Introduction to Network Connectivity User-Initiated Automations
This section describes how to use the automation policies found in the Network Connectivity User-Initiated Automations PowerPack
  • Datacenter Automation Pack
  • ScienceLogic Standard solution
What is the Network Connectivity User-Initiated Automations PowerPack?
The Network Connectivity User-Initiated Automations PowerPack includes automation policies that you can use to run common network diagnostic commands from the SL1 event console , using Event Tools. This PowerPack is supplemental to the Network Connectivity Automations PowerPack and is not meant for standalone use.
In addition to using the standard content, you can customize the automation policies, or you can create your own automation policies using any available automation actions.
Installing the Network Connectivity User-Initiated Automations PowerPack
Before completing the steps in this section, you must import and install the latest version of the Network Connectivity Automations PowerPack and the Network Connectivity  PowerPack.
The Network Connectivity User-Initiated Automations PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the appropriate SL1Release Notes.
You must also install the Datacenter Automation Utilities PowerPack, which provides the output formats for the automation actions included in this PowerPack.
Standard Automation Policies
The Network Connectivity User-Initiated Automations PowerPack includes standard automation policies that trigger automation actions that will run network diagnostic commands from the SL1 event console.
The automation policies available in this release of the PowerPack are tied to default SL1 events for availability and monitoring polcices.
The automation policies are of Policy Type, "User Initiated". This means that for an event that matches the criteria, you can run these automation policies from the Event Console.
For these automation policies to be visible from the Event Tools in the Event's drawer, the following three things must be true between the event and the automation policy configuration:
  • Aligned Devices. The device for which the event is triggered must be configured as a Aligned Device in the automation policy.
The following table shows the automation policies, their aligned events, and the automation actions that run in response to the events.
The aligned events are included as part of the Network Connectivity PowerPack and are not installed with the SL1 platform. You must install the PowerPack to obtain these events.
Automation Policy Name Aligned Events Automation Action
Run NMAP on Affected Port
  • Poller: TCP/UDP port not responding
  • Poller: TCP/UDP port not responding (SMTP)
  • Run NMAP: Singe Port from Event
  • Datacenter Automation: Format Output as HTML
Run NMAP on Common Ports
  • Poller: Availability and Latency checks failed
  • Poller: Device not responding to ping (high frequency)
  • Poller: Availability Check Failed
  • Poller: Availability Flapping
  • Transactions: Round trip mail did not arrive within threshold
  • Run NMAP: Common Port List
Run NMAP on Monitored Ports
  • Run NMAP: Monitored Ports
Run Nslookup (IPv4)
  • Poller: Failed to resolve hostname
  • Poller: DNS hostname resolution time above threshold
  • Run Nslookup: Default Options
Run Ping (IPv4)
  • Poller: Network Latency Exceeded Threshold
  • Poller: TCP connection time above threshold
  • Run Ping: Default Options
Run Ping (IPv6)
  • Run Ping6: Default Options
Run Traceroute (IPv4)
  • Run Traceroute: Default Options
Run Traceroute (IPv6)
  • Run IPv6 Traceroute: Default Options
Running a User Initiated Automation Policy
To run a user initiated automation policy, open the drawer for the event and click in the Tools section. Any available user initiated automation policy will be available to run on demand.
Viewing Automation Actions for an Event
The following figure shows a VMware event with major criticality on the Events page. Click the [Actions] button () for an event, and select View Automation Actions to see the automation actions triggered by the events.
The results shown for this event, in the Event Actions Log, include the automation policy that ran (shown at the top of the following figure), along with the collected data. The following figure shows an example of this output.
To learn more about which logs are collected by default for a given automation action, see the Customizing Network Connectivity Actions section.
Although you can edit the automation policy described in this section, it is a best practice to use "Save As" to create a new automation policy, rather than to customize the standard automation policies.
