Customizing Automation Policies
This section describes how to customize automation policies using the automation actions in the "AWS Automated Troubleshooting" PowerPack.
Customizing an Automation Policy
  1. Search for the "AWS Automated Troubleshooting" automation policy you want to edit and click the wrench icon (wrench icon) for that policy . The Automation Policy Editor page appears.
  1. Complete the following fields as needed:
  • Organization. Select the organization that will use this policy.
  • Aligned Actions. This field includes the actions associated with the policies from the AWS Automated Troubleshooting  PowerPack. To add an action to the Aligned Actions field, select the action in the Available Actions field and click the right arrow (>>). To re-order the actions in the Aligned Actions field, select an action and use the up arrow or down arrow buttons to change that action's position in the sequence.
  1. Optionally, supply values in the other fields on the Automation Policy Editor page to refine when the automation will trigger.
  1. Click Save As.
The following table shows the automation policy, its default aligned events, and the automation action that runs in response to the events.
Automation Policy Name Aligned Events Automation Action
AWS Automated Troubleshooting: Get Console Output All events AWS Automated Troubleshooting: Get Console Output
AWS Automated Troubleshooting: Get Instance Status or Recommendation All events AWS Automated Troubleshooting: Instance Status or Recommendation
AWS Automated Troubleshooting: Monitor or Unmonitor Instance All events AWS Automated Troubleshooting: Monitor or Unmonitor Instance
The "AWS Automated Troubleshooting: Get Console Output Automation" policy will not work for output with a string size greater than 65k.
