This PowerPack requires the ScienceLogic Standard solution.
What is the AWS Automated Troubleshooting PowerPack?
The "AWS Automated Troubleshooting" PowerPack includes automation policies that enrich Skylar One events for Amazon Web Services devices by automatically gathering device information and recommendations.
Installing the AWS Automated TroubleshootingPowerPack
The "AWS Automated Troubleshooting" PowerPack requires Skylar One version 10.2.0 or later. For details on upgrading Skylar One, see the appropriate Skylar One Release Notes.
