What is Cisco: Viptela?
Cisco Viptela provides a cloud-based, software-defined wide area networking (SD-WAN) solution. Viptela includes advanced routing, segmentation, and security capabilities for enterprise networks. Viptela's cloud-based network management and orchestration technologies help you deploy and manage the latest WAN architectures.
What Does the Cisco: Viptela PowerPack Monitor?
To monitor Cisco Viptela resources using Skylar One, you must install the "Cisco: Viptela" PowerPack. This PowerPack enables you to discover, model, and collect data about Viptela resources.
The "Cisco: Viptela" PowerPack includes:
- Example credentials that you can use as templates to create SOAP/XML credentials to connect to Viptela
- The "Cisco: Viptela vManage Template" for aligning all Dynamic Applications to the root component device
- Dynamic Applications to discover, model, and monitor performance metrics or collect configuration data for the following Viptela resources:
- vManage
- vSmart Controller
- vEdge Routers
- vBond Orchestrator
- Device classes for each type of Viptela device monitored:
- ASR1000 Series
- ISR1000 Series
- ISR4000 Series
- vEdge
- vEdge Cloud
- vEdge 100
- vEdge 1000
- vEdge 5000
- vEdge 2000
- vEdge 100-B
- vEdge 100-M
- vEdge 100-WM
- vEdge Container
- vManage
- vSmart Controller
- Event policies and corresponding alerts that are triggered when Viptela resources meet certain status criteria
- Dashboards that display information about Viptela component devices
Installing the Cisco: Viptela PowerPack
