Introduction to the PagerDuty SyncPack
This section describes how you can use the PagerDuty SyncPack to automatically trigger, acknowledge, and resolve SL1 events and PagerDuty incidents between your PagerDuty and SL1 systems. The integration is bi-directional, from SL1 to PagerDuty.
This SyncPack requires a subscription to ScienceLogic Standard solutions.
  • A subscription to the SL1 Standard solution
PowerFlow PagerDuty API Any TCP 443 PagerDuty API Access
PowerFlow SL1 Database Any TCP 7706 SL1 Database Access
Contents of the SyncPack
This section lists the contents of the PagerDutySyncPack.
PowerFlow Applications
  • Create Event in PagerDuty from SL1 Event. This application sends SL1 event information to PagerDuty. The application translates and formats the event data from SL1 so that it can be consumed by PagerDuty to trigger, acknowledge, or resolve an incident.
  • Get PagerDuty log and incident data. This application queries the PagerDuty API to collect log entries and incident data. The collected entries are formatted and passed to subordinate applications that process the data to update, acknowledge, and clear events in SL1.
  • Clear resolve event from ScienceLogic. This application clears an event in SL1 that was resolved in PagerDuty. This application is called by the "Create resolve alert data from PagerDuty" application for each event that needs to be cleared.
  • Create resolve alert data from PagerDuty. This application is called by the "Get PagerDuty log and incident data" application to process log messages that indicate that an incident has been resolved. This application queries the PagerDuty API for the alerts associated with the resolved incidents. If the alert was triggered from an SL1 event, the application calls the "Clear resolve event from ScienceLogic" application to clear the event.
  • Get trigger alert data from PagerDuty. This application is called by the "Get PagerDuty log and incident data" application to process log messages that indicate that an incident has been triggered. This application queries the PagerDuty API for the alerts associated with those triggered incidents. If the alert was triggered from an SL1 event, the application calls the "Post event updates to ScienceLogic" application to add to incident ID to the event.
  • Get alert and user data from PagerDuty and ScienceLogic. This application is called by the "Get PagerDuty log and incident data" application to process log messages that indicate that an incident has been acknowledged. This application queries the PagerDuty API for the alerts associated with acknowledged incidents. If the alert was triggered from an SL1 event, the application updates the SL1 event so that the acknowledgment matches PagerDuty. This application also determines the date of the most recently processed alert and stores that value to be used by the next execution of the "Get PagerDuty log and incident data" application.
  • Post event updates to ScienceLogic. This application updates SL1 events using the data collected from the PagerDuty API.
For more information about how to configure these applications, see Configuring and Aligning the PagerDuty Applications.
Configuration Object
  • PagerDuty Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to the SL1 API, including the URL, username, and password
  • Details for connecting to the PagerDuty API, including the URL, username, and password
  • Details for connecting to the PagerDuty REST API, including the URL and API key
  • Details for connecting to an HTTP Proxy when communicating with PagerDuty, including the hostname or IP address, username, and password
  • An optional identifier that appends the event ID to create a PagerDuty dedup key. This can be used to avoid routing collisions when multiple SL1 platforms connect to the same PagerDuty instance.
  • Mapping between SL1 events and PagerDuty incidents including, event summary formats, event data, and indications to resolve or link incidents between SL1 and PagerDuty
Steps
  • Acknowledge the alert by user
  • Check for since parameter after query
  • Check conditional
  • Get alert count and acknowledge the alert by user
  • Get incident and user data
  • Get resolve incident data
  • Get trigger incident data
  • Get user email from user details
  • Convert ScienceLogic event data to PagerDuty event
Installing the SyncPack
Downloading the SyncPack
  2. Click the Product Downloads tab and select PowerPacks & SyncPacks.
  3. In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see the following topic.
