Introduction to the LayerX Integration PowerPack
This section describes the event policies found in this PowerPack.
What is the LayerX Integration PowerPack?
The LayerX Integration PowerPack contains event policies that:
  • Match alerts sent by VOSS Insights to SL1 via the API and generates an event for each VOSS Insights event.
The PowerPack also includes dashboards that integrate with LayerX and displays information about your LayerX devices.
Available Event Policies
The LayerX IntegrationPowerPack includes several pre-defined event policies for VOSS Insights events:
Event Policy Name Description Event Source Severity
LayerX Critical Alert This event policy matches alerts sent from LayerX with critical severity. API Critical
LayerX Major Alert This event policy matches alerts sent from LayerX with a major severity. API Major
LayerX Minor Alert This event policy matches alerts sent from LayerX with a minor severity. API Minor
LayerX Informational Alert This event policy matches alerts sent from LayerX with an informational severity. API Notice
VOSS Insights Event Severity to SL1 Event Severity Mapping
The following table lists the different names for the aligned events in VOSS Insights and SL1:
VOSS Insights Event Severity SL1 Event Severity
Critical Critical
Major Major
Minor Minor
Informational Notice
Installing the LayerX Integration PowerPack
Configuring VOSS Insights for SL1 Event Policies
For steps on how to configure LayerX to send alerts to SL1, see https://www.voss-solutions.com/support/.
