The following sections describe how to configure and discover Cisco Application Centric Infrastructure (ACI) component devices for monitoring by Skylar One using the "Cisco: ACIPowerPack:
Prerequisites for Monitoring Cisco ACI
To configure the Skylar One system to monitor a Cisco ACI system using the "Cisco: ACIPowerPack, you must first:
  • Know the credentials (username and password) for a user account that has access to the API for the Cisco ACI system. The user account must have read-all access.
  • Ensure that the APIC in your ACI system supports TLS 1.1 or TLS 1.2. Skylar One does not support TLS 1.0.
Be advised, "read-all" access is no longer sufficient for use with the "Cisco: ACI Faults" Dynamic Application due to permissions updates from past Cisco: ACI versions. For more information, please refer to Cisco: ACI's documentation.
If the credentials for your account have been changed, the PowerPack will not recognize the new credentials. To recognize new credentials, you must manually delete the existing session from your Cisco ACI system. To do this, log in to your ACI system and go to System > Active Sessions. There are typically two sessions created by the Data Collector for each monitored APIC. Right-click on the existing sessions and select Delete. When the confirmation dialog box appears, confirm that you want to delete the session. Once all of the sessions are deleted, a new session is automatically established the next time your ACI Dynamic Applications run and your new credential will be recognized.
Recommended System Values
ScienceLogic recommends that you set the following values on your Cisco ACI system:
  • ACI HTTPS Throttle. 5 requests per second.
  • Web Session Timeout. 600 seconds or greater.
  • Web Session Idle Timeout. 600 seconds (default).
Configuring a Credential for a Cisco ACI System
To use the Dynamic Applications in the "Cisco: ACIPowerPack, you must first define a SOAP/XML credential in Skylar One. This credential allows Skylar One to collect data from your ACI system.
 You will need to create a separate credential for each APIC that you want to discover.
: If you are using a Skylar One system prior to version 11.1.0, the new user interface does not include the Duplicate option for sample credential(s). ScienceLogic recommends that you use the classic user interface and the Save As button to create new credentials from sample credentials. This will prevent you from overwriting the sample credential(s).
To configure a SOAP/XML credential for Cisco ACI, perform the following steps:
  2. Locate the "Cisco: ACI Example" sample credential, click its Actions icon () and select Duplicate. A copy of the credential appears.
  3. Click the Actions icon () for the "Cisco: ACI Example copy" credential copy and select Edit. The Edit Credential modal page appears.
  • Timeout. It is recommended that you set this value to 5 seconds or lower.
  • URL. Type "https://%D". You can type the IP address of the cluster where the APIC resides, but this is not recommended.
  • HTTP Auth User. Type the username for a user account that has read-all access to the APIC API.
  • HTTP Auth Password. Type the password for the username you entered in the HTTP Auth User field.
  • Embed Value [%1]. Type one or more IP addresses of the APICs from which Skylar One should not collect data. This field supports up to 64 characters, so you can provide only four IP addresses if they are under the 64-character limit. This field is required and cannot be left blank. If you do not want to skip any IPs, enter [].
  • Embed Value [%3]. If you want to specify the APIC precedence order, type the IP addresses of the APICs in your desired precedence order. When you do so, if the primary APIC being monitored becomes unavailable, Skylar One will use this order to determine the next APIC it should monitor instead. This field supports up to 64 characters, so you can provide only four IP addresses if they are under the 64-character limit. This field is required and cannot be left blank.
When entering IP addresses in the Embed Value [%1] or Embed Value [%3] fields, each IP address should be surrounded by quotation marks and include a comma and space between IP addresses. Additionally, the list of IP addresses should be surrounded by brackets. For example: ["198.18.133.200", "198.18.133.201", "198.18.133.202"]
When creating the discovery session, the first entry in the Embed Value [%3] field must be entered in the IP Address Discovery List field in the Discovery Session Editor.
Proxy Settings
You must complete the Proxy Settings fields only if you connect to Cisco ACI through a third-party proxy server. If you do not use a proxy to connect to Cisco ACI, then you can leave these fields blank.
  • Proxy Hostname/IP. Type the server's hostname or IP address.
  • Proxy Port.Type the port on the proxy server to which you will connect.
  • Proxy User. Type the username used to access the proxy server.
  • Proxy Password. Type the password used to access the proxy server.
  1. Click Save & Close.
Configuring a Credential for a Cisco ACI System in the Skylar One Classic User Interface
  1. Locate the Cisco: ACI Example Priority credential and then click its wrench icon (). The Edit SOAP/XML Credential modal page appears:
Basic Settings
  • URL. Type "%D". You can type the IP address of the cluster where the APIC resides, but this is not recommended.
SOAP Options
Proxy Settings
  • Hostname/IP. Type the server's hostname or IP address.
  • Port.Type the port on the proxy server to which you will connect.
  • User. Type the username used to access the proxy server.
  • Password. Type the password used to access the proxy server.
  1. Click Save As.
Creating a Cisco ACI Virtual Device
A virtual device is a user-defined container that represents a device or service that cannot be discovered by Skylar One. You can use the virtual device to store information gathered by policies or Dynamic Applications.
You must use this method if you are using the classic Skylar One user interface. If you are using the default Skylar One user interface (AP2), ScienceLogic recommends creating a virtual device and manually aligning the "Cisco: ACI APIC Communications Manager" Dynamic Application to the Cisco ACI virtual device, rather than creating a discovery session.
To create a virtual device that represents your Cisco ACI system:
  2. Click Actions and select Create Virtual Device from the menu. The Virtual Device modal page appears.
  • Device Class. Select Cisco Systems | ACI.
Manually Aligning the Cisco: ACI APIC Communications Manager Dynamic Application
After creating the Cisco Meraki virtual device, you must manually align the "Cisco: ACI APIC Communications Manager" Dynamic Application to the Cisco ACI virtual device.
To manually align the Cisco ACI Dynamic Application in the Skylar One classic user interface:
  2. Click the wrench icon () for your Cisco ACI virtual device.
  4. Click the Actions button and select Add Dynamic Application from the menu.
  5. In the Dynamic Application Alignment window, from the Dynamic Applications field, select the "Cisco: ACI APIC Communications Manager" Dynamic Application.
  6. In the Credentials field, select the Cisco ACI credential you created.
  7. Click Save to align the Dynamic Application with the Cisco ACI virtual device.
After aligning the "Cisco: ACI APIC Communications Manager" Dynamic Application, your Cisco ACI component devices will be discovered and classified.
Discovering a Cisco ACI System
To discover a Cisco ACI system, perform the following steps:
  1. On the Credentials page, locate and select the credential you created for the Cisco ACI system.
  • List of IPs/Hostnames. Type the IP address of the first controller listed in the Embed Value [%3] field of the SOAP/XML credential.
NOTE: In version 109 and later, the tenant's IP address will match the APIC used for the API calls. If failover occurs, the ACI root IP stays the same, but the tenants will get new IP addresses.
NOTE: If failover occurs during discovery of an ACI system, it will fail over to the next IP address in the Embed Value [%3] field.
Once the Dynamic Component Map tree is built out and the data is collected , if a user manually changes the name of the root device (for example, the virtual device), there will be new duplicate tenant devices created. Tenant device names have the root device name as the prefix, which leads to the creation of the duplicate devices. ScienceLogic does not recommend changing the root device once the full DCM tree is built out.
The initial discovery of a Cisco ACI system will align most Dynamic Applications; however, you will need to manually align the "Cisco: ACI IC UpTime" Dynamic Application for the internal collections data to be displayed on the Device Properties page (Devices > Classic Devices > wrench icon).
To manually align the "Cisco: ACI IC UpTime" Dynamic Application:
  • After the discovery session has completed, find the Cisco ACI device in the Devices page and click on it.
  • From the Device Investigator page for the Cisco ACI device, click the Collections tab.
  • Click Edit and then click Align Dynamic App. The Align Dynamic Application window appears.
  • Click Choose Dynamic Application. The Choose Dynamic Application window appears.
  • Select the "Cisco: ACI IC UpTime" Dynamic Application and click Select. The name of the selected Dynamic Application appears in the Align Dynamic Application window.
  • If a default credential is listed below the Dynamic Application and it is the credential you created, skip ahead to step 9. Otherwise, uncheck the box next to the credential name.
  • Click Choose Credential. The Choose Credential window appears.
  • Select the credential you created for your Cisco ACI device for the Dynamic Application and click the Select button. The name of the selected credential appears in the Align Dynamic Application window.
  • Click the Align Dynamic App button. When the Dynamic Application is successfully aligned, it is added to the Collections tab, and a confirmation message appears at the bottom of the tab.
It can take several minutes after the discovery session has completed for Dynamic Applications to appear on the Dynamic Application Collections page.
The "Cisco: Cisco: ACI IC Interface Inventory" and "Cisco: ACI IC Interface Performance" Dynamic Applications perform internal collections for interfaces and are a heavy load on the APIC. ScienceLogic does not recommend enabling these Dynamic Applications unless these collections are vital and physical discovery and merging of the components is not viable.
Discovering a Cisco ACI System in the Skylar One Classic User Interface
  • Go to the Discovery Control Panel page (System > Manage > Classic Discovery or System > Manage > Discovery in the classic user interface).
  • Click the Create button. The Discovery Session Editor page appears:
  • IP Address Discovery List. Type the IP address of the first controller listed in the Embed Value [%3] field of the SOAP/XML credential.
  • Other Credentials. Select the credential you created for the Cisco ACI system.
  • Optionally, supply values in the other fields in this page. For a description of the fields in this page, see the Discovery and Credentials section.
  • Click the Save button.
  • The Discovery Control Panel page will refresh. Click the lightning bolt icon () for the discovery session you just created.
  • In the pop-up window that appears, click the OK button. The page displays the progress of the discovery session.
  1. From the Device Properties page for the Cisco ACI system, click the Collections tab. The Dynamic Application Collections page appears.
  2. In the Dynamic Application Collections page, click the Action button and then select Add Dynamic Application from the menu. The Dynamic Application Alignment page appears.
  3. In the Dynamic Applications field, select Cisco: ACI IC UpTime.
  1. In the Credentials field, select the credential you created for the Cisco ACI system.
  2. Click the Save button.
  3. After aligning the Dynamic Application, click the Reset button and then click the plus icon (+) for the Dynamic Application. If collection for the Dynamic Application was successful, the graph icons () for the Dynamic Application are enabled.
Performing a Manual Failover
If you want to change the APIC being used by the PowerPack, you can perform a manual failover by editing your SOAP/XML credential. To do this:
  1. Locate the SOAP/XML credential you created and then click on its name to open the Edit Credential page.
  1. There are two ways to failover manually:
  • Type the IP address of the APIC that you no longer want to use in the Embed Value Embed Value [%1] field.
  • Edit the Embed Value [3%] field to change the order of the APIC IP addresses, making the first IP address in the list the APIC that you want to failover to.
  1. Click Save & Close. The next time the "Cisco: ACI APIC Communications Manager" Dynamic Application runs, the PowerPack will use the new APIC IP address specified.
Viewing Information About the ACI System
When Skylar One performs collection for the ACI cluster, Skylar One will create component devices for the components associated with the ACI system and align other Dynamic Applications to those component devices. Some of the Dynamic Applications aligned to the component devices will also be used to create additional component devices.
NOTE: If you delete a Tenant in a monitored device, that component device will still appear in Skylar One but the Dynamic Applications aligned to it will stop collecting data, and a message indicating "Failed Availability" will appear in the device log of its child component devices.
You can view all the devices, virtual devices, and component devices in the Cisco ACI system in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One. The Device Components page displays all root devices and component devices in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a Cisco ACI system, find the Cisco ACI root device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for a Cisco ACI device, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
