What is Cisco ESA?
Cisco Email Security Appliance (ESA) is a virtual, all-in-one appliance that provides protection against spam, malware, viruses, and other inbound and outbound email threats and annoyances.
What Does the Cisco: ESA PowerPack Monitor?
To monitor Cisco Email Security Appliances devices using Skylar One, you must install the "Cisco: ESA" PowerPack. This PowerPack enables you to discover and collect data about Cisco Email Security Appliances.
The "Cisco: ESA" PowerPack includes:
- Dynamic Applications to discover and monitor performance and configuration data for Cisco ESA devices
- Device classes for each of the Cisco ESA devices that Skylar One monitors
- Event policies that are triggered when Cisco ESA devices meet certain status criteria
- A device dashboard that displays performance data about Cisco ESA devices
Installing the Cisco: ESA PowerPack
