Introduction to the Jenkins SyncPack
This section describes how you can use the "Jenkins" SyncPack. The "Jenkins" SyncPack provides a bidirectional integration between SL1 events and Jenkins jobs, pipeline jobs, and nodes.
What is the Jenkins SyncPack?
The "Jenkins"  SyncPack includes a configuration object, applications, and steps that bidirectionally sync jobs, pipeline jobs, and node status between Jenkins and SL1.
  • A subscription that includes CMDB/Inventory Workflow Automations
  • "Base Steps" SyncPack version 1.3.2 or later
  • Administrator access to Jenkins
PowerFlow Jenkins API Any TCP 443 Jenkins API Access
PowerFlow SL1 Database Any TCP 7706 SL1 Database Access
Contents of the SyncPack
This section lists the contents of the Jenkins SyncPack.
PowerFlow Applications
  • Create External Notes For SL1 Event. This application queries Jenkins for job information to be added to the associated SL1 event.
  • Create Event In SL1 For Jenkins Job Run. This application creates an SL1 event when a Jenkins job fails.
  • Create Event In SL1 For Jenkins Node Status. This application creates an SL1 event when a node is offline in Jenkins.
  • Create Event In SL1 For Jenkins Pipeline Job Run. This application creates an SL1 event when a Jenkins pipeline job fails.
  • Update SL1 Event Triggered. This application updates an SL1 event with Jenkins job information.
  • Trigger Event In SL1. This application creates an SL1 event when an SL1 event reaches a major severity threshold.
  • Create Virtual Device In SL1 For Jenkins Jobs And Nodes. This application creates a virtual device in SL1 that is used to identify Jenkins jobs and nodes.
For more information about how to configure these applications, see Configuring Applications for the Jenkins SyncPack.
Configuration Object
  • Base Jenkins Configuration. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to SL1, including the host, username, and password.
  • Details for connecting to Jenkins, including the URL, username, and password.
  • Details for notifications including the sender and receiving email, password, server, and port.
  • Details for connecting to Jenkins devices including device ID, collector group ID, and device class ID.
Steps
  • Build Jenkins Job
  • Build Jenkins Job From SL1 Event
  • Build Jenkins Pipeline Job
  • Create Jenkins Virtual Devices On SL1
  • Create SL1 Alert
  • Get Event Details From SL1
  • Get Jenkins Nodes Status
  • Get List Of Existing Virtual Devices Of Nodes
  • Get Virtual Device
  • Post Update To SL1
  • Read Cache
  • Update Jenkins Details To SL1
  • Update SL1 Event of Jenkins Build Job
Installing the SyncPack
Downloading the SyncPack
  1. Go to the ScienceLogic Support Site.
  3. In the Search PowerPacks field, search for the SyncPack and select it from the search results. The Release Version page appears.
  4. On the PowerPack Versions tab, click the name of the SyncPack version that you want to install. The Release File Details page appears.
  5. Click the Download File button or click the name of the .zip file containing the .whl file for this SyncPack to start downloading the file.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see the following topic.
