What are the Datacenter Advanced Enrichment Policies PowerPacks?
The set of "Datacenter Advanced Enrichment Policies" PowerPacks contain device-specific automation policies (and additional event policies not included in other ScienceLogic PowerPacks) that you can configure to collect additional diagnostic information when events occur. You can use this additional data about the event to provide instructions on how to troubleshoot and resolve that event.
You must install the "Datacenter Advanced Enrichment Actions" PowerPack before you can install and use any of the related Policies PowerPacks. For more information, see Datacenter Advanced Enrichment Actions PowerPack.
Available Automation Policies and Event Policies
The following table lists the number of automation policies and event policies in each of the "Datacenter Advanced Enrichment Policies" PowerPacks:
| Device Type | Number of Automation Policies | Number of Additional Event Policies |
| Cisco Collaboration | 3 | 0 |
| Cisco CSP | 1 | 0 |
| Cisco IOS | 73 | 180 |
| Cisco IOS-XE | 32 | 72 |
| Cisco IOS-XR | 35 | 58 |
| Cisco Networking | 27 | 20 |
| Cisco NX-OS | 2 | 2 |
| Cisco Unified Communication Manager | 20 | 34 |
| Cisco UCS | 17 | 0 |
| Cisco UCS C-Series | 17 | 125 |
| Cisco Wireless | 18 | 28 |
| Citrix NetScaler | 10 | 17 |
| F5 Big-IP | 21 | 0 |
| Juniper JunOS | 2 | 0 |
| NetApp | 3 | 0 |
System Requirements
The "Datacenter Advanced Enrichment Policies" PowerPacks have the following prerequisites:
- The most recent version of the "Datacenter Advanced Enrichment Actions" PowerPack must be installed on your SL1 system.
- SL1 version 11.3.0 or higher.
Installing Datacenter Advanced Enrichment Policies PowerPacks
Unsupported Configurations
The following configurations are not supported by the "Datacenter Advanced Enrichment Actions" PowerPack:
- Customer-created run book actions that build command lists to be executed by the "Enrichment: Util: Collect Enrichment Data" run book action are not supported without prior authorization from ScienceLogic.
- Modifications of any kind to the code supplied in the "Datacenter Advanced Enrichment Actions" PowerPack are not supported without prior authorization from ScienceLogic.
