This section describeshow to configure and discover Microsoft SQL Servers for monitoring in Skylar One using the "Microsoft: SQL Server EnhancedPowerPack.
If you already have Windows Server discovered, you might not need to create a new SQL Server credential or run a separate discovery session for SQL Servers if the PowerShell credential information is the same as that used for the Windows Server credential. In this scenario, you need only to install the "Microsoft: SQL Server EnhancedPowerPack and ensure that the Windows user account used in the credential has the appropriate permissions, as outlined in the Prerequisites section.
Prerequisites for Monitoring SQL Servers
To configure the Skylar One system to monitor SQL servers using the"Microsoft: SQL Server EnhancedPowerPack, you must first have the following information about the SQL Servers that you want to monitor:
  • IP addresses and ports for the SQL Servers
  • Username and password for a Windows user account with access to the SQL Servers
The SQL Servers that you monitor must be running PowerShell version 3.0 or later and need to have the SQL Server PowerShell (SQLPS) module installed. This SQLPS module is installed by SQL Server Management Studio. You can also install the SqlServer PowerShell module found here: https://www.powershellgallery.com/packages/Sqlserver/21.1.18218
The InvokeSqlCmd cmdlet must be present on the server and is available in the SQLPS and SqlServer PowerShell modules mentioned above. To determine if the proper cmdlets are available for this PowerPack to collect, run Get-Command Invoke-SqlCmd to see if the Invoke-SqlCmd cmdlet is installed.
In addition, the "Microsoft: SQL Server EnhancedPowerPack requires the following permissions for the user account used for monitoring:
  • SQL 2014 and newer versions require one of the following configurations:
  • The user account has an enabled login on every instance and database to be monitored, with CONNECT SQL, VIEW SERVER STATE, and CONNECT ANY DATABASE permission granted to the login on each instance. The login should have VIEW DATABASE STATE permission and DB_DATAREADER role granted on the 'master' database, and the DB_DATAREADER role granted on the 'msdb' database. The user account will also need VIEW ANY DEFINITION permissions which can be granted using the following SQL statement:
  • GRANT VIEW ANY DEFINITION TO [DOMAIN\USER]
  • The user account has the replmonitor role assigned for the distribution database to monitor Replication Agent. To assign, perform the following:
    1. Open the SQL Server Management Studio and connect to the SQL Server with replication.
    2. Go to the Security Properties for the monitoring user.
    3. Select User Mapping from the Select a page list.
    4. Select the checkbox to choose distribution in the Database column. Then select the checkbox to choose the replmonitor role for the user from the Database role membership panel.
    5. Click OK to apply the changes.
  • The user account has an enabled login on every instance and has the SYSADMIN role.
  • SQL 2012 requires one of the following configurations:
  • The user account has an enabled login on every instance and database to be monitored, with CONNECT SQL and VIEW SERVER STATE granted to the login on each instance. The login should also have VIEW DATABASE STATE permission and the DB_DATAREADER role granted on the 'master' database, and the DB_DATAREADER role granted on the 'msdb' database. In addition, every database in the instance should have CONNECT access granted to the login. The user account will also need VIEW ANY DEFINITION permissions which can be granted using the following SQL statement:
ScienceLogic provides a PowerShell script on that automates the permissions-granting that is required as stated above. The script is included with the "Microsoft: Windows Server" PowerPack.
  1. When you download the "Microsoft: SQL Server EnhancedPowerPack from the ScienceLogic Support site, a .zip file for the WinRM Configuration Wizard Script(winrm_configuration_wizard._v3.4.ps1) will be in the folder with the PowerPack's EM7PP file.
  2. Copy the WinRM Configuration Wizard Script .zip file to the Windows server where Microsoft SQL Server is installed and from which you will be collecting data. Unzip the file
  3. Using the credentials for an account that is a member of the Administrator's group, log in to the Windows server you want to monitor. You can log in directly or use Remote Desktop to log in.
  4. Copy the PowerShell script named winrm_configuration_wizard_v3.4 to the Windows server that you want to monitor with Skylar One.
  5. Right-click on the PowerShell icon and select Run As Administrator.
  6. At the PowerShell prompt, navigate to the directory where you copied the PowerShell script named winrm_configuration_wizard_v3.4.
  7. At the PowerShell prompt, enter the following to enable execution of the script:
Set-ExecutionPolicy -ExecutionPolicy Unrestricted -Scope Process -Force
NOTE: The execution policy setting persists only during the current PowerShell session.
  1. After the warning text, select Y.
NOTE: If your Windows configuration requires further steps to allow execution of the script, PowerShell will display prompts. Follow the prompts.
  1. To set the required, least-privileged permissions for the user account Skylar One will use to monitor all SQL Server instances and databases on the server, run the following script:
.\winrm_configuration_wizard_v3.4.ps1 -user <domain>\<username> -sql_only
Creating a PowerShell SQL Server Credential
To configure Skylar One to monitor SQL Servers, you must first create a PowerShell credential. This credential allows the Dynamic Applications in the "Microsoft: SQL Server EnhancedPowerPack to connect with an SQL Server. An example PowerShell credential that you can edit for your own use is included in the PowerPack.
To create a PowerShell credential for an SQL Server:
  2. Locate the SQL PowerShell - Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called SQL PowerShell - Example copy appears.
  3. Click the Actions icon () for the SQL PowerShell - Example copy credential and select Edit. The Edit Credential modal page appears.
  • Name. Type a new name for your SQL Server credential.
  • Timeout (ms). Type "18000".
  • Hostname/IP. Type "%D".
  • Port. Type "5985".
  • Username. Type the username for a Windows user with access to the SQL Server.
  • Password. Type the password for the Windows account username.
  • Account Type. Select Active Directory.
  • Use SSL (HTTPS) / Encrypted. Toggle this setting off.
    The user account whose username and password are provided in the credential must have certain permissions in all SQL Server instances that Skylar One will monitor. For a list of these permissions, see the Prerequisites section.
  • In Skylar One versions prior to 12.3.7, this field is labeled Encrypted. In versions 12.3.7 and above, it is labeled Use SSL (HTTPS).
  • Active Directory Host/IP. Specify the hostname or IP address of the Active Directory server that will authenticate the credential.
  • Active Directory Domain. Specify the domain where the monitored SQL Server resides.
  • Message Encryption Setting. Select whether Kerberos packages sent over PowerShell Remoting Protocol (PSRP) or Windows Remote Management (WinRM) are encrypted.
  • PowerShell Proxy Hostname/IP. If you use a proxy server in front of the Windows devices you want to communicate with, enter the IP address of the proxy server in this field. Otherwise, leave this field blank.
The PowerShell credential test is not supported by the "Microsoft: SQL Server Enhanced" PowerPack.
Creating a PowerShell SQL Server Credential in the Skylar One Classic User Interface
  1. Locate the SQL PowerShell - Example credential, and then click its wrench icon (). The Edit PowerShell Credential modal page appears.
  1. Complete the following fields.
  • Profile Name. Type a new name for your SQL Server credential.
  • Timeout. Type "18000".
  • Encrypted. Select no.
  • Active Directory Hostname/IP. Specify the hostname or IP address of the Active Directory server that will authenticate the credential.
  • Domain. Specify the domain where the monitored SQL Server resides.
  1. Click the Save As button.
SQL Cluster Monitoring
For SQL Clusters that only include SQL Instances in an Active/Active configuration, follow the steps in the Discovering SQL Servers section.
For SQL Clusters that include an SQL Instance in an Active/Passive configuration, additional discovery steps are required and listed below.
Skylar One's Active/Passive SQL Instance monitoring leverages the Skylar One GUID Component Identifier to allow the SQL Instance component and its child database components to move between SQL Servers during a failover. Adding this GUID Component Identifier on Skylar One versions prior to 8.12.1 will create a duplicate SQL Instance component on any already discovered SQL Servers. To prevent this, the GUID Component Identifier is not used by default. The "Enable Active Passive Cluster Failover" threshold in the "Microsoft: SQL Server Cache and Discovery" Dynamic Application provides the option to use the GUID Component Identifier when enabled. A value of "0" in the Threshold Value disables Active/Passive cluster failover; a value of "1" enables it.
To monitor SQL clusters:
  • Go to the Dynamic Applications Manager page (System > Manage > Applications).
  • Click the wrench icon () for the "Microsoft: SQL Server Cache and Discovery" Dynamic Application to open the Dynamic Applications Properties Editor page.
  • In the Thresholds tab, click the wrench icon () for the "Enable Active Passive Cluster Failover" threshold and change the Threshold Value to 1.
  • Click Save.
  • Follow the steps in the Discovering SQL Servers section on each Windows Server in the cluster.
When you discover SQL Servers in Skylar One, Skylar One auto-aligns a series of Dynamic Applications to discover, configure, and monitor the following SQL Server component devices:
  • SQL Servers
  • SQL Server instances
  • SQL Server databases
To discover SQL Servers and their component devices, perform the following steps:
  1. Click the Unguided Network Discovery Workflow button. Additional information about the requirements for discovery appears in the General Information pane to the right.
  1. On the Credentials page, locate and select the PowerShell credential you created.
  • List of IPs/Hostnames. Type the IP addresses or the range of IP addresses for the SQL Servers you want to discover.
Discovering SQL Servers in the Skylar One Classic User Interface
  • SQL Servers
  1. Click the Create button. The Discovery Session Editor page appears.
  • IP Address/Hostname Discovery List. Type the IP addresses or the range of IP addresses for the SQL Servers you want to discover.
  • Other Credentials. Select the PowerShell credential you created.
  • Discover Non-SNMP. Because the discovery session is not using an SNMP credential, select this checkbox.
  2. Click the Save button.
  3. The Discovery Control Panel page will refresh. Click the lightning bolt icon () for the discovery session you created.
Skylar One can automatically build relationships between SQL servers and other associated devices:
  • If you discover Windows server clusters using the Dynamic Applications in the "Microsoft: Windows Server Cluster" PowerPack version 100 or later, Skylar One will automatically create relationships between SQL servers and Windows server clusters.
SQL Cluster Node and SQL Cluster Instance Relationships
When discovering clustered SQL Server instances you will see multiple component device trees that represent the clustered SQL server. In these component device trees, the SQL servers are described as Nodes and the instances described as Roles.
NOTE: Discovering clustered SQL instances is the same process as discovering standalone SQL servers.
The following SQL cluster configurations are supported by the PowerPack. The relationship between the SQL cluster nodes and instances are described for each:
  • Active/Active. The default configuration. After discovery, the roles (instances) will be modeled in both nodes (servers). To determine which instances belong to a specific node, go to the Devices page and click on the node device. Click the Configs tab from the Device Investigator and click "Microsoft: SQL Server Instance Discovery" in the pane on the left. There you will see which roles (instances) belong to the node.
  • Active/Passive. To enable this configuration, you must find the "Microsoft: SQL Server Cache and Discovery" Dynamic Application in the Dynamic Applications Manager page (System > Manage > Dynamic Applications). Click its wrench icon () and then click the Thresholds tab. Click the wrench icon () for the Enable Active Passive Cluster Failover threshold object. In the Override Threshold Value drop-down, select Enabled and then click Save. This configuration is more intuitive, as the roles (instances) will be modeled only under the node (server) that they belong to, and in the event of a failover the instances will move between nodes.
NOTE: Nodes that have been stopped will not be discovered.
Viewing SQL Server Component Devices
In addition to the Devices page, you can view the SQL Server and all associated component devices in the following places in the user interface:
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a SQL Server, find the server and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This page makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for a SQL Server, go to the Component Map page and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Maps.
