Configuring Cisco ACI Multi-Site Manager for Monitoring
The following sections describe how to configure and discover Cisco ACI Multi-Site Manager for monitoring by SL1 using the "Cisco: ACI Multi-Site Manager" PowerPack:
Prerequisites
Before you can monitor Cisco ACI Multi-Site Manager in SL1, you must do the following:
  • Your Data Collector must have API access to the Cisco ACI Multi-Site Manager Orchestrator
  • The API user needs permissions for "auth", "get token", and "poll" for metrics
Creating a Credential for Cisco ACI Multi-Site Manager
To configure SL1 to monitor Cisco ACI Multi-Site architecture, you must first create a SOAP/XML credential. This credential allows the Dynamic Applications in the "Cisco: ACI Multi-Site Manager" PowerPack to communicate with your Cisco ACI Multi-Site account.
To configure a SOAP/XML credential:
  2. Locate the Cisco: ACI MM Sample Credential credential, click its Actions icon () and select Duplicate. A copy of the credential appears.
  1. Click the Actions icon () for the "Cisco: ACI MM Sample Credential copy" credential and select Edit. The Edit Credential page appears:
  • URL. Specify the IP of the Cisco ACI Multi-Site web interface
  • HTTP Auth User. Enter the username for the Cisco ACI Multi-Site web interface
  • HTTP Auth Password. Enter the password for the Cisco ACI Multi-Site web interface
Creating a Credential for Cisco ACI Multi-Site Manager in the SL1 Classic User Interface
  2. Locate the Cisco: ACI MM Sample Credential credential, then click its wrench icon (). The Edit SOAP/XML Credential modal page appears.
Basic Settings
  1. Click the Save As button.
Creating a Cisco ACI Multi-Site Manager Virtual Device and Discovering Cisco ACI Multi-Site
To discover a Cisco ACI Multi-Site architecture, you must create a virtual device that represents the root device. A virtual device is a user-defined container that represents a device or service that cannot be discovered by SL1. You can use the virtual device to store information gathered by policies or Dynamic Applications.
If you have multiple Cisco ACI Multi-Site architecture you want to monitor, you should create a separate virtual device for each root device. You can also create different organizations for each architecture.
To create a virtual device that represents your Cisco ACI Multi-Site architecture:
  2. Click the Actions button and select Create Virtual Device from the menu. The Create Virtual Device modal page appears.
  • Device Name. Enter a name for the device. For example, you could enter "ACI Multi-Site" in this field.
  • Device Class. Select Cisco Systems | ACI Multi-Site Manager Cluster.
  • Collector. Select CUG.
  2. Once you have created the device, go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic SL1 user interface) and select the virtual device you created.
  3. In the Select Action menu, select MODIFY By Template and click Go.
  4. In the Device Template Editor window, select the Dyn Apps tab.
  5. Click the plus sign in the Subtemplate Selection pane.
  6. In the Dynamic Application Settings pane, select the "Cisco: ACI Multi-Site Manager Node Discovery" Dynamic Application.
  7. In the Credentials drop-down, select the "Cisco: ACI MM Sample Credential". Click Apply.
Once you have completed modifying the device template, discovery will run and the Dynamic Applications will be aligned.
  • After creating the virtual device and aligning the credential to the template, go to the Devices page and click on the ACI Multi-Site virtual device. From the Device Investigator page, click the Collections tab.
  • All applicable Dynamic Applications for the switch are automatically aligned during discovery and will appear in the Collections tab.
You should see the following Dynamic Applications aligned to the ACI Multi-Site virtual device:
  • Cisco: ACI Multi-Site Manager Component Counts
  • Cisco: ACI Multi-Site Manager Node Discovery
  • Cisco: ACI Multi-Site Manager Site Discovery
  • Cisco: ACI Multi-Site Manager Tenant Discovery
  • Cisco: ACI Multi-Site Manager Token
The following Dynamic Applications will automatically align to their corresponding device components:
  • Cisco: ACI Multi-Site Manager Node Configuration
  • Cisco: ACI Multi-Site Manager Site Config
  • Cisco: ACI Multi-Site Manager Site Performance
  • Cisco: ACI Multi-Site Manager Tenant Config
Verifying Discovery and Dynamic Application Alignment in the SL1 Classic User Interface
  • After creating the virtual device and aligning the credential to the template, go to the Device Manager page and click the wrench icon () for the ACI Multi-Site virtual device. From the Device Properties page, click the Collections tab. The Dynamic Application Collections page appears.
  • All applicable Dynamic Applications for the switch are automatically aligned during discovery.
The following Dynamic Applications will automatically align to their correspondent device components:
Viewing Component Devices
In addition to the Devices page, you can view the Cisco ACI Multi-Site Manager and all associated component devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by SL1 in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a Cisco ACI Multi-Site Manager, find the virtual device and click its plus icon (+):
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. SL1 automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for a Cisco ACI Multi-Site Manager device, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
