Discovery
The following sections describe the steps required to discover Dell EMC XtremIO storage devices in Skylar One:
Discovering Dell EMC XtremIO Component Devices
To model and monitor your Dell EMC XtremIO storage devices, you must run a discovery session to discover the XtremIO Management Server (XMS) device and XtremIO clusters that Skylar One will use as the root devices for monitoring the applications.
After the discovery session completes, the Dynamic Applications in the "Dell EMC: XtremIOPowerPack automatically align to the XMS device, and then the PowerPack discovers, models, and monitors the remaining XtremIO storage devices.
To create and run a discovery session that will discover a Dell EMC XtremIO appliance:
  • Description. Optional. Type a short description of the discovery session. You can use the test in this description to search for the discovery session on the Discovery Session tab.
  2. On the Credentials page, locate and select the SOAP/XML credential you created for Dell EMC XtremIO appliances.
  3. Click Next. The Discovery Sessionpage of the Add Devices wizard appears.
  • List of IP/Hostnames. Type the IP address for the Dell EMC XtremIO appliance.
    • Select Device Template. If you configured a Dell EMC XtremIO device template, select it here. Otherwise, leave the default selection.
To model and monitor your Dell EMC XtremIO storage devices in the Skylar One classic user interface, you must run a discovery session to discover the XtremIO Management Server (XMS) device and XtremIO clusters that Skylar One will use as the root devices for monitoring the applications.
To discover the XtremIO devices that you want to monitor, perform the following steps:
  2. On the Discovery Control Panel, click the Create button.
  3. The Discovery Session Editor page appears. On the Discovery Session Editor page, define values in the following fields:
  • IP Address/Hostname Discovery List. Enter the IP address or hostname for the XtremIO storage device or devices that you want to discover.
  • SNMP Credentials. Select the SNMP credential that you are using for XtremIO.
  • Other Credentials. Select the Basic/Snippet or SOAP/XML credential that you created for your XtremIO storage devices.
  • Initial Scan Level. Select 5. Deep Discovery.
  • Detection Method & Port: Select TCP: 443 - https.
  • Duplication Protection. Select this checkbox.
  4. The Discovery Session window appears. After the devices are discovered, click the device icon () to view the Device Properties page for each device.
  1. After discovery has completed, click the device icon for the XMS device (). From the Device Properties page for the XMS device, click the Collections tab. The Dynamic Application Collections page appears.
  1. All applicable Dynamic Applications for the XMS device are automatically aligned during discovery.
You should see the following Dynamic Applications aligned to the XMS device:
Dynamic Application Credential Type
Dell EMC: XtremIO Cluster Discovery SOAP/XML
Dell EMC: XtremIO XMS Config SOAP/XML
  • Click the Action button and then select Add Dynamic Application. The Dynamic Application Alignment page appears.
  • In the Credentials field, select the credential specified in the table.
  • Click the Save button.
  • Repeat steps 1-4 for the other unaligned Dynamic Applications.
Viewing Dell EMC XtremIO Component Devices
In addition to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface), you can view the Dell EMC XtremIO storage devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with Dell EMC XtremIO, find the XtremIO component device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for an Dell EMC XtremIO devices, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Views.
