Introduction to ScienceLogic Libraries and Execution Environments
This section describes how to create and manage ScienceLogic Libraries and Execution Environments in Skylar One (formerly SL1).
What is a ScienceLogic Library?
Some Dynamic Applications, credential tests, and Run Book Actions in Skylar One collect data or complete automated actions by executing one or more blocks of Python code, called snippets. When this happens, Skylar One passes credentials and other configuration information to the snippet, and at the end of execution, the snippet either passes collected data back to Skylar One or runs an action.
ScienceLogic Library is a package consisting of metadata and Python files that can be used by the Dynamic Applications, credential tests, and Run Book Actions that use snippets. ScienceLogic Libraries can be included in a PowerPack along with the Dynamic Applications, credential tests, and Run Book Actions that they support.
ScienceLogic Libraries are built using Python 3.
Python 2 support was deprecated in Skylar One 12.5.1. If you still use Python 2 for custom code, you cannot upgrade to 12.5.1 or later releases until your custom code is Python 3-compatible.
These are a few reasons you might want to create and use a ScienceLogic library in your PowerPack. For example, if you have a Python package you created that you want to share between snippets, or you have a third-party package that needs to be available during snippet execution.
ScienceLogic Libraries use the py_package (.tar) format. This file type includes metadata and Python packages, and allows you to take advantage of unit tests, automatic versioning, and other common packaging practices. This format requires an understanding of Python packaging tools.
Older versions of Skylar One bundled ScienceLogic Libraries in a py_directory format. That format has since been deprecated. Current ScienceLogic Libraries should be bundled only in a py_package format.
ScienceLogic Libraries can be installed on Skylar One in three ways:
  • Some libraries are included when you install Skylar One or run system updates.
  • Libraries that are included in a PowerPack are installed on Skylar One when you install the PowerPack.
  • Libraries can be manually imported into Skylar One.
You can view all of the installed ScienceLogic Libraries on the ScienceLogic Library Manager page (System > Customize > ScienceLogic Libraries).
For details about how to manage libraries in Skylar One, see the Managing ScienceLogic Libraries section.
What is an Execution Environment?
To use a ScienceLogic Library, you must align it with an execution environment.
In the Skylar One user interface, an execution environment is a list of one or more ScienceLogic libraries. When a Dynamic Application snippet, Run Book Automation snippet, or credential test is executed, the execution environment defines a virtual Python environment that is deployed on-demand and includes all of the ScienceLogic libraries aligned with it for use during snippet execution.
A ScienceLogic Library can be associated with multiple execution environments, allowing you to share code between snippets, Dynamic Applications, and PowerPacks.
Execution environments must be specified when creating or editing the following:
  • Snippets
  • Credential tests
  • Run Book Action policies that execute a snippet
When Skylar One runs a snippet embedded in a Dynamic Application, credential test, or a Run Book Action, it automatically deploys the runtime environment defined by the execution environment. The runtime environment includes each library aligned with the execution environment, plus system libraries that are provided by Skylar One.
If you do not specify the execution environment for a Dynamic Application, credential test, or Run Book Action, Skylar One aligns them with a system-default execution environment. This default execution environment is defined in each Skylar One System update.
When you build a PowerPack, it automatically includes the execution environments that are aligned with the PowerPack's Dynamic Applications, credential tests, and Run Book Actions that execute snippets.
Additionally, built-in, non-snippet Dynamic Application types use a pre-deployed, read-only Python 3 execution environment, "sl1_default_ee". This execution environment appears on the Environment Manager page (System > Customize > ScienceLogic Libraries > Actions > Execution Environments), but you cannot edit or delete it. Whenever new built-in Dynamic Applications are created via the user interface, they are automatically assigned to this execution environment.
The internal collection processes and Internal Collection Dynamic Applications (ICDAs) run on Python 3. The snippet code that is included in these Dynamic Applications must be Python 3.
For details about how to create and manage execution environments in Skylar One, see the Managing Execution Environments section.
For more information about aligning execution environments with Dynamic Applications, credential tests, or Run Book Actions, see the following sections:
