This section describes how to configure and discover Juniper Mist devices for monitoring by Skylar One using the "Juniper: Mist" PowerPack:
Configuring a Credential for Juniper Mist
To configure Skylar One to monitor Juniper Mist, you must first create a credential. This credential allows the Dynamic Applications in the "Juniper: Mist" PowerPack to connect with Juniper Mist devices. The "Juniper: Mist" PowerPack supports two credential types to use to connect with Juniper Mist devices:
Creating a Universal Credential for Juniper Mist
To define a universal credential to access Juniper Mist:
  2. Click Create New and select Create Juniper: mist api Credential. The Create Credential modal page appears.
  • All Organizations. Toggle on (blue) to align the credential to all organizations, or toggle off (gray) and then select one or more specific organizations from the from the Select the organizations the credential belongs to drop-down field to align the credential with those specific organizations.
  • Authentication Type. Keep the default value.
  • URL. Enter the Juniper Mist API URL that you want to use to retrieve device data.
  • API Key. Type the Juniper Mist API key.
  • SSL Peer Verify. Keep the default value of True to verify SSL certificates for API calls made using this credential.
  • CA Path. Enter the path to your Certificate Authority (CA) certificate.
  • Port. Keep the default value.
  • Timeout*. Keep the default value.
Proxy Settings
Toggle on this field (blue) if you are using a proxy server to communicate with your Juniper Mist account, then enter the values in the fields listed below:
  • Proxy Scheme. Select http or https from the drop-down field.
  • Proxy Hostname/IP. Enter the hostname or the IP address associated with your device.
Creating a SOAP/XML Credential for Juniper Mist
To configure Skylar One to monitor Juniper Mist devices, you must first create a SOAP/XML credential. This credential allows the Dynamic Applications in the "Juniper: Mist" PowerPack to communicate with Juniper Mist devices.
To configure a SOAP/XML credential to access Juniper Mist devices:
  2. Locate the Juniper Mist Example sample credential, click its Actions icon () and select Duplicate. A copy of the credential, called Juniper Mist Example copy appears.
  3. Click the Actions icon () for the Juniper Mist Example copy credential and select Edit. The Edit Credential modal page appears.
To learn more about aligning credentials and organizations, see Aligning Organizations With a Credential.
  • URL. Type the URL of your Juniper Mist API endpoint. The example URL uses "https://api.mist.com/api/v1/" as a default value , Please verify and modify the URL for your specific region.
The URL provided in the sample credential is the generic main Juniper Mist URL. There are several others, the choice of which is determined by your global region. For example, the URL for the EU region could be https://api.eu.mist.com/ For more information, see the Juniper Mist documentation at https://www.juniper.net/documentation/us/en/software/mist/automation-integration/topics/topic-map/api-endpoint-url-global-regions.html#reference_u5h_lrd_qjb .
  • Embed Value [%1]. Enter your Juniper Mist Organization ID.
  • HTTP Auth Password. Type the Juniper Mist API Key.
  • Embedded Password [%P]. Leave this field blank.
The PowerPack does not verify SSL certificates by default. You can enable SSL verification by selecting the SSLVERIFYPEER option from the CURL Options field and then selecting 1 from the drop-down field. Since the Mist API exists at a public URL with an authority-issued certificate, no further action is required.
Proxy Settings
You must complete the Proxy Settings fields only if you connect to Juniper Mist through a third-party proxy server. If you do not use a proxy to connect to Juniper Mist, then you can leave these fields blank.
  • Proxy Hostname/IP. Type the server's hostname or IP address.
  • Proxy Port.Type the port on the proxy server to which you will connect.
  • Proxy User. Type the username used to access the proxy server.
  • Proxy Password. Type the password used to access the proxy server.
HTTP Headers
  • Add a header. Click Add a header to connect a proxy server using HTTP or HTTPS.
    • proxy_url_protocol:http.Enter this schema if the proxy server does not have https configured.
    • proxy_url_protocol:https. Enter this schema if the proxy server has https configured.
Creating a SOAP/XML Credential for Juniper Mist in the Skylar One Classic User Interface
  2. Locate the Juniper Mist Example credential, then click its wrench icon (). The Edit SSH/Key Credential modal page appears:
Proxy Settings
HTTP Headers
  • Add a header. Click Add a header to connect a proxy server using http or https.
  1. Click the Save As button.
Configuring a Juniper Mist Device Template
A device template allows you to save a device configuration and apply it to multiple devices. The "Juniper: Mist" PowerPack includes the "Mist: Discovery Template". If you configure and apply this device template when you discover your Juniper Mist devices, Skylar One aligns the appropriate Dynamic Applications to the discovered Juniper Mist device.
To configure the "Mist: Discovery Template" device template:
  1. Go to the Configuration Templates page (Devices > Templates or Devices > Templates, or Registry > Devices > Templates in the classic user interface in the Skylar One classic user interface).
  1. Locate "Mist: Discovery Template" and click its wrench icon (). The Device Template Editor page appears.
  • Credentials. Select the credential that you created for Juniper Mist.
  1. Click the next Dynamic Application listed in the Subtemplate Selection section on the left side of the page and then select the Juniper Mist credential you created in the Credentials field.
  2. Repeat step 5 until the you have selected the Juniper Mist credential in the Credentials field for all of the Dynamic Applications listed in the Subtemplate Selection section.
  3. Click Save As.
Discovering Juniper Mist Devices
To discover Juniper Mist devices, must first create a virtual device, and then align Dynamic Applications to it.
Managing API Call Limits
The "Mist: AP Asset Configuration", "Mist: AP Discovery", and "Mist: AP Statistics" Dynamic Applications are disabled by default. Before enabling these Dynamic Applications, be advised that doing so may enable Skylar One to discover a very large number of access points (APs). Due to the structure of the Juniper Mist API, ScienceLogic polls the Juniper Mist API for AP data regardless.
Enabling or disabling any device-related Dynamic Applications will not change the number of API calls the PowerPack makes. You should expect the PowerPack to make one API call per 1000 total devices (APs, Switches, or Gateways) each polling cycle, as long as at least one Dynamic Application related to those device types is active.
For example, if you have 400 switches, 400 gateways, and 1200 APs, there will be two API calls each polling cycle, since there are 2000 total devices, and ScienceLogic fetches 1000 per API call.
ScienceLogic recommends following the Wireless LAN Controller (WLC) scaling for your collectors. If you want to discover more than 5,000 access points on a single collector, contact your ScienceLogic account representative for support.
Creating a Juniper Mist Virtual Device
To monitor your Juniper Mist devices, you must create a virtual device that represents the Juniper Mist root device. A virtual device is a user-defined container that represents a device or service that cannot be discovered by Skylar One. You can use the virtual device to store information gathered by policies or Dynamic Applications.
If you want to discover more than one Juniper Mist account, you must create a virtual device for each API key that you want to use.
To create a virtual device:
  1. Click Actions and select Create Virtual Device from the menu. The Virtual Device modal page appears.
  • Device Class. Select Mist | Mist Portal.
  2. Repeat these steps for each Juniper Mist API key that you want to use.
Manually Aligning Dynamic Applications to the Virtual Device
After creating the Juniper Mist virtual device, you must manually align the "Mist: Site Discovery" and "Mist: Organization Alarms and Events" Dynamic Applications to the Juniper Mist virtual device.
ScienceLogic recommends manually disabling the "Mist: API Cache Producer" Dynamic Application. If the Dynamic Application remains active and aligned to the root device, extra API calls will be made, and you may experience performance or rate limit issues.
To manually align the "Mist: Site Discovery" and "Mist: Organization Alarms and Events" Dynamic Applications:
  1. Go to the Devices page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface).
  1. Locate your Juniper Mist virtual device and click its name.
  3. Click the Edit button at the top of the page, then click the Align Dynamic App button.
  1. In the Align Dynamic Application modal, click Choose Dynamic Application.
  2. Locate "Mist: Site Discovery" and click Select.
  1. In the Align Dynamic Application modal, de-select the Use Device SNMP Credential box. Click the Choose Credential option that appears.
  2. Select the Juniper Mist credential you created and click Select.
  1. Click Align Dynamic App to align the Dynamic Application with the Juniper Mist virtual device.
  2. Repeat steps six through 10 for the "Mist: Organization Alarms and Events" Dynamic Application.
After aligning the Dynamic Applications, your Juniper Mist component devices will be discovered and classified.
Upon initial collection, you will see the "Cache empty or expired" event in Skylar One. This event is expected and will expire in 60 minutes, or it can be manually cleared. Once the cache producer finishes creating the cache, this event will no longer occur.
Manually Aligning Dynamic Applications to the Virtual Device in the Skylar One Classic User Interface
  1. Click the wrench icon () for your Juniper Mist virtual device.
  3. Click the Actions button and select Add Dynamic Application from the menu.
  1. In the Dynamic Application Alignment window, from the Dynamic Applications field, select the "Mist: Site Discovery" Dynamic Application.
  2. In the Credentials field, select the Juniper Mist credential you created.
  1. Click Save to align the Dynamic Application with the Juniper Mist virtual device.
  2. Repeat steps four through seven for the "Mist: Organization Alarms and Events" Dynamic Application.
Viewing Juniper Mist Component Devices
In addition to the Devices page, you can view your Juniper Mist devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One. The Device Components page displays all root devices and component devices in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a Juniper Mist device, find the device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for a Juniper Mist device, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
