Creating a Custom Action Policy with Network Connectivity Actions
You can use one of the Action Types included with the "Network Connectivity Automations" PowerPack to create custom actions that you can then use to build custom automation policies.
To create an action policy:
- Navigate to the Action Policy Manager page (Registry > Run Book > Actions).
- In the Action Policy Manager page, click the button.
- The Action Policy Editor modal appears.
- In the Action Policy Editor page, supply a value in each field.
- Action Name. Specify the name for the action policy.
- Action State. Specifies whether the policy can be executed by an automation policy (enabled) or cannot be executed (disabled).
- Description. Allows you to enter a detailed description of the action.
- Organization. Organization to associate with the action policy.
- Action Type. Type of action that will be executed. Your choices are:
- Run Ping
- Run Traceroute
- Run Nslookup
- Run NMAP
- Run SNMP Walk
- Execution Environment. Select from the list of available Execution Environments. The default execution environment is System.
- Action Run Context. Select Database or Collector as the context in which the action policy will run.
- Input Parameters. A JSON structure that specifies each input parameter. Each parameter definition includes its name, data type, and whether the input is optional or required for this Custom Action Type.
Input parameters must be defined as a JSON structure, even if only one parameter is defined.
- Click [Save]. If you are modifying an existing action policy, click . Supply a new value in the Action Name field, and save the current action policy, including any edits, as a new policy.
Customizing Ping Actions
The "Network Connectivity Automations" PowerPack includes two automation actions that execute a Ping or Ping6 command. You can specify the host and the options in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
The following automation actions that use the "Run Ping" action type are included in the "Network Connectivity Automations" PowerPack.
Action Name | Description | host | options | ipv6 |
Run Ping: Default Options |
Runs a ping with default options |
Default is %a (IP address of current device) |
Default is None (empty string) |
false |
Run Ping6: Default Options |
Runs a ping6 with default options |
true |
For more information about substitution variables, see Appendix A: Run Book Variables.
Custom Ping Action Parameters
The Ping actions accepts the following parameters in JSON:
Paramter | Input type | Description |
host |
string |
The hostname or IP address to include in the ping command. You can also use the substitution variable "%a" to specify the IP address of the current device. |
options | string |
The options string to include in the command. Escape characters are not supported. You can include any of the options supported by the ping command-line utility in this field. If you do not include the "-c" or "-w" options in this field, the ping command will automatically include the option "-c 5", meaning that Ping will send five ECHO_REQUEST packets. |
ipv6 |
boolean |
(optional) If the ipv6 option is true, the ping6 command will be executed. If the ipv6 option is false, the ping command will be executed. |
The pipe (|) and semi-colon (;) characters are not permitted as input to the "host" and "options" parameters.
Using Substitution Values. The host and options inputs can contain substitution values that match the keys in EM7_VALUES. For example, to run a ping against the IP address of the device that triggered the event, you can specify "%a" in the "host" parameter.
Custom Ping Action Examples
IPv4. If the options parameter contains either "-c" or "-w" as a sub-string, and the ipv6 parameter is false or not supplied, the ping command string is built in the following format:
ping [options input] [host input]
For example, for the following settings:
- host. 192.168.1.1
- options. -c 10
The equivalent ping command string would be: ping -c 10 192.168.1.1
The equivalent JSON structure would be:
"host": "192.168.1.1",
"options": "-c 10",
"ipv6": false
IPv6. If the options parameter contains either "-c" or "-w" a s sub-string and the ipv6 parameter is true, a ping command string is built in the following format:
ping6 [options input] [host input]
- host. 192.168.1.1
- options. -c 10
The equivalent ping command string would be: ping6 -c 10 192.168.1.1.
"options": "-c 10",
"ipv6": true
The following figure shows a custom ping action for a fictitious company. This custom action is designed to ping IPv4 addresses 10 times without fragmenting the ICMP packets. The action will use the IP address of the current device as the IP address argument.
For a description of all options that are available in Automation Policies, see the
Customizing Traceroute Actions
The "Network Connectivity Automations" PowerPack includes two automation actions that execute a traceroute command. You can specify the host and the options in a JSON structure (name:value pairs) that you enter in the Input Parameters field in the Action Policy Editor modal.
The following automation actions that use the "Run Traceroute" custom action type are included in the "Network Connectivity Automations" PowerPack.
Action Name | Description | host | options | packet_length |
Run Traceroute: Default Options |
Runs an IPv4 traceroute with default options |
Default value is %a (IP address of the current device) |
Default value is None (empty string) |
Default value is 0 |
Run IPv6 Traceroute: Default Options |
Runs an IPv6 traceroute with all other options as default |
Default value is -6 |
Custom Traceroute Action Parameters
The custom Traceroute action type accepts the following parameters:
host |
string |
The hostname or IP address to include in the traceroute command. You can also use the substitution variable "%a" to specify the IP address of the current device. |
options |
string |
The options string to include in the command. You can include any of the options supported by the traceroute command-line utility in this field. |
packet_length |
integer |
The packet length to include in the traceroute command. To use the default packet length, use "0". |
Using Substitution Values. The host and options inputs can contain substitution values that match the keys in EM7_VALUES. For example, to run a traceroute against the IP address of the device that triggered the event, you can specify "%a" in the "host" parameter.
Custom Traceroute Action Examples
For the following settings, the equivalent traceroute command string would be: traceroute -t 192.168.1.1
- host. 192.168.1.1
- options. -t
- packet_length. 0
"options": "-t",
"packet_length": 0
For the following settings, the equivalent traceroute command string would be: traceroute 192.168.1.2 100
- host. 192.168.1.2
- options. An empty string
- packet_length. 100
"host": "192.168.1.2",
"options": "",
"packet_length": 100
Customizing NSLOOKUP Actions
The "Network Connectivity Automations" PowerPack includes an automation action that executes an NSLOOKUP command. You can specify the host and the options in a JSON structure (name:value pairs) that you enter in the Input Parameters field in the Action Policy Editor modal
The following automation actions that use the Run Nslookup custom action type are included in the "Network Connectivity Automations" PowerPack.
Action Name | Description | host | options | nameserver |
Run Nslookup: Default Options |
Runs an nslookup with default options |
Custom NSLOOKUP Action Parameters
The custom NSLOOKUP action type accepts the following parameters:
host | string | The hostname or IP address to include in the NSLOOKUP command. You can also use the substitution variable "%a" to specify the IP address of the current device. |
nameserver | string |
The IP address or hostname of the nameserver to include in the NSLOOKUP command |
options | string |
The options string to include in the command. You can include any of the options supported by the NSLOOKUP command-line utility in this field. |
The pipe (|) and semi-colon (;) characters are not permitted as input parameters.
Custom NSLOOKUP Action Examples
For example, for the following settings, the equivalent NSLOOKUP command string would be:
nslookup -timeout=10 192.168.1.1
- host. 192.168.1.1
- options. -timeout=10
- nameserver. An empty string
"nameserver": "",
"options": "-timeout=10"
For the following settings, the equivalent NSLOOKUP command string would be:
nslookup 192.168.1.2 10.644.148.32
- host. 192.168.1.2
- nameserver. 10.64.148.32
"nameserver": "10.64.148.32",
"options": ""
Customizing NMAP Actions
The Network Connectivity Automations PowerPack includes three automation actions that execute an NMAP command. You can specify the host and the options in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
The following automation actions that use the "Run NMAP" action type are included in the "Network Connectivity Automations" PowerPack.
Run NMAP: Common Port List |
Runs an NMAP command using a list of common ports. |
Default ports are 21, 22, 25, 53, 80, 443, 5985, and 5986 |
Run IPv6 NMAP: Common Port List |
Runs an IPv6 NMAP command using a list of common ports. |
Run NMAP: Monitored Ports |
Runs an NMAP command on the ports that are currently monitored on the device. |
Default is %_monitored_ports_% |
Run IPv6 NMAP: Monitored Ports |
Runs an IPv6 NMAP command on the ports that are currently monitored on the device. |
Run NMAP: Single Port from Event |
Runs an NMAP command on the port provided in the event sub-entity. |
Default is %Y |
Run IPv6 NMAP: Single Port from Event |
Runs an IPv6 NMAP command on the port provided in the event sub-entity. |
Default is %Y |
Custom NMAP Action Parameters
Custom NMAP action types accept the following parameters:
Parameter | Input type | Description |
host |
string |
The hostname or IP address to include in the NMAP command. You can use the substitution variable "%a" to specify the IP address of the current device. |
options |
string |
The options string to include in the command. See the parameters for specific NMAP actions earlier in this section. |
The special %_monitored_ports_% substitution variable is supported for the "Run NMAP" and "Run IPv6 NMAP" action types. This variable replaces a comma-separated list of ports from the monitoring policies aligned to the triggering device.
Custom NMAP Action Examples
For example, for the following settings, the equivalent NMAP command string would be:
nmap -p 22 192.168.1.1
- host. 192.168.1.1
- options. -p 22
"options": "-p 22"
Suppose you want to scan a range of ports. In this example, we're scanning the ports from 1 to 100. For the following settings, the equivalent NMAP command string would be:
nmap -p 1-100 192.168.1.1
- host. 192.168.1.1
- options. -p 1-100
"options": "-p 1-100"
Customizing SNMP Actions
The Network Connectivity Automations PowerPack includes an automation action type that can be used to create automation actions that run the SNMP walk command. To do this, you specify the host, OID, and SNMP credential in the Action Policy Editor modal.
Custom SNMP Walk Action Parameters
The SNMP Walk action type accepts the following parameters:
host | string | The hostname or IP address to include in the SNMP command. You can use the substitution variable "%a" to specify the IP address of the current device. |
oid | string |
The OID to walk. You can use substitution characters in this field. |
credential_id | integer | The ID of the SNMP credential to use when running the command. The SNMP credential specifies the SNMP version, community string, timeout, and other connection parameters. If you specify "0" (zero) in this field, the SNMP Read credential setting of the device associated with the triggering event will be used. |
Using Substitution Values. The host and oid inputs can contain substitution values that match the keys in EM7_VALUES.
Custom SNMP Action Examples
For example, settings to walk the System MIB using the IP address and SNMP Read credential of the device associated with the triggering event, the parameters would be::
- host. %a
- oid. .1.3.6.1.2.1.1
- credential_id. ID of the SNMP credential to use when running the command.
"host": "%a",
"oid": ".1.3.6.1.2.1.1",
"credential_id": 0
