Introduction
This section describes how to monitor Cisco CloudCenter Suite services in SL1 using the Dynamic Applications in the "Cisco CloudCenter SuitePowerPack.
The "Cisco CloudCenter SuitePowerPack supports Cisco CloudCenter Suite version 5.1 and higher.
The following sections provide an overview of Cisco CloudCenter Suite and the "Cisco CloudCenter SuitePowerPack:
What is the Cisco CloudCenter Suite?
Cisco CloudCenter Suite is a comprehensive, enterprise-class multicloud orchestration and workflow management platform used for deploying and managing infrastructure and applications in data centers, private clouds, and public clouds. Cisco CloudCenter Suite 5.1 includes Cisco CloudCenter, now known as Workload Manager.
What Does the Cisco: CloudCenter Suite PowerPack Monitor?
The "Cisco CloudCenter SuitePowerPack lets you discover and collect configuration and performance data about CloudCenter Suite 5.1 deployments and their components. The "Cisco CloudCenter SuitePowerPack can monitor CloudCenter Manager version 5.1 and higher.
The "Cisco CloudCenter SuitePowerPack includes:
  • A sample credential you can use as a template to create your own Credentials to monitor CloudCenter Suite deployments
  • Dynamic Applications and Run Book Actions to discover, model, and monitor performance metrics and/or collect configuration data for the following CloudCenter Suite components:
  • CloudCenter Suite Action Orchestrator
  • CloudCenter Suite Workload Manager
  • CloudCenter Suite Cost Optimizer
  • Supported CloudCenter Suite Applications
  • Device classes for each of the CloudCenter Suite components that SL1 monitors
  • Event policies and corresponding alerts that are triggered when CloudCenter Suite components meet certain status criteria
  • Automation policies you can use to specify actions you want to run automatically in response to specific event conditions in SL1
Installing the Cisco: CloudCenter PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Cisco CloudCenter SuitePowerPack.
To align RabbitMQ with your Remote Cloud, you must install the "DockerPowerPack discover the swarm. You must also have the "AMQP: RabbitMQPowerPack installed.
