Introduction to the Skylar Compliance Automation PowerPack
This section describes how to use the Skylar One automation policies, automation actions, and custom action types found in the "Skylar Compliance Automation" PowerPack. You can use this PowerPack to enrich Skylar One events for Skylar Compliance devices by automatically running diagnostic commands, and the command output is added to the Skylar One event log or associated incident.
This PowerPack requires the "Datacenter Automation Utilities" PowerPack, version 103 or later.
What is the Skylar Compliance Automation PowerPack?
The "Skylar Compliance Automation" PowerPack includes automation policies that enrich Skylar One events for Skylar Compliance devices (for example, from the "Skylar Compliance" PowerPack) by automatically running diagnostic commands. The command output is added to the Skylar One event log or associated incident.
The Skylar Compliance run book actions are executed on the Skylar One All-In-One Appliance or Data Collector.
In addition to using the standard content, you can use the content in the "Skylar Compliance Automation" PowerPack to:
  • Create your own automation policies that include the pre-defined actions that run different sets of diagnostic commands.
  • Use the supplied "Restorepoint: Generic Action type" custom action type to configure your own automation action by supplying a set of commands.
Contents of the PowerPack
This PowerPack includes the following features:
  • The "Restorepoint Connectivity" Dynamic Application, which validates the type of credentials used by Skylar Compliance
  • Run book automation policies:
    • Restorepoint Event Enrichment
    • Revert Restorepoint Backup
    • Start Restorepoint Backup
  • Run book action policies:
    • Restorepoint: Difference between Last Two Backups
    • Restorepoint: Link to Last Configuration Backup
    • Restorepoint: Recent Logs
    • Restorepoint: Revert Backup
    • Restorepoint: Start Backup
  • The "Restorepoint: Generic Action type" run book action type
  • The "Restorepoint Automation" credential
  • The "Restorepoint Devices" device group, which includes a dynamic rule that matches devices with aligned Dynamic Applications, including the "RestorepointConnectivity" Dynamic Application
Installing the Skylar Compliance Automation PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Skylar Compliance Automation" PowerPack.
You must install the"Datacenter Automation Utilities" PowerPack version 103 before using the "Skylar Compliance Automation" PowerPack.
Downloading and Compiling the Skylar Compliance MIB Files
After installing the PowerPack, you will need to download the following MIB files from Skylar Compliance and compile the MIB files in Skylar One:
  • RESTOREPOINT-APPLIANCE-MIB.txt
  • RESTOREPOINT-MIB.txt
You can access the Skylar Compliance MIB files from your Skylar Compliance system.
To download the MIB files in Skylar Compliance:
  1. In your Skylar Compliance system, go to the Systems Settings page (Administration > System Settings).
  2. Click the SNMP tab and navigate to the Download MIBs field.
  3. Click both of the MIB file names to download them to your local drive.
To compile the Skylar Compliance MIB files in Skylar One:
  1. Go to the MIB Compiler page (System > Tools > MIB Compiler) and click the Import button.
  2. In the MIB Import modal page, navigate to the location of the MIB file on your local computer and click the Import button. The new MIB file appears in the list of MIB files in the MIB Compiler page.
  3. Repeat steps 1-2 to upload the second MIB file.
  4. You must compile both MIB files before Skylar One can use them. To compile a MIB, click its lightning bolt icon (image of the lightning bolt icon).
  5. To enable Skylar Compliance to send trap events to Skylar One, go to Administration > System Settings > Logs/Alerts in the Skylar Compliance user interface and change the following:
  • SNMP Traps: Check this checkbox.
  • SNMP Server: Enter the IP address of the Skylar One All-In-One or Data Collector.
