The following sections describe how to configure and discover Cisco Viptela resources for monitoring by Skylar One using the "Cisco: Viptela" PowerPack:
Prerequisite for Monitoring Cisco Viptela
To configure the Skylar One system to monitor Cisco Viptela resources using the "Cisco: Viptela" PowerPack, you must first know the credentials (username and password) for a user account that has access to the Cisco Viptela system. The user account must have read-all access.
To discover vEdge devices with only "valid" statuses, modify the "Cisco: Viptela vEdge Discovery" Dynamic Application's snippet arguments to filter by "valid" by changing the [*] section to use [?validity=='valid']. For example, the serialNumber's snippet argument uses the following: rest://dataservice/system/device/vedges&silo_args=jpath=data[?validity=='valid'].serialNumber|serialNumber
Configuring a Credential for Cisco Viptela
To configure Skylar One to monitor Cisco Viptela devices, you must first create a credential. This credential allows the Dynamic Applications in the "Cisco: Viptela" PowerPack to use your Viptela user account to retrieve information from the Viptela devices.
Configuring a Universal Credential for Cisco Viptela
To define a universal credential to access Cisco Viptela:
  2. Click Create New and select Create Cisco sdwan/viptela Credential. The Create Credential modal page appears.
  • Authentication type. Keep the default value (Token Authentication).
  • Authenticator Override. Keep the default value (AuthViptela).
  • Username. Type the Viptela account username.
  • Password. Type the Viptela account password.
  • URL. Type the URL and port for the Viptela system, using the following format: https://URL:443. For example, https://my.viptela.system:443.
Proxy Settings
Toggle on this field if you are using a proxy server to communicate with your Cisco Viptela account, enter the values in the fields listed below:
  • Proxy scheme type. Select http or https from the drop-down field.
  • Proxy Hostname/IP. Enter the hostname or the IP address associated with your device.
The HTTPS proxy scheme is only available using the new universal credential . Existing SOAP/XML credentials do not support switching the scheme.
Configuring a SOAP/XML Credential for Cisco Viptela
To configure a SOAP/XML credential to access Viptela:
  2. Locate and then click the Viptela Credential Example - SOAP/XML credential. The Edit Credential modal page appears:
  • Name. Type a name for the Viptela credential.
  • Method. Select POST.
  • HTTP Auth User. Type the Viptela account username.
  • HTTP Auth Password. Type the Viptela account password.
  1. For the remaining fields, use the default values, and then click the Save As button.
Configuring a Credential for Cisco Viptela in the Skylar One Classic User Interface
To configure Skylar One to monitor Cisco Viptela devices, you must first create a SOAP/XML credential. This credential allows the Dynamic Applications in the "Cisco: Viptela" PowerPack to use your Viptela user account to retrieve information from the Viptela devices.
  2. Locate the Viptela Credential Example - SOAP/XML credential, and then click its wrench icon (). The Edit SOAP/XML Credential modal page appears.
  • Profile Name. Type a name for the Viptela credential.
  • Timeout (seconds). Type "10".
Cisco Viptela Guided Discovery
You can use the Guided Discovery Framework process in Skylar One to guide you through a variety of existing discovery types in addition to traditional SNMP discovery. This process, which is also called "guided discovery", lets you choose a discovery type based on the type of devices you want to monitor. The Guided Discovery workflow includes a button for Cisco Viptela.
To run a Guided Discovery:
  2. Select the Cisco button. Additional information about the requirements for device discovery appears in the General Information pane to the right.
  1. On the Credential Selection page of the guided discovery process, select the Cisco Viptela universal credential that you configured, and then click Next. The Root Device Details page appears.
  • Root Device Name. Type the name of the root device for the Cisco Viptela root device you want to monitor.
  1. Click Next. Skylar One creates the Cisco Viptela root device with the appropriate Device Class assigned to it and aligns the relevant Dynamic Applications. The Final Summary page appears.
  1. Click Close.
This PowerPack uses the snippet framework in order to function. Not all values returned in an API call in a Dynamic Application may have a collection object. For more information about how collections can be modified, added, or deleted using the snippet framework, see the Snippet Framework documentation.
Creating a Cisco Viptela Virtual Device
Because the Cisco Viptela service does not have a static IP address, you cannot discover a Viptela device using discovery unless you use guided discovery. Instead, you must create a virtual device that represents the Viptela service. A virtual device is a user-defined container that represents a device or service that cannot be discovered by Skylar One. You can use the virtual device to store information gathered by policies or Dynamic Applications.
To create a virtual device that represents your Viptela service:
  • Device Class. Select Cisco Systems Viptela | vManage.
Aligning Dynamic Applications to the Virtual Device
A device template allows you to save a device configuration and apply it to multiple devices. The "Cisco: Viptela" PowerPack includes the "Cisco: Viptela vManage Template," which enables the Skylar One to align all Dynamic Applications to the root component device.
Configuring the Device Template
Before you can use the "Cisco: Viptela vManage Template," you need to configure the template so that each dynamic application in the template aligns with the credential you created earlier.
To configure the Viptela device template:
  1. Go to the Configuration Templates page (Devices > Templates).
  2. Locate the "Cisco: Viptela vManage Template" and click its wrench icon (). The Device Template Editor modal page appears.
  3. Click the Dyn Apps tab. The Editing Dynamic Application Subtemplates page appears.
  4. In the Credentials drop-down list, select the credential that you created for Viptela.
  5. Click the next Dynamic Application listed in the Subtemplate Selection section on the left side of the page and then select the credential you created in the Credentials field.
  6. Repeat step 5 until you have selected that credential in the Credentials field for all of the Dynamic Applications listed in the Subtemplate Selection section.
  7. Click Save.
Using the Device Template to Align Dynamic Applications to the Component Device
After you have configured the "Cisco: Viptela vManage Template" so that each dynamic application in the template aligns with the credential you created, you can use that template to align the Dynamic Applications to the root component device for Viptela.
To use the "Viptela vManage Template" to align Dynamic Applications:
  2. On the Device Manager page, select the checkbox for the root component device.
  1. In the Select Actions field, in the lower right, select the option MODIFY by Template and click the Go button. The Device Template Editor page appears:
  • In the Template drop-down list, select Cisco: Viptela vManage Template.
  • In the Credentials drop-down list, select the credential you created earlier.
  1. Click the Apply button, and then click Confirm to align the Dynamic Applications to the root component device.
Viewing Information About the Cisco Viptela System
You can view your Cisco Viptela devices in the following places in the user interface:
  • The Map tab of the Device Investigator for a selected device on the Devices page displays a map of that device and all of the devices with which it has parent-child relationships. Double-clicking any of the listed devices reloads the page to make the selected device the primary device.
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One. The Device Components page displays all root devices and component devices in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a Cisco Viptela device, find the device and click its plus icon (+).
  • The Classic Maps page (Maps > Classic Maps) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. From this page, go to Device Maps > Component to easily visualize and manage root nodes and their components. Skylar One automatically updates the Classic Maps as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for a Cisco Viptela device, go to the Classic Maps page and select the map from the list in the left NavBar. To learn more about the Classic Maps page, see the section on Maps.
