Introduction to the Infoblox: Workflow Configuration PowerPack
Thissectiondescribes the event policy found in the Infoblox: Workflow Configuration PowerPack.
This PowerPack requires a subscription that includes CMDB/Inventory workflow automations.
What is the Infoblox: Workflow Configuration PowerPack?
The Infoblox: Workflow Configuration PowerPack includes one "Infoblox: Mismatched IP addresses" event policy. The "Infoblox: Mismatched IP addresses" event policy creates an event in SL1 when an SL1 and Infoblox device have the same name but different IP addresses.
For more information on enabling event policies, see the section on Editing an Event Policy.
Installing the Infoblox: Workflow ConfigurationPowerPack
Before completing the steps in this section, you must import and install the latest version of the Infoblox: Workflow Configuration PowerPack.
IMPORTANT: You must install and configure the Infoblox: Inventory SyncPack version 1.0.0 before using the Infoblox: Workflow Configuration PowerPack.
The Infoblox: Workflow Configuration PowerPack requires SL1 version 10.2.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
