "Sync File Systems from Skylar One to ServiceNow via SGC" application syncs file systems and their organizations and relationships from Skylar One to ServiceNow. For more information, see Syncing File Systems from Skylar One to ServiceNow.
  • Interface Sync. The "Sync Interfaces from Skylar One to ServiceNow via SGC" application syncs network interfaces and their organizations and relationships from Skylar One to ServiceNow. For more information, see Syncing Interfaces from Skylar One to ServiceNow.
In addition, this SyncPack uses a Guided Setup process in ServiceNow to help you quickly and easily set up these syncs.
Contents of the SyncPack
This section lists the contents of the "ServiceNow Service Graph Connector" SyncPack.
PowerFlow Applications
The following PowerFlow applications are included in this SyncPack:
  • Cache Skylar One Orgs and Device Classes. Reads all existing Skylar One Device Classes and writes them to a cache. You must run this application before you run the "Sync Devices from Skylar One to ServiceNow via SGC" application.
  • Sync Devices from Skylar One to ServiceNow via SGC. Syncs devices and their organizations and relationships from Skylar One to ServiceNow. For more information, see Syncing Devices from Skylar One to ServiceNow.
  • Sync File Systems from Skylar One to ServiceNow via SGC. Syncs file systems and their organizations and relationships from Skylar One to ServiceNow. For more information, see Syncing File Systems from Skylar One to ServiceNow.
  • Sync Interfaces from Skylar One to ServiceNow via SGC. Syncs network interfaces and their organizations and relationships from Skylar One to ServiceNow. For more information, see Syncing Interfaces from Skylar One to ServiceNow.
Steps
  • Post CIs to ServiceNow
  • Post Relationships to ServiceNow
  • Process Skylar One Devices
  • Pull and Process Advanced Topology from Skylar One for SGC
  • Pull and Process File Systems from Skylar One
  • Pull and Process Interfaces and IPs/subnets from Skylar One for SGC
  • Pull Devices from Skylar One
  • Query and Cache Skylar One Device Class info
You can use the "ServiceNow SyncPack" configuration object from the ServiceNow BaseSyncPack as a template for a configuration object for this SyncPack.
This SyncPack requires you to download and install the new "Service Graph Connector for ScienceLogic" application. For more information, see Installing the "Service Graph Connector for ScienceLogic" Application in ServiceNow.
