Creating a Physical Device without Running Discovery
Skylar One (formerly SL1) allows you to manually create physical devices without running discovery. When you do so, a device record exists in Skylar One before Skylar One can communicate with the device.
In some cases, service providers find it useful to pre-populate a Skylar One system with device records but set the status of the manually created devices to Disabled. When network and firewall work are completed, the provider can then enable the devices and use discovery to keep the device data up-to-date.
You can manually create a physical device in three ways:
Requirements
Before manually creating a device record in Skylar One, you must have the following information:
Using the User Interface to Create a Physical Device
Creating a Physical Device from the Devices Page
To manually create a physical device from the Devices page:
  1. Go to the Devices page.
  2. Click the down arrow icon () next to the Add Devices button and then select Create Physical Device. The Create a Physical Device modal appears.
  3. In the Create a Physical Device modal, complete the following required fields:
    • IP Address. Enter an IP address that is unique in the device's collector group and can be used to communicate with the device.
      Skylar One will not allow a new device to be added with a public IP address that is not unique system-wide or a private IP address that is not unique to the selected Collector Group.
    • Device Name. Enter a device name for the device.
    • SNMP Read Credential. Select from a list of SNMP credentials.
    • Organization. Select from a list of organizations.
    • Device Class. Select from a list of device classes.
    • Collector Group. Select from a list of collector groups.
  4. Click Create.
Creating a Physical Device from the Device Manager Page
To manually create a physical device from the Device Manager page:
  2. Click the Actions menu and select Create Physical Device. The Create Physical Device modal page appears.
  3. In the Create Physical Device modal page, supply the following:
  1. Click Add to add the new physical device.
Managing Physical Devices Created in the User Interface
After an administrator manually creates a physical device, the device appears in the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface).
The new device can be managed like any physical device in Skylar One. However, the following caveats apply:
If you want to disable Auto-Update and disable Collection for the new device, see the details in the section on Editing Device Settings.
If you want to discover the device using the Discovery tool, see the section on Manually Re-Running Discovery for a Device.
Using a CSV File to Create Multiple Physical Devices
Skylar One allows users to manually create multiple physical devices simultaneously by uploading device data in a CSV file.
The fields supported differ based on whether you are uploading the CSV file from the Devices page or from the Device Manager page.
The following fields are supported if you are uploading the file from the Devices page:
From the Device Manager page, the same fields are instead labeled like this:
  • ip
  • organization
  • name
  • class_type
  • snmp_cred_id
  • collector_group
The explanations and examples in the rest of this section use the Devices page format. If you are uploading the CSV file from the Device Manager page, you should instead use the field labels listed here.
Skylar One generates an error if a required field is excluded from the CSV file or if non-supported fields (for example, hostname) are included in the CSV file.
The CSV file must contain a comma-separated header line that indicates the fields used, followed by comma-separated lines for each device. The CSV file must include the ip, organization, and deviceClassId fields at a minimum, and can include additional fields. You must enter the field names in lowercase with no space between field names. Because the field names must match the corresponding parameters in the API, you must enter the field names exactly as follows:
For example, to create two devices using only the required fields of IP address, organization, and device class ID, the CSV file must contain the following:
ip,organization,deviceClassId
10.2.9.42,1,9681
10.2.10.42,1,9681
To create "Device A" and "Device B" using all supported fields, the CSV file must contain the following:
ip,organization,name,deviceClassId,snmpCredId,collectorGroupId
10.2.9.42,1,Device A,9681,37,1
10.2.10.42,1,Device B,9681,37,1
Do not include spaces between the comma-separated values in the CSV file.
Creating Multiple Physical Devices Using a CSV File from the Devices Page
To manually create multiple physical devices using a CSV file from the Devices page:
  2. Click the down arrow icon () next to the Add Devices button and then select Create Physical Device From File. The Create a Physical Device From File modal appears.
  3. In the Create a Physical Device From File modal, click Browse Files, then select the desired CSV file.
  4. Click Create to import the CSV file and create the physical devices. If an error occurs, the error message appears in the Create a Physical Device From File modal. Otherwise, if the import is successful, the Devices page appears with the new devices added.
Creating Multiple Physical Devices Using a CSV File from the Device Manager Page
To manually create multiple physical devices using a CSV file from the Device Manager page:
  1. Click the Actions menu and select Create Physical Devices From File. The Bulk Physical Device modal appears.
  2. In the Bulk Physical Device modal, click Browse, then select the desired CSV file.
  3. Click Import to import the CSV file and create the physical devices. The Bulk Physical Device modal displays log messages as each new physical device is created or if any errors occurred while adding a device.
  4. If an error occurred importing a device, select the wrench icon () for a that device to open the manually edit the settings for that device. The Creating a Physical Device in the User Interface section describes the user interface for adding a single device manually.
Managing Physical Devices Created Using a CSV File
You can use the Skylar One user interface to manage the newly created devices. For details, see the section Managing Physical Devices Created in the User Interface.
Using the API to Create a Physical Device
Creating a Physical Device with the API
You can use a POST request to the /device API resource to manually create a physical device in Skylar One.
The following fields are supported:
Example
The following example creates a physical device using the API:
curl -v -H 'X-em7-beautify-response:1' -H 'accept:application/json' -H 'content-type:application/json' -u 'em7admin:<password>' "http://192.168.10.205/api/device" -d '{"name": "example-device", "organization": "\/api\/organization\/0", "class_type": "\/api\/device_class\/1547", "ip": "10.20.7.31", "snmp_cred_id": "\/api\/credential\/snmp\/69","collector_group": "\/api\/collector_group\/1"}'
Field Name Value
name example-device
organization /api/organization/0
class type /api/device_class/1547
ip 10.20.7.31
snmp_cred_id /api/credential/snmp/69
collector_group /api/collector_group/1
The API returns an HTTP 201 response. The response body includes the newly created device record in JSON format.
The X-EM7-status-message header includes the device ID of the newly created device.
< HTTP/1.1 201 Created:
< Server: nginx/1.10.0
< Date: Thu, 28 Jul 2016 16:50:12 GMT
< Content-Type: application/json
< Transfer-Encoding: chunked
< Connection: keep-alive
< X-EM7-Implemented-methods: GET,POST,PUT,DELETE
< X-Powered-By: ScienceLogic, Inc. - EM7 API/Integration Server
< X-EM7-Authenticated-account: /api/account/1
< Location: /api/device/33
< Cache-Control: private, no-cache, must-revalidate, no-store, max-age=0, post-c heck=0, pre-check=0
< X-EM7-status-message: Device :33 added successfully
< X-EM7-status-code: CREATED
< Vary: Accept-Encoding
"ip": "10.20.7.31",
"hostname": null,
"snmp_w_cred_id": null,
"collector_group": "\/api\/collector_group\/1",
The rest of the response includes a list of all device fields, each set to its default value.
Managing Physical Devices Created with the API
You can use the ScienceLogic user interface to manage the newly created device. For details, see the section Managing Physical Devices Manually Created in the User Interface.
You can also use the ScienceLogic API to manage the newly created device. For more information, ask your ScienceLogic contact for access to the ScienceLogic API documentation.
Available Actions for the Device Resource
Action URI Method
View/search/filter the list of devices. /device GET
Create a new physical device. Unlike for virtual device, must specify a valid IP address and the organization ID for an existing organization.
/device
POST
Create a new virtual device. /device POST
View the properties of a device. /device/X GET
Update the properties of a device. /device/X POST
Replace the properties of a device. /device/X PUT
Delete a device. /device/X DELETE
View/search/filter the list of Dynamic Applications aligned with a device. /device/X/aligned_app GET
Align a Dynamic Application with a device. /device/X/aligned_app POST
View the collection status and associated credential for a Dynamic Application aligned with a device. /device/X/aligned_app/X GET
Update the collection status and associated credential for a Dynamic Application aligned with a device. /device/X/aligned_app/X POST
Unalign a Dynamic Application from a device. /device/X/aligned_app/X DELETE
View/search/filter the list of available configuration data for a device. /device/X/config_data GET
View meta-data about data collected from a device by a configuration Dynamic Application. /device/X/config_data/X GET
View data collected from a device by a configuration Dynamic Application. /device/X/config_data/X/data GET
View historical snapshots of data collected from a device by a configuration Dynamic Application. /device/X/config_data/X/snapshots GET
View general information collected from a device. /device/X/detail GET
View/search/filter the list of credentials aligned with a device. /device/X/device_app_credentials GET
View the threshold settings for a device. /device/X/device_thresholds GET
Update the threshold settings for a device. /device/X/device_thresholds POST
Replace the threshold settings for a device. /device/X/device_thresholds PUT
Revert all device thresholds to the global default values. /device/X/device_thresholds DELETE
Add an interface record to a device. /device/X/interface POST
View/search/filter the list of interfaces for a device. /device/X/interface GET
View the properties of an interface for a device. /device/X/interface/X GET
Update the properties of an interface for a device. /device/X/interface/X POST
Replace an interface record associated with a device. /device/X/interface/X PUT
Delete an interface record associated with a device. /device/X/interface/X DELETE
View data for an interface. /device/X/interface/X/interface_data/data GET
View daily normalized data for an interface. /device/X/interface/X/interface_data/normalized_daily GET
View hourly normalized data for an interface. /device/X/interface/X/interface_data/normalized_hourly GET
View/search/filter the list of logs associated with a device. /device/X/log/ GET
View a log associated with a device. /device/X/log/X GET
Add a note to a device. /device/X/note/ POST
View/search/filter the list of notes associated with a device. /device/X/note/ GET
View a note associated with a device. /device/X/note/X GET
Update a note associated with a device. /device/X/note/X POST
Replace a note associated with a device. /device/X/note/X PUT
View/search/filter the list of files associated with a device note. /device/X/note/X/media GET
Get a media file associated with a device note. /device/X/note/X/media/X GET
Add a media file to a device note. /device/X/note/X/media/X PUT
View meta-data about a media file associated with a device note. /device/X/note/X/media/X/info GET
View/search/filter the list of available Dynamic Application data for a device. /device/X/performance_data GET
View data for a Dynamic Application aligned to a device. /device/X/performance_data/X/data GET
View daily normalized data for a Dynamic Application aligned to a device. /device/X/performance_data/X/normalized_daily GET
View hourly normalized data for a Dynamic Application aligned to a device. /device/X/performance_data/X/normalized_hourly GET
View/search/filter the list of available vitals data for a device. /device/X/vitals GET
View availability data for a device. /device/X/vitals/availability/data GET
View daily normalized availability data for a device. /device/X/vitals/availability/normalized_daily GET
View hourly normalized availability data for a device. /device/X/vitals/availability/normalized_hourly GET
View data for a file system on a device. /device/X/vitals/fsX/data GET
View daily normalized data for a file system on a device. /device/X/vitals/fsX/normalized_daily GET
View latency data for a device. /device/X/vitals/latency/data GET
View daily normalized latency data for a device. /device/X/vitals/latency/normalized_daily GET
View hourly normalized latency data for a device. /device/X/vitals/latency/normalized_hourly GET
Apply a device template to a device. /device/X Post a /device_template resource.
