Configuring Inbound CloudWatch Alarms
The following sections describe the CloudWatch alarm Event Policies that are included in the "Amazon Web Services" PowerPack and information about configuring CloudWatch and Skylar One to generate events based on CloudWatch alarms:
CloudWatch Alarm Event Policies
Amazon CloudWatch is a service that allows you to monitor your AWS resources and applications in near real-time. You can use CloudWatch to collect and track metrics, and use CloudWatch alarms to send notifications or automatically trigger changes to the resources being monitored based on rules that you define.
In addition to Skylar One collecting metrics for AWS instances, you can configure CloudWatch to send alarm information to Skylar One via API. Skylar One can then generate an event for each alarm.
The "Amazon Web Services" PowerPack includes an "AWS: CloudWatch Alarms Performance" Dynamic Application. This Dynamic Application monitors CloudWatch alarms and associates the alarms with the appropriate AWS component devices, if applicable. If an appropriate component device does not exist in Skylar One or cannot be determined, the alarm is instead associated with the component device for the AWS account.
The performance data collected by the "AWS: CloudWatch Alarms Performance" Dynamic Application is metadata intended to give general insight into the alarm activity the Dynamic Application is processing. This metadata can help identify overall trends, but users should be cautioned that the data presented can be imprecise in certain scenarios, such as when the Dynamic Application is being run in debug mode while data is still being collected.
The "Amazon Web Services" PowerPack also includes several pre-defined event policies for CloudWatch alarms:
Alarm Type Alarm State Event Policy Name Description Event Source Severity
Action Failed AWS: CloudWatchAlarm_Action_Failed An Amazon CloudWatch alarm action has failed. API Major
Action InProgress AWS: CloudWatchAlarm_Action_InProgress An Amazon CloudWatch alarm action is in progress. API Notice
Action Succeeded AWS: CloudWatchAlarm_Action_Succeeded An Amazon CloudWatch alarm action has succeeded. API Notice
Configuration Update Configuration Update AWS: CloudWatchAlarm_ConfigurationUpdate A ConfigurationUpdate alarm type is received. API Notice
Status Update Alarm AWS: CloudWatchAlarm_StateUpdate_Alarm A CloudWatch alarm transitions to an "Alarm" state. API Major
Status Update Insufficient Data AWS: CloudWatchAlarm_StateUpdate_InsufficientData A CloudWatch alarm transitions to an "Insufficient Data" state. API Notice
Status Update OK AWS: CloudWatchAlarm_StateUpdate_OK A CloudWatch alarm transitions to an "OK" state. API Healthy
These events are aligned to AWS Account component devices in the following way:
  • If the CloudWatch alarm is configured on a device that is discovered in Skylar One, then the event in Skylar One will be aligned with the component device for that instance.
  • If the CloudWatch alarm is configured on a device that is either not discovered or not supported by CloudWatch, or if Skylar One cannot determine a correct component device, then that alarm will be aligned to the Account component device.
The "AWS: CloudWatch Alarms Performance" Dynamic Application and related Event Policies are disabled by default. If you want Skylar One to monitor CloudWatch alarms and generate events about them, you must enable the Dynamic Application and Event Policies. You must also configure the Dynamic Application to specify which types of alarms you want to monitor.
For more information about enabling and configuring the "AWS: CloudWatch Alarms Performance" Dynamic Application, see the Configuring the "AWS: CloudWatch Alarms Performance" Dynamic Application section. For more information about enabling the CloudWatch alarms Event Policies, see the Enabling CloudWatch Alarm Events in the ScienceLogic Platform section.
Because the AWS services make new data points available at varying time intervals, there might be a difference in the data points collected by Skylar One when compared to data presented in CloudWatch at a given time. The difference between Skylar One and CloudWatch is typically less than 1%.
If an event expires and the CloudWatch alarm in AWS is still in an "Alarm" state, Skylar One will not generate any additional CloudWatch events unless that CloudWatch alarm changes states in AWS.
Creating Custom CloudWatch Metrics
A CloudWatch alarm watches a single metric and performs one or more actions based on the value of the metric relative to a threshold over a number of time periods. A CloudWatch metric consists of the following elements:
  • A namespace, such as AWS/EC2
  • A metric name, such as CPUUtilization
  • A value, such as 42
  • A dimension that identifies a particular resource instance, such as {'Name': 'InstanceId', 'Value': 'i-0a6a989bb8d57b074'}
For a complete list of supported CloudWatch Metrics and Dimensions, see https://docs.aws.amazon.com/AmazonCloudWatch/latest/monitoring/CW_Support_For_AWS.html.
The "Amazon Web Services" PowerPack uses the metric dimensions identified in an alarm to associate the alarm message to a particular ScienceLogic component device. The following table lists the services that are currently supported and the dimensions used to associate an alarm to a component device:
AWS Service Dimension
API Gateway
'ApiName' | 'ApiName | Stage'
NOTE: ScienceLogic recommends that you create API Gateways with unique names within the same region.
ApplicationELB 'LoadBalancer' | 'TargetGroup'
CloudFront 'DistributionId'
Direct Connect 'ConnectionID'
DynamoDB 'TableName'
EBS 'VolumeId'
ECS 'ClusterName' | 'ServiceName'
EC2 'InstanceId' | 'AutoScalingGroupName'
EKS Cluster 'ClusterName'
ElasticBeanstalk 'EnvironmentName'
ElastiCache
'CacheClusterId'
NOTE: Alarms for this service will be associated with the component device for the AWS account.
ElasticMapReduce 'JobFlowId'
ELB 'LoadBalancerName'
Glacier
'VaultId'
NOTE: This service is not supported by CloudWatch. You must define a custom metric and publish the metric to the CloudWatch service using an agent toolkit or the AWS command-line interface.
Lambda
'FunctionName', 'Resource', 'Version', 'Alias', 'Executed Version'
NOTE: Alarms "across all functions" for this service will be associated with the component device for the AWS account. Alarms "by function name" will be aligned to a specific Lambda function.
NetworkELB 'LoadBalancer' | 'TargetGroup'
OpsWorks 'StackId' | 'InstanceId'
RDS
'DBInstanceIdentifier'
Redshift
'ClusterIdentifier'
Route53 'HealthCheckId'
Shield
'ShieldService'
NOTE: CloudWatch alarms are available only for Shield Advanced Services.
SNS 'TopicName'
SQS 'QueueName'
StorageGateway 'GatewayId' | 'VolumeId'
S3 'BucketName'
WAF 'WebACLId'
AWS enables users to create custom metrics for these services and then publish those metrics to CloudWatch using the AWS command-line interface (CLI) or an application programming interface (API). The Dynamic Applications in the "Amazon Web Services" PowerPack can then collect data for these custom AWS metrics (which are not in the "AWS" cloud namespace).
For the "Amazon Web Services" PowerPack to collect data for these custom metrics, you must enable certain Dynamic Applications that are disabled by default. For more information, see the Enabling Custom Metrics Collection in the ScienceLogic Platform section.
When creating a custom metric, it is important that the metric is correctly formed. For Skylar One to align a custom metric to a particular ScienceLogic component device, the following must be true:
  • The metric namespace must include the service being tracked.
For example, MyVendorName/EC2 would be a valid namespace that the "Amazon Web Services" PowerPack could use to identify the EC2 service for a tracked metric.
  • The dimension must include one or more of the dimensions listed in the preceding table. The dimension enables Skylar One to identify which device to associate with the alarm.
For example, if the dimension included {'Name': 'InstanceId', 'Value': 'i-0a6a989bb8d57b074'}, this would identify the EC2 component. Other dimensions are permitted, but 'InstanceId' is necessary to locate the EC2 instance.
If the component device was an AutoScaleGroup component that is also under the EC2 service, then the dimension might look like this: {'Name': 'AutoScalingGroupName', 'Value': 'Y1Z55ZJ390UP'}.
If the CloudWatch event cannot align to a particular ScienceLogic component device, it will instead align to the component device for the AWS account.
Configuring CloudWatch to Send Alarms for a Metric
To configure CloudWatch to send alarms to Skylar One for a metric, perform the following steps:
  1. Open a browser session and go to aws.amazon.com.
  1. Click My Account and then select AWS Management Console. If you are not currently logged in to the AWS site, you will be prompted to log in.
  1. In the AWS Management Console, under the Management Tools heading, click CloudWatch.
  2. Click the Browse Metrics button.
  3. Select the metric for which you want CloudWatch to send alarms.
  4. Select the instances for which you want CloudWatch to send alarms for this metric.
  1. Click the Create Alarm button. The Create Alarm page is displayed.
  1. Specify a Name and Description for the alarm.
  1. If you have previously configured an alarm for Skylar One, select the notification list for Skylar One in the Send notification to field. Otherwise, select the New list link to the right of the Send notification to field and supply values in the following fields:
  • Send notification to. Enter a name for the new notification list. If you add additional alarms, you can select the name you enter in this field instead of re-entering the email address.
  • Email list. Enter the email address to which you want CloudWatch notifications sent.
  1. Supply values in the other fields in this page as desired.
  2. Click the Create Alarm button.
  3. Log in to the email account you configured to receive email from the email alias.
  4. Open the confirmation email from Amazon and click the Confirm subscription link.
Enabling Custom Metrics Collection in Skylar One
AWS enables users to publish their own custom metrics to CloudWatch using the AWS command-line interface (CLI) or an application programming interface (API). The "Amazon Web Services" PowerPack includes Dynamic Applications that collect data for custom AWS metrics (which are not in the "AWS" cloud namespace). However, these Dynamic Applications are disabled by default and must be enabled for use.
To enable these Dynamic Applications:
  1. Click the wrench icon (wrench icon) for the "AWS: Custom Metrics" Dynamic Application. The Dynamic Applications Properties Editor page appears.
  2. In the Operational State field, select Enabled.
  3. Click the Save button.
  4. Repeat steps 1 - 4 for the "AWS: Custom Metrics Cache" Dynamic Application.
The "Amazon Web Services" PowerPack includes an "AWS: CloudWatch Alarms Performance" Dynamic Application that monitors CloudWatch alarms and associates the alarms with the appropriate AWS component devices, if applicable. This Dynamic Application must be enabled if you want Skylar One to generate CloudWatch alarm events.
If an appropriate component device does not exist in Skylar One or cannot be determined, the alarm is instead associated with the "Account" component device.
To enable the "AWS: CloudWatch Alarms Performance" Dynamic Application:
  1. Locate the "AWS: CloudWatch Alarms Performance" Dynamic Application and then click its wrench icon (wrench icon). The Dynamic Applications Properties Editor page appears.
  1. In the Operational State field, select Enabled.
  2. Click Save.
By default, the "AWS: CloudWatch Alarms Performance" Dynamic Application monitors only the "StateUpdate" type of CloudWatch alarms. If you want the Dynamic Application to also monitor "Action" and "ConfigurationUpdate" alarm types, you must configure the Dynamic Application to do so.
To configure the "AWS: CloudWatch Alarms Performance" Dynamic Application to monitor all CloudWatch alarm types:
  2. Click the Collections tab. The Collection Objects page appears.
  1. On the Collection Objects page, locate the "CloudWatch Alarms Collection Success" collection object and then click its wrench icon (wrench icon).
  1. In the Snippet field, select one of the following options:
  • cloudwatch_alarms_performance_StateUpdate_only. This option is selected by default. This snippet will only trigger events for State Update alarms.
  • cloudwatch_alarms_performance.This snippet triggers notifications if any alarm configuration is modified.
  • cloudwatch_alarms_statistics. This snippet will trigger events for all CloudWatch alarm types (Action, Configuration Update, and State Update).
If you want to monitor all CloudWatch alarm types, then select cloudwatch_alarms_performance in the Snippet field.
  1. Click Save. This Dynamic Application will be executed every 1 minute.
Enabling CloudWatch Alarm Events in Skylar One
The "Amazon Web Services" PowerPack also includes several pre-defined event policies for CloudWatch alarms. These Event Policies must be enabled if you want Skylar One to generate CloudWatch alarm events.
To enable the CloudWatch alarms Event Policies:
  1. Go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic user interface).
  1. Perform a search for "CloudWatch".
  1. Select the check boxes for the events you want to enable.
  2. Select Enable at the bottom of the screen.
To enable the CloudWatch alarms Event Policies in the Skylar One classic user interface:
  1. In the Event Policy Name filter-while-you-type field, type "CloudWatch".
  2. In the Select Action drop-down field, select ENABLE these Event Policies.
  3. Click Go.
Preserving CloudWatch Alarm Event Changes
If you have modified CloudWatch alarm event policies that are included in the "Amazon Web Services" PowerPack, those changes will be overwritten when the PowerPack is updated in your system. If you have modified event policies that are included in the PowerPack, you can:
  • Re-implement those changes after each update of the "Amazon Web Services" PowerPack.
  • Remove the content from the PowerPack on your system. When the "Amazon Web Services" PowerPack is updated in your system, updated versions of this content will not be installed on your system and your local changes will be preserved.
To remove event policies from the "Amazon Web Services" PowerPack on your system:
  2. Click the wrench icon (wrench icon) for the "Amazon Web Services" PowerPack. The Editing PowerPack page appears.
  3. In the left NavBar of the Editing PowerPack page, click Event Policies. The Embedded Event Policies and Available Event Policies panes appear.
  4. In the upper pane, click the delete icon () for each event policy that you want to remove from the "Amazon Web Services" PowerPack on your system.
