Prerequisites for the SyncPack
- Administrator access to SL1
- Webex administrator access
PowerFlow | Webex API | Any | TCP 443 | Webex API Access |
Contents of the SyncPack
This section lists the contents of the Webex SyncPack.
PowerFlow Applications
- Create Room For Event. Creates a Webex room from an event.
- Created Room Event Notification. Sends a notification when a room has been created.
- Major Event Notification. Notifies users of a "Major" event.
- Sync Event Status From Webex to SL1. This application synchronizes an event update made in Webex with the event status in SL1.
For more information about how to configure these applications, see Configuring and Aligning a Configuration Object in PowerFlow.
- Sample Webex Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system.
Steps
- Create Webex Room
- Create SL1 Payload
- Delete Event From SL1
- Fetch Room ID From Name
- Fetch User Email
- Fetch User Input
- Invite Users To Room
- Post Event Card To Webex
- Post Update To SL1
Installing the SyncPack
Downloading the SyncPack
- Click the PowerPacks & SyncPacks. tab and select
- In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
- On the SyncPack version that you want to install, and select Show File Details. The Release File Details page appears. tab, click the down arrow next to the
- Click the SyncPack. button to download the
Importing the SyncPack
- On the SyncPacks page (
) appears.
