The following sections describe how to configure and discover Cisco HyperFlex data clusters for monitoring by Skylar One using the "Cisco: Hyperflex" PowerPack:
NOTE: The "Cisco: Hyperflex" PowerPack supports only HyperFlex API version 4.5 and later.
Prerequisites for Monitoring Cisco HyperFlex
To configure Skylar One to monitor Cisco HyperFlex using the "Cisco: Hyperflex" PowerPack, you must have the following information about the HyperFlex data clusters that you want to monitor:
  • The Hyperflex Cluster Management IP Address
  • SNMP community strings for the voice mailboxes
Creating a SOAP/XML Credential for Cisco HyperFlex
To configure Skylar One to monitor Cisco HyperFlex, you must first create a SOAP/XML credential. This credential allows the Dynamic Applications in the "Cisco: Hyperflex" PowerPack to connect with HyperFlex devices. An example SOAP/XML credential that you can edit for your own use is included in the "Cisco: Hyperflex" PowerPack.
NOTE: If you are using a Skylar One system prior to version 11.1.0, the default user interface (AP2) does not include the Duplicate option for sample credential(s). If you are using an older Skylar One system, ScienceLogic recommends that you instead use the classic user interface and the Save As button to create new credentials from sample credentials. This will prevent you from overwriting the sample credential(s).
To configure a SOAP/XML credential to access HyperFlex devices:
  2. Locate the "Cisco: HyperFlex - Example" sample credential, click its Actions icon (actions icon) and select Duplicate. A copy of the credential appears.
  3. Click the Actions icon (actions icon) for the "Cisco: HyperFlex - Example copy" credential copy and select Edit. The Edit Credential modal page appears:
  • Name. Enter a new name for the HyperFlex credential.
  • Method. Select POST.
  • URL. Enter the IP address of your HyperFlex cluster.
  • HTTP Auth User: Use the login credentials for the HyperFlex REST API Explorer:
  • For users with HyperFlex Data Platform 3.0 and prior versions, type "root"
  • For users with Hyperflex Data Platform 3.5 and later versions, type "admin"
  • HTTP Auth Password:
  • For users with HyperFlex Data Platform 3.0 and prior versions, enter the password for "root"
  • For users with HyperFlex Data Platform 3.5 and later versions, enter the HyperFlex administrator user's password
  • Proxy Hostname/IP. Leave this field blank.
  • Proxy Port. Keep the default value.
  • Proxy User. Enter the SSH username for the HyperFlex device(s).
  • Proxy Password. Enter the SSH password for the HyperFlex device(s).
Creating a SOAP/XML Credential for Cisco HyperFlex in the Skylar One Classic User Interface
  2. Locate the sample credential included in the "Cisco: Hyperflex" PowerPack, called Cisco: HyperFlex - Example, then click its wrench icon (wrench icon).
Basic Settings
  • Profile Name. Enter a new name for the HyperFlex credential.
Proxy Settings
  • Port. Keep the default value.
  • User. Enter the SSH username for the HyperFlex device(s).
  • Password. Enter the SSH password for the HyperFlex device(s).
  1. Click Save As.
Discovering Cisco HyperFlex Devices
To create and run a discovery session that will discover Cisco HyperFlex devices, perform the following steps:
  1. On the Credentials page, select the SOAP/XML credential that you created for Cisco HyperFlex.
  • List of IPs/Hostnames. Type the IP address(es) for the Cisco HyperFlex device(s) you want to discover.
Discovering Cisco HyperFlex Devices in the Skylar One Classic User Interface
  2. Click the Create button to create a new discovery session. The Discovery Session Editor page appears.
  • IP Address Discovery List. Enter the IP address(es) for the Cisco HyperFlex device(s) you want to discover.
  • SNMP Credential. Do not select a credential in this field.
  • Other Credentials. Select the SOAP/XML credential that you created for Cisco HyperFlex.
  1. You can enter values in the other fields on this page, but are not required to and can simply accept the default values. For more information about the other fields on this page, see the section on Defining an SNMP Credential.
  2. Click Save and then close the Discovery Session Editor window.
  3. The discovery session you created appears at the top of the Discovery Control Panel page. Click its lightning bolt icon () to run the discovery session.
  4. The Discovery Session window appears.
  5. When the Cisco HyperFlex data cluster is discovered, click its device icon () to view its Device Properties page.
Troubleshooting Known Issues
The following known issues affect version 103 of the Cisco: Hyperflex PowerPack:
  • The "Cisco: Hyperflex Service Configuration" Dynamic Application will stop collecting data when the "/rest/services" endpoint is deprecated.
  • In Skylar One (SL1) version 8.10.0, the following Minor events are displayed for the "Cisco: Hyperflex Resiliency Stats" Dynamic Application:
78:StorageProc1: Non-digits in oid with object id: 18882, did:4 in dynamic app:1625 when updating performance value (val:NA)
78:StorageProc1: Non-digits in oid with object id: 18876, did:4 in dynamic app:1625 when updating performance value (val:NA)
