What are Ancillary Cisco UC Devices?
Skylar One enables you to monitor ancillary Cisco UC devices, including Cisco Unified Border Element (CUBE)-enabled devices and Cisco Emergency Responder.
CUBE is a Session Border Controller that extends Session Initiation Protocol-based voice and video connectivity between networks. It can run on a variety of Cisco routers or can be deployed virtually.
Emergency Responder supplements the emergency 9-1-1 functionality offered by Cisco Unified Communications Manager (CUCM) by helping CUCM pinpoint the location of emergency callers.
What Does the Cisco: UC Ancillary PowerPack Monitor?
To monitor ancillary UC devices using Skylar One, you must install the "Cisco: UC Ancillary" PowerPack. The PowerPack includes:
- An example credential you can use as a template to create SSH/Key credentials to connect to the devices you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and/or collect configuration data for ancillary UC devices
- Device classes for each of the ancillary UC devices that Skylar One monitors
- Event policies that are triggered when ancillary UC devices meet certain status criteria
- A device dashboard that displays host resource and interface information about ancillary UC devices
Installing the Cisco: UC Ancillary PowerPack
Ensure that you are running version 12.1.0 or later of Skylar One before installing this PowerPack. For details on upgrading Skylar One, see the relevant Skylar One Platform Release Notes.
