Introduction to the Windows PowerShell Automations PowerPack
This section describes how to use the run book automation policies, run book actions, and custom action types found in the "Windows PowerShell Automations" PowerPack.
What is the Windows PowerShell Automations PowerPack?
The "Windows PowerShell Automations" PowerPack includes:
  • A custom action type for running PowerShell commands on remote devices
  • A device group with rules that include only Windows devices
  • A set of run book actions that run diagnostic commands on Windows systems via PowerShell
  • A set of run book automation policies that tie events from monitoring PowerPacks to the run book actions
The run book automation actions for this PowerPack are executed on the Skylar One All-In-One Appliance or Data Collector.
In addition to using the standard content, you can use the content in the "Windows PowerShell Automations" PowerPack to:
  • Create your own run book automation policies that include the pre-defined actions that run different sets of diagnostic commands.
  • Use the supplied "Execute PowerShell Request" custom action type to configure your own run book action by supplying a set of commands to be executed via PowerShell.
Version 105 and later of this PowerPack supports Python 3.6.
Installing the Windows PowerShell Automations PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Windows PowerShell Automations" PowerPack.
You must install the "Datacenter Automation Utilities" PowerPack version 201 or later before using this release of the "Windows PowerShell Automations" PowerPack.
The "Windows PowerShell Automations" PowerPack requires Skylar One version 12.1.2 or later. For details on upgrading Skylar One, see the appropriate Skylar OneRelease Notes.
Creating a Credential for Windows PowerShell
If you do not have the "Microsoft: Windows Server" PowerPack installed, you must create a credential that includes the username and password to communicate with your Windows devices.
To prepare your Windows systems for monitoring, follow the instructions in Configuring Windows Servers for Monitoring with PowerShell.
If you have the "Microsoft: Windows Server" PowerPack installed and configured, you may skip this section.
  2. Locate the Windows PowerShell - Example credential, click its Actions icon () and select Duplicate. A copy of the credential, called Windows PowerShell - Example copy appears.
  3. Click the actions icon () for the credential copy and select Edit. The Edit Credential modal page appears.
  • Name. Type a new name for your credential. Can be any combination of alphanumeric characters, up to 64 characters. This field is required.
  • Timeout (ms). Time, in milliseconds, after which Skylar One will stop trying to communicate with the authenticating server. For collection to be successful, Skylar One must connect to the authenticating server, execute the PowerShell command, and receive a response within the amount of time specified in this field. The default value is 10000.
Creating a Credential for Windows PowerShell in the Classic User Interface
