Introduction
This section describes how to monitor Cisco Unified Communications (UC) Voice Operating System (VOS) applications in Skylar One using the "Cisco: UC VOS Applications" PowerPack.
What are Cisco UC VOS Applications?
The following Cisco UC applications and devices share the Cisco Voice Operating System (VOS):
  • Cisco Contact Center Express (CCX)
  • Cisco Unity Connection (CUC) servers
  • Cisco Hosted Collaboration Mediation for Fulfillment (HCM-F)
  • Cisco HCS Intelligent Loader
  • Cisco IM & Presence (IM&P) servers
  • Cisco Prime License Manager (PLM)
  • Cisco Emergency Responder
  • Cisco Prime Collaboration Deployment (PCD) servers
  • Cisco SocialMiner
In the past, Cisco labeled VOS as "Cisco Unified Communications Operating System" and "Cisco Unified Operating System."
What Does the Cisco: UC VOS Applications PowerPack Monitor?
To monitor Cisco VOS applications using Skylar One, you must install the "Cisco: UC VOS Applications" PowerPack. This PowerPack enables you to discover, model, and collect data about VOS applications.
The "Cisco: UC VOS Applications" PowerPack includes:
  • Three example credentials you can use as templates to create SOAP/XML and/or Basic/Snippet credentials to connect to the VOS applications you want to monitor
  • Dynamic Applications and run book actions to discover, model, and monitor performance metrics and/or collect configuration data for VOS applications and devices.
  • Device classes for each of the VOS applications and devices Skylar One monitors
  • Event policies and corresponding alerts that are triggered when VOS devices meet certain status criteria
  • Run book action and automation policies that do the following:
  • Align the correct device class to Cisco VOS systems based on the GUID passed in an event.
  • Align the appropriate "Cluster Status" Dynamic Applications to VOS Cluster virtual root devices.
  • Verify that component devices remain aligned to the same collector as the root device.
  • Move the physical devices discovered using the "Cisco: UC VOS Applications" PowerPack to the same collector as their component devices when merging physical and component devices.
Installing the Cisco: UC VOS Applications PowerPack
If you are on "Cisco: UC VOS Applications" PowerPack versions 110 through 112, upgrading to version 14.0 of the Cisco: Unified Communications Manager application might break the integration with the PowerPack and require a snippet change for Dynamic Applications to function. For more information, see https://support.sciencelogic.com/s/article/14487.
Before completing the steps in this section, you must import and install the latest version of the "Cisco: UC VOS Applications" PowerPack.
