Hardware and Software
The Device Hardware page (Devices > Hardware) displays a list of all hardware components from all devices that have been discovered by Skylar One (formerly SL1), while the Software Titles page (Devices > Software) displays a list of all software on all devices discovered by Skylar One.
Skylar One can automatically populate inventory lists of hardware components and installed software using data collected by configuration Dynamic Applications. To do so, those Dynamic Applications must have Inventory Link collection objects set to Hardware Components or Software Titles.
For more information about Inventory Link collection objects, see the section on Collection Objects.
Viewing the List of All Discovered Hardware Components
The Device Hardware page allows you to easily view details on device components and generate reports on device components. The Device Hardware page can display information about the following types of components:
  • CPU
  • Disk
  • File system
  • Memory
  • Virtual Memory
  • Components
To view a list of hardware components in the Device Hardware page:
  1. Go to the Device Hardware page (Devices > Hardware).
  2. The Device Hardware page displays the following for each hardware component:
To sort the list of hardware, click on a column heading. The list will be sorted by the column value, in ascending order. To sort the list by descending order, click the column heading again.
  • Device Name. Name of the device associated with the hardware component.
  • Organization. Name of the organization associated with the hardware component.
  • IP Address. IP address of the device or of the hardware component, if applicable.
  • Device-Class / Device Sub-class. The manufacturer (device class) and type of device (sub-class). The Device-Class/Sub-Class is automatically assigned during auto-discovery, at the same time as the Category.
  • Comp Type. Description of the hardware component. The choices are:
  • CPU
  • Disk
  • File system
  • Memory
  • Swap
  • Components
  • Description. Description of the hardware component.
  • Type. Further categorization of the hardware component.
  • Size. If applicable, the size of the hardware component.
  • Hidden. For file systems, specifies whether or not the component is "hidden", meaning "not monitored" by Skylar One.
  • Comp ID. Unique, numeric ID assigned to the component by Skylar One.
  • Tools. For each hardware component, one or more of the following tools are available:
  • View asset record (). This icon appears if an asset record has already been defined for the device. This icon leads to the Asset Properties page, where you can view the asset record for the device.
  • Checkbox (). Applies the action in the Select Actions drop-down menu to the hardware component. To select all the checkboxes, select the checkmark icon above the list of hardware components.
Generating a Report for Multiple Hardware Components on Multiple Devices
The Device Hardware page allows you to generate an Excel report that contains all the information on the Device Hardware page. You can immediately view the information or save it to a file for later viewing.
To generate a report on all hardware components in Skylar One:
  2. In the Device Hardware page, click the Report button.
  3. When prompted, specify whether you want to save the report to your local computer or open the report immediately.
Hiding a File System
When you hide a file system:
  • Skylar One stops collecting information about the file system.
  • Skylar One does not generate events about the file system.
  • Skylar One does not monitor the file system for thresholds (defined in the Device Thresholds and Global Threshold Settings pages).
  • Skylar One does not include the file system in the Device Summary page.
  • Skylar One does not include the file system in file system reports in the Device Performance page.
  • If the NFS Detection Disable checkbox is selected in the Behavior Settings page (System > Settings > Behavior), NFS file systems are automatically hidden during discovery.
  • File systems of type "iso9660" are automatically hidden during discovery.
  • File systems for which the storage size is not reported or the storage size is less than 1024 MB are automatically hidden during discovery.
  • File systems of type "Other" are automatically hidden during discovery.
Hidden file systems are not monitored, only discovered. If the file system is monitored by a Dynamic Application, alerts or events can still be generated for a hidden file system. This only applies to internal collection alerts. For more information, see Knowledge Base article:https://support.sciencelogic.com/s/article/4025
  2. Filter the list to display only Comp Type of "file system".
  3. Select the checkbox for one or more file systems you would like to hide.
  4. From the Select Actions field (in the lower right), select Hide File Systems.
  5. Click the Go button.
  6. Each selected file system will be hidden in Skylar One.
  3. Select the checkbox for one or more file systems you would like to unhide.
  4. From the Select Actions field (in the lower right), select Unhide File Systems.
  6. Skylar One will resume collection for each selected file system and will include each selected file system in the Device Summary and Device Performance pages.
Changing Thresholds for One or More File Systems
From the Device Hardware page (Devices > Hardware), you can change the Major and Critical thresholds for one or more file systems. These thresholds appear on the Device Thresholds page (Devices > Classic Devices > wrench icon > Thresholds, or Registry > Devices > Device Manager > wrench icon > Thresholds in the classic user interface). Changes made to file system thresholds from the Device Hardware page update the settings in the Device Thresholds page. Changes made to file system thresholds in the Device Thresholds page override thresholds defined in the Global Threshold Settings page (System > Settings > Thresholds).
  • Major Threshold. This threshold will trigger a "low disk space" event. The default threshold is 85%. When a file system has used more disk-space than the specified percentage, Skylar One will generate a "file system usage exceeded threshold" event with a status of "major". To disable this threshold, set the threshold to 0% (zero percent). When you disable a threshold, Skylar One does not generate an event for the threshold.
  • Critical Threshold. This threshold will trigger a "low disk space" event. The default threshold is 95%. When a file system has used more disk-space than the specified percentage, Skylar One will generate a "file system usage exceeded threshold" event with a status of "critical". To disable this threshold, set the threshold to 0% (zero percent). When you disable a threshold, Skylar One does not generate an event for the threshold.
To change a Major file system threshold:
  1. Find the file system for which you want to change the Major threshold. Select its checkbox.
  1. Select the checkbox for each additional file system for which you want to change the Major threshold.
  2. In the Select Action drop-down list, find Change Major Threshold and select a new threshold (between 0 -100).
  3. Select the Go button.
  4. Skylar One will change the Major threshold for each selected file system.
To change a Critical file system threshold:
  1. Find the file system for which you want to change the Critical threshold. Select its checkbox.
  2. Select the checkbox for each additional file system for which you want to change the Critical threshold.
  3. In the Select Action drop-down list, find Change Critical Threshold and select a new threshold (between 0 -100).
  4. Select the Go button.
  5. Skylar One will change the Critical threshold for each selected file system.
Viewing the List of All Discovered Software Titles
The Software page displays a list of all software on all devices discovered by Skylar One. From this page, you can view the list of software titles, generate an Excel report on all discovered software, or generate an exclusion report (that is, a report for a single software title that specifies devices where the software is installed and devices where the software is not installed.)
To view a list of all software discovered on all devices:
  1. Go to the Software page (Devices > Software).
  2. The Software page displays the following about each installed software title:
To sort the list of software, click on a column heading. The list will be sorted by the column value, in ascending order. To sort the list by descending order, click the column heading again.
  • Device Name. Name of the device where the software title is installed. For devices running SNMP or with DNS entries, the name is discovered automatically. For devices without SNMP or DNS entries, the device's IP address will appear in this field.
  • Organization. Organization associated with the software.
  • IP Address. IP address of the device where the software is installed.
  • Device Class / Sub-Class. The manufacturer (device class) and type of device (sub-class). The Device Class/Sub-Class is automatically assigned during auto-discovery.
  • Software Title. Name of the software.
  • Date of Install. Date the software was installed.
Viewing a List of Software Titles for a Single Device
The Software tab of the Device Investigator page
  • Name. Name of the software.
Viewing a List of Software Titles for a Single Device in the Classic Skylar One User Interface
To view the list of software installed on a single device:
  2. Find the device for which you want to view the list of installed software. Select the bar graph icon () for that device.
  3. In the Device Reports panel, select the Software tab. The Software Packages page appears.
  4. For each installed software title, the Software Packages page displays the following information:
  • Software Package Name. Name of the software.
Filtering the List of Software
You can filter the list of software titles in the Software Packages page. The list dynamically updates as you enter the regular expression to use as a filter.
  • In the Filter field, you must enter a regular expression. Skylar One will search for software package names that match the regular expression. You can use the following special characters in each filter:
  • * Match zero or more characters preceding the asterisk. For example:
  • % Match zero or more characters preceding the percent. This special character behaves in the same way as the asterisk.
Generating a Report on All Software on All Devices
From the Software Titles page (Devices > Software) you can generate a report on all, multiple, or a single software title in Skylar One. The report will contain all the information displayed in the Software Titles page.
To generate a report on all or multiple software titles in Skylar One:
  1. Go to the Software Titles page (Devices > Software).
  2. On the Software Titles page, click the Report button. The Export current view as a report modal appears:
    If you want to include only certain software titles in the report, use the "find while you type" fields at the top of each column. You can filter the list by one or more column headings. You can then select the Report button, and only the software titles displayed in the Software Titles page will appear in the report.
  3. In the Export current view as a report page, you must select the format in which Skylar One will generate the report. Your choices are:
  • Web page (.html)
  • Excel spreadsheet (.xlsx)
  • Acrobat document (.pdf)
  1. Click the Generate button. The report will contain all the information displayed in the Software Titles page. You can immediately view the report or save it to a file for later viewing.
Generating an Exclusion Report for a Single Software Title
From the Software Titles page you can generate Software Exclusion Reports. These reports can help administrators manage patches and software versions. Software Exclusions Reports are generated in .XLSX format.
A Software Exclusions Report displays the following:
  • Name of the software title and the date the report was generated.
  • List of all devices in Skylar One that have the software installed.
  • List of all devices in Skylar One that don't have the software installed. Skylar One includes only appropriate servers in this report. For example, Solaris servers would not appear in a report for a Windows 2000 patch.
  • The last row in the report displays:
  • Total number of devices in report.
  • Total number of device categories included in the report.
  • Total number of device classes included in the report.
  • Number of devices where software is installed.
  • Number of devices where software is not installed.
To generate a software exclusion report:
  • Go to the Device Software page (Devices > Software).
  • On the Software Titles page, find an instance of the software title you want to generate an exclusion report for.
  • Click its printer icon (). You will be prompted to save or view the generated report.
