To use this SyncPack, you will need to use an existing configuration object in the PowerFlow user interface or create a new configuration object. Next, you can integrate one PagerDuty instance with multiple SL1 instances by creating a separate configuration for each SL1 instance.
For this SyncPack, you can make a copy of the "PagerDuty Base Config" configuration object, which is the sample configuration file that was installed with the PagerDuty SyncPack.
The "PagerDuty Base Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and PagerDuty settings.
To create a configuration object based on the "PagerDuty Base Config" configuration object:
Click the button (
) for the "PagerDuty Base Config" configuration object and select Edit. The Configuration pane appears:
Click . The Create Configuration pane appears.
- event_api. The URL of the PagerDuty event API for all PagerDuty instances. The default value is "https://events.pagerduty.com/v2/enqueue". You do not need to update this field.
- integration_key. The routing/integration key to use when sending events.
- pd_base_url. The base URL of the PagerDuty REST API for all PagerDuty instances. The default value is "https://api.pagerduty.com". You do not need to update this field.
- rest_api_key. The api key to use when syncing information to SL1 from PagerDuty.
- sl1_host. The hostname or IP address of the SL1 system the incident states will synchronize to.
- proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to PagerDuty.
- platform_identifier. The parameter that is appended to the event ID to create the PagerDuty dedup key. When you configure your SL1 system to send event data to PagerDuty via PowerFlow, the "platform_identifier" parameter in the Run Book Action must match this value.
- summary_string. The string that reflects how the summery field is constructed before it is sent to PagerDuty. You can use Run Book Variables to dynamically include SL1 event data in the summary field. For example, the default value, "%S: %X: %M", includes the severity, affected device, and event message in the summary string.
- custom_details. A structure of "key:value" pairs that can be used to provide additional SL1 event data to PagerDuty. You can use Run Book Variables to dynamically include SL1 event data in this field.
- resolve_events. A value to indicate whether events should be resolved in SL1 when the incident is resolved in PagerDuty. The default value is "False". If the value is "False", SL1 events will not be automatically cleared in SL1 when the corresponding PagerDuty incident is resolved.
- link_events. A value to indicate whether events should be updated with the incident URL from PagerDuty. The default value is "True". If the value is "True", the External Ticket ID field will be updated with the ID and URL of the PagerDuty incident.
For information on creating a PagerDuty service and accessing the integration key, see https://support.pagerduty.com/docs/services-and-integrations#create-a-new-service.
For more information on generating a PagerDuty REST API key, see https://support.pagerduty.com/docs/generating-api-keys#generating-a-general-access-rest-api-key.
For more information on Run Book Variables, see
SL1 supports only one value in this field. To avoid conflicts with other integrations, set this value to 'False' if your SL1 system has been integrated with another incident management system, e.g. ServiceNow.
With this SyncPack, any status changes made to an SL1 Event is sent to PagerDuty to update the corresponding incident. Any status changes to the PagerDuty incident are synced back to the corresponding SL1 event. You will need to align the PagerDuty applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Clear resolve event from ScienceLogic"
- "Get PagerDuty log and incident data"
- "Get resolve alert data from PagerDuty"
- "Get trigger alert data from PagerDuty"
- "Get alert and user data from PagerDuty and ScienceLogic"
- "Post event updates to ScienceLogic"
- "Create event in PagerDuty from SL1 event"
- Wait until you see the "App & Confg modifications saved" pop-up message before proceeding.
Using the PagerDuty Incident IntegrationPowerPack, you can optionally configure a single PowerFlow instance and single PagerDuty instance with multiple SL1 instances using the automation actions included in the PowerPack. To run the automation, you must create a configuration for each SL1 instance and schedule the "Get PagerDuty log and incident data" application.
For more information on the automation action included in the PagerDuty Incident IntegrationPowerPack, see
To schedule an application:
On the Applications page (
Click . The schedule is added to the list of schedules on the initial Schedule window. Also, on the Applications page, the word "Scheduled" appears in the Scheduled column for this application, and the button contains a check mark:
When either multiple SL1 instance or multiple PagerDuty instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or PagerDuty instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or PagerDuty instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
