The "HP 3PAR: SMI-S" PowerPack can be used with any 3PAR storage array that has the SMI-S provider service enabled. The following sections describe how to configure SMI-S storage arrays for monitoring by Skylar One using the "HP 3PAR: SMI-S" PowerPack:
Prerequisites for Monitoring HP 3PAR
To configure the Skylar One system to monitor a 3PAR storage array that has the SMI-S provider service enabled using the "HP 3PAR: SMI-S" PowerPack, you must have the following information about the HP 3PAR Provider that you want to monitor:
  • IP address and port for the HP 3PAR SMI-S Provider
  • Username and password for a user with access to the HP 3PAR provider
The HP 3PAR Provider will act as the root device during discovery by Skylar One.
Creating a Credential to Monitor HP 3PAR Storage Arrays
To configure Skylar One to monitor HP 3PAR storage arrays, you must first create a Basic/Snippet credential. This credential allows the Dynamic Applications in the "HP 3PAR: SMI-S" PowerPack to connect with the HP 3PAR provider. An example Basic/Snippet credential that you can edit for your own use is included in the "HP 3PAR: SMI-S" PowerPack.
To create a Basic/Snippet credential to access an HP 3PAR device:
  2. Locate the example HP 3PAR SMI-S Example credential, click its Actions icon (actions icon) and select Duplicate. A copy of the credential, called HP 3PAR SMI-S Example copy appears.
  3. Click the actions icon (actions icon) for the HP 3PAR SMI-S Example copy credential and select Edit. The Edit Credential page appears:
  • Name.Type a new name for the credential.
  • Hostname/IP. Enter "%D".
  • Port. Enter the Port value for an HTTPS connection.
The default value for the Port field is "5989", however, you should use the Port value you have configured for your provider.
  • Username. Enter the username for a user with access to the HP 3PAR provider.
  • Password. Enter the password for the HP 3PAR account username.
Creating a Credential to Monitor Storage Arrays in the Skylar One Classic User Interface
  2. Locate the HP 3PAR SMI-S Example credential and then click its wrench icon (wrench icon). The Edit Basic/Snippet Credential modal page appears.
  1. Click the Save As button.
Discovering HP 3PAR Storage Arrays
To model and monitor your storage system, you must first run a discovery session to discover the HP 3PAR Provider that Skylar One will use as the root device for monitoring the storage system.
The discovery session will discover the HP 3PAR Provider as a pingable device using the Basic/Snippet credential that you created.
To discover the storage system that you want to monitor, perform the following steps:
  2. Click the Unguided Network Discovery button. Additional information about the requirements for discovery appears in the General Information pane to the right.
  2. On the Credentials page, locate and select the Basic/Snippet credential you created.
  3. Click Next. The Discovery Session Details page of the Add Devices wizard appears:
  • List of IPs/Hostnames. Enter the IP address for the HP 3PAR Provider.
  • Which collector will discover these devices?. Select an existing collector to monitor the discovered devices. Required.
  • Discover Non-SNMP. Toggle on (blue).
  • Model Devices. Toggle on (blue).
After the discovery session, you must manually align the following Dynamic Applications to the HP 3PAR Provider pingable device:
  • 3PAR SMI-S: DCM Caching Configuration
  • 3PAR SMI-S: Volume Stats Cache
  • 3PAR SMI-S: Storage System Configuration
When you do so, Skylar One will discover, model, and monitor the remaining component devices in your storage system.
  1. Go to the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface.
  2. Locate the HP 3PAR root device and then click its wrench icon (wrench icon). The Device Properties page appears.
  3. Click the Collections tab. The Dynamic Application Collections page appears.
  4. Click the actions icon and select Add Dynamic Application from the menu.
  5. In the Dynamic Application Alignment modal:
  6. Click Save to align the Dynamic Application with the HP 3PAR root device. The Dynamic Application begins collecting data at the default polling interval.
  7. Repeat this process for the "3PAR SMI-S: Volume Stats Cache" and "3PAR SMI-S: Storage System Configuration" Dynamic Applications.
You do not need to align a credential to the "3PAR SMI-S: Storage System Configuration" Dynamic Application.
Discovering HP 3PAR Storage Arrays in the Skylar One Classic User Interface
The discovery session will discover the HP 3PAR Provider as a pingable device using the Basic/Snippet credential that you created. You must manually align the following Dynamic Applications to the HP 3PAR Provider pingable device:
  1. Go to the Discovery Control Panel page (System > Manage > Discovery).
  1. The Discovery Session Editor page appears. On this page, define values in the following fields:
  • IP Address Discovery List. Enter the IP address for the HP 3PAR Provider.
  • Other Credentials. Select the Basic/Snippet credential you created for the SMI-S Provider.
  4. The Discovery Session window appears. When the HP 3PAR Provider is discovered, click its device icon () to view the Device Properties page for the HP 3PAR Provider.
  5. From the Device Properties page for the HP 3PAR Provider, click the Collections tab. The Dynamic Application Collections page appears.
  1. Click the actions icon and then select Add Dynamic Application from the menu. The Dynamic Application Alignment page appears:
  1. In the Dynamic Applications field, select 3PAR SMI-S: DCM Caching Configuration.
  2. In the Credentials field, select the Basic/Snippet credential you configured for the HP 3PAR Provider.
  3. Click the Save button.
  4. Repeat steps 8-12 for the "3PAR SMI-S: Storage System Configuration" and "3PAR SMI-S: Volume Stats Cache" Dynamic Applications.
You cannot align a credential to the "3PAR SMI-S: Storage System Configuration" Dynamic Application.
  1. The Dynamic Applications appear on the Dynamic Application Collections page and begin auto-aligning the other Dynamic Applications in the "HP 3PAR: SMI-S" PowerPack to the HP 3PAR Provider and discovering the other component devices in the storage system.
It might take several minutes after manually aligning the discovery Dynamic Application for Skylar One to discover and model the remaining component devices in the storage system.
