Discovery
The following sections describe how to discover Dell EMC Isilon storage arrays for monitoring by Skylar One using the "Dell EMC: IsilonPowerPack.
Discovering Dell EMC Isilon Component Devices
To model and monitor your Dell EMC Isilon storage arrays, you must run a discovery session to discover the storage arrays that Skylar One will use as the root devices for monitoring the Isilon storage system.
After the discovery session completes, the Dynamic Applications in the "Dell EMC Isilon" PowerPack automatically align to the storage array device, and then the PowerPack discovers, models, and monitors the remaining Isilon storage devices.
When the PowerPack is upgraded, some component devices may appear duplicated. You must manually remove existing component devices and then upgrade the PowerPack, or you will need to upgrade the PowerPack and then, manually remove the old components.
To create and run a discovery session that will discover an Dell EMC Isilon appliance:
  2. On the Credentials page, locate and select the SOAP/XML credential you created for Dell EMC Isilon appliances.
  3. Click Next. The Discovery Sessionpage of the Add Devices wizard appears.
  • List of IP/Hostnames. Type the IP address for the TSM appliance.
    • Select Device Template. If you configured a Dell EMC Isilon device template, select it here. Otherwise, leave the default selection.
Discovering Dell EMC Isilon Devices in the Classic User Interface
To model and monitor your Dell EMC Isilon storage arrays in the Skylar One classic user interface, you must run a discovery session to discover the storage arrays that Skylar One will use as the root devices for monitoring the Isilon storage system.
To discover the Isilon arrays that you want to monitor in the Skylar One classic user interface, perform the following steps:
  2. On the Discovery Control Panel, click the Create button. The Discovery Session Editor page appears.
  • IP Address/Hostname Discovery List. Type the IP address or hostname for the Isilon storage array or arrays that you want to discover.
  • SNMP Credentials. Select the SNMP credential that you created for Isilon devices.
  • Other Credentials. Select the SOAP/XML credential that you created for Isilon devices.
  • Duplication Protection. Select this checkbox.
  4. The Discovery Session window appears. After the devices are discovered, click the device icon () to view the Device Properties page for each device.
  1. After discovery has completed, click the device icon for the Isilon Storage Array device ().
  2. From the Device Properties page for the array device, click the Collections tab. The Dynamic Application Collections page appears.
  3. All applicable Dynamic Applications for the storage array device are automatically aligned during discovery.
You should see the following Dynamic Applications aligned to the storage array device:
Dynamic Application Credential Type
Dell EMC: Isilon Cluster Capacity Stats SOAP/XML
Dell EMC: Isilon Cluster Config SOAP/XML
Dell EMC: Isilon Cluster Stats SOAP/XML
Dell EMC: Isilon Cluster Smart Quota SOAP/XML
Dell EMC: Isilon Node Discovery SOAP/XML
  1. Click the Actions button and then select Add Dynamic Application. The Dynamic Application Alignment page appears.
  3. In the Credentials field, select the credential specified in the table.
  4. Click the Save button.
Viewing Dell EMC Isilon Component Devices
In addition to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic SL1 user interface), you can view the Isilon storage devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with Dell EMC Isilon, find the Isilon component device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for an Dell EMC Isilon arrays, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Views.
